Old 08-11-2014, 08:30 AM   #176
Flatpat
Flatpat's Avatar
Re: 1987 GMC V1500 Sierra Classic LS swap/build
Post #5 shows how he did it.
http://67-72chevytrucks.com/vboard/s...d.php?t=532351
Since the module has it's own bucket you don't need an EFI tank. Sure you can find non EFI 20 gal for pretty cheap.
Flatpat is offline   Reply With Quote
Old 08-11-2014, 08:44 AM   #177
NastyBuzzard
NastyBuzzard's Avatar
Originally Posted by Flatpat View Post
If you are using all the wiring and the gauges for the '01 why not use the fuel module from the '01 as well, already has the right pump and fuel level sender. I believe you can modify your current tank or a 20 gal to accept it with:
http://www.vetteworksonline.net/cata...hv3jun2ivcuc20
Mrwhitels1 did it on his blazer (now on his K10)
I would love to do that! The 01 pump assy is really deep b/c the 01 tank is really deep, it has a spring mechanism on it that makes it go to the bottom of the tank.
If I can find more details on how to do that, it is exactly what I will do. It is the best way to go about it in my opinion.
NastyBuzzard is offline   Reply With Quote
Old 08-11-2014, 08:59 AM   #178
NastyBuzzard
Just some more updates..
Wiring harness removed from the 87.
My mess:
01 donors rad may be trashed...
Transfer cases adapters are a tad different!
Tried to seperate the 01 donors wiring a little. Makie it a little easier to manuever and run. Seperated into engine wiring, fuse panel wiring, and interior wiring.
Old 08-11-2014, 10:21 AM   #179
NastyBuzzard
Thanks!!
So you are saying I need a non baffled tank instead of the baffled 87 tank I have now?
I maybe could try and track down a 20 gal tank or just maybe buy a new one.
Old 08-11-2014, 10:56 AM   #180
NastyBuzzard
Also the artic blaze thread guy is using a blazer tank, which has the hole for the pump assy like in the middle.
These damn side saddle tank has the hole for pump assy near the edge of the hump..
I think it may still work though... Not sure.
Old 08-11-2014, 01:57 PM   #181
Flatpat
Flatpat's Avatar
You can still use your current tank. Just saw you were thinking about moving up to a 20 gal tank and figured if you went this route you don't need a baffled tank. It being in the middle isn't a big deal, ideally you want it mounted in the deepest part of the tank which is where I believe the current sending unit in the tank is mounted. If you are worried about the module being too tall, from what I can tell a majority of modern GM vehicles have roughly the same design for the fuel modules with varying heights. If you have a pick and pull need by you could find one closer to your current tanks height.
Old 08-11-2014, 02:05 PM   #182
NastyBuzzard
Yes I eventually want to go to a 20 gal tank.
Thats a great idea about pull a part. Unfortunately, I don't have any that are close by. Could go to Azone or Advanced and just get them to show me a crap ton of the ones they have in stock.
Not sure what vehicles to check though? Maybe a van or impala or something?
Old 08-11-2014, 02:11 PM   #183
Jonboy
Slots go on anything!
I would say 20 gal. longbed tank for your truck would work.
1974 Jimmy- 5.3/4L80e/NP241
Old 08-11-2014, 02:13 PM   #184
NastyBuzzard
I'll work on locating one. I could probably find a decent used one that isn't baffled for pretty cheap. It is trying to find a baffled one that is difficult.
Old 08-11-2014, 03:04 PM   #185
Flatpat
Flatpat's Avatar
I suppose you could have them show different ones that they have then see if a junkyard or craigslist has one. From what I've seen, you want the module to be about an inch (uncompressed) taller than the tank. Then the springs when compressed make sure it doesn't move.
Old 08-11-2014, 03:10 PM   #186
Flatpat
Flatpat's Avatar
The most popular module I'm seeing used in swaps is the 99-02 LS1 F-body module. Also the Pontiac modules are popular, grand prix, GTO, etc..
Old 08-11-2014, 03:14 PM   #187
NastyBuzzard
Possible to modify the "bucket"? Change or cut springs?
Module? Are you talking abou the fuel pump assembly?
