Old 07-28-2015, 10:19 AM   #176
77K10Silverado
77K10Silverado's Avatar
Re: 1977 K10 Silverado Longbox
Mike B.
77 K10 - http://67-72chevytrucks.com/vboard/s...=1#post6752641
77K10Silverado is offline   Reply With Quote
Old 07-28-2015, 05:02 PM   #177
rusty76
rusty76's Avatar
That does look good. You can really see the shine.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 07-29-2015, 06:07 PM   #178
Chevrolado
Chevrolado's Avatar
I just read through this whole thing and I must say, thank you for the inspiration. My 77 is sitting pretty rough and I have never taken on a restoration project before (all my previous car building has been improving 94 and newer vehicles) and now I can see what the hard work and patience can get you. I really like what you've done so far.
I'm looking forward to following much of the same for mine.
Subscribing to continue watching this one.. Great work.
Dave
- 1977 Chevy K10
Chevrolado is offline   Reply With Quote
Old 07-30-2015, 08:46 AM   #179
77K10Silverado
Thank you for the kind words! Its def been a process in which has slowed due to funds at the moment. And the fact i'm just enjoying it and don't want it to be torn down for long periods at a time. I do have some near future plans of replacing the front springs and all the shocks soon. I figure if i'm taking the front springs down I might as well pull the front 10 bolt and do the whole thing like I did the rear. Prob save it for winter or early spring.
Mike B.
Old 08-10-2015, 01:02 PM   #180
77K10Silverado
Rebuilding the front drive shaft. Stripped it down then painted with Chassis Saver and Semi-gloss rattle.
Is the knuckle suppose to move freely or is it kinda hard to roll over per say..?
Mike B.
Old 08-27-2015, 09:45 AM   #181
77K10Silverado
Restored the door pockets last night.
Cleaned them with purple power then wiped them down with a wet rag. Took the elastic out of a pair of old boxers and replaced the worn out ****. Came out pretty good with good snap back action!
Mike B.
Old 08-27-2015, 09:55 AM   #182
y5mgisi
Second Chance Program
y5mgisi's Avatar
Like!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 08-27-2015, 11:51 AM   #183
C@rnut001
Awesome job on your truck. Keep it up!
C@rnut001 is offline   Reply With Quote
Old 08-28-2015, 04:46 PM   #184
rusty76
rusty76's Avatar
Cool idea.
My build thread
Crossmembers CC
Old 09-02-2015, 09:28 AM   #185
77K10Silverado
Power steering leaks suck...
I noticed a drip starting to happen in the driveway and the hoses and frame being wet the last week or so. After an investigation, I found the pressure hose to have a small worn hole from the protruding brake line clamp screw going through the frame. Here's some pics of the tear down. I plan to clean it all up, paint it up and put on new hoses. Seems to work fine other than the leak.
Mike B.
Old 09-02-2015, 09:29 AM   #186
77K10Silverado
More
Mike B.
Old 09-08-2015, 08:28 AM   #187
77K10Silverado
Well im all in now. Time for a front 10 bolt rebuild, new leaf springs and shocks. Also going to redo the rest of the brakes that I left undone from last winter. I pulled the say bar out as it will get powder coated and re-bushed. I'll prob pull the motor so I can get to the lines easier and clean and paint the frame while i'm in the bay. Here's some pics of the disassemble. Time to buy some parts...
Mike B.
Old 09-08-2015, 08:37 AM   #188
77K10Silverado
Mike B.
Old 09-08-2015, 08:38 AM   #189
77K10Silverado
Mike B.
Old 09-08-2015, 08:39 AM   #190
77K10Silverado
Mike B.
Old 09-09-2015, 12:26 PM   #191
77K10Silverado
Another shot of her limping for now..
Mike B.
Old 09-09-2015, 02:04 PM   #192
Matt Man
Matt Man's Avatar
Looking good Mike, that is a lot of work. Since you have the axle pulled, you should install the ORD steering box brace.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 09-09-2015, 02:42 PM   #193
77K10Silverado
Thanks Matt! I don't plan to run bigger than 31/32s on the truck. Do you think its necessary? I've inspected the area and seems to be solid and crack free. I'm going to pull the box and get a better look.
Mike B.
Old 09-09-2015, 02:50 PM   #194
Matt Man
Matt