Old 08-11-2014, 04:04 PM   #188
Flatpat
Flatpat's Avatar
Here's a good read on how this guy did his.
http://www.gearhead-efi.com/gm-ecm-p...onversion.html
Old 08-11-2014, 04:11 PM   #189
NastyBuzzard
Very nice!! Thanks! Only difference is he extended and I may need to shorten...
Although without the baffles in the tank I may not need to shorten too much...
Gonna try and track down a 20 gal carb tank.
Old 08-11-2014, 04:21 PM   #190
Flatpat
Flatpat's Avatar
No problem, I'm looking at doing the same thing to the dual tanks in my K30 for a 8.1 swap when I get back so I had been looking around for info. It'll be cool to see how it works out for you.
Old 08-11-2014, 04:30 PM   #191
NastyBuzzard
I will take plenty of pics! I need to find a huge hole saw!
Old 08-13-2014, 10:10 PM   #192
NastyBuzzard
Still wondering how this is gonna swap in.
Got these bad boys in today!! Got them on sale too!
My 87s trans is getting ready to say bye bye tomorrow.. Gonna swap it for something special but don't want to jinx it!
Next big step is to wire wheel/clean frame and paint it chassis paint.
Old 08-14-2014, 10:50 PM   #193
NastyBuzzard
700R4 is gone! Traded it for this:
Details:
2002 6.0 LQ4 167k miles
Came with everything minus exhaust manifolds, power steering pump & bracket, ac compressor and alternator w/ bracket.
Story goes; friend wanted to swap in brand new engine b/c original one had very low oil pressure. Bouncing from 0-20 psi at idle.
Previous owner said he drove truck on the trailer, brought it home, drove it off trailer, swapped engines and he got to keep the old one. Said he was gonna stroke it for his race truck. Low oil pressure but only had valve chatter no knocking.
I checked oil after I got it unloaded and is about 2-2.5 qts low. Gonna let this one sit on my stand and maybe rebuild it once I sell my 350 TBI. Who knows.
Still planning to swap the 4.8 into my 87, mostly b/c I know it ran decent right before I pulled it.
Old 08-15-2014, 12:38 AM   #194
y5mgisi
Second Chance Program
y5mgisi's Avatar
Nice trade!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 08-15-2014, 07:34 AM   #195
NastyBuzzard
Originally Posted by y5mgisi View Post
Nice trade!
I agree!! Never thought I would end up owning one of these! Perfect candidate for my 79 Trans Am... One day..
Old 08-16-2014, 03:15 PM   #196
Hankster
Hankster's Avatar
Good score! I say put in a new PCV valve and a oil change and that motor is probably fine.
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 08-17-2014, 07:38 PM   #197
NastyBuzzard
I am not sure if I want to chance it.. Hate for no oil pressure to cause some deep grooves in the block. I wish I could just do that and a new oil pump and roll out though!! We will see when I tear into it a little farther.
Old 08-17-2014, 10:30 PM   #198
NastyBuzzard
Got it set down tonight to see if I need to order a set of f-body manifolds. I got a friend who can ship me some this week for $125. 01-02 egr less ones w/ flanges. Not sure if that's a great deal or not but cheaper than I have seen elsewhere.
DS looks tight, like if I move it at all may hit/rub.
Just seeing how it will look.
So should I jump on the set of fbody manifolds or what? I do see now what people were talking about the truck manifolds pointing in odd directions.
Also not 100% sure I am in the location at which the engine is staying. I can move it around thanks to the dirty dingos but I don't have trans attached so not sure if this is the final resting place or not.
I also picked up a 20 gal carb tank to try and play with. I want to get the 01 fuel pump assy in it, if possible.
Old 08-18-2014, 09:55 PM   #199
NastyBuzzard
Now to figure out how to get these to work...
stock tbi lines on bottom, top 3 are from the donor truck.
Old 08-19-2014, 11:44 AM   #200
NorCalAnthony
Great job on your build so far. I'm about to start a similar project on my '89 K5 and even have a complete donor ('00 Yukon) like you do lol. I want to see how you wind up getting the newer sending unit mounted in the older tank since I'm going to have to do the same thing with mine to carry over all of the evap stuff for the eventual smog ref inspection I'll have to do... Keep up the good work
NorCalAnthony is offline   Reply With Quote
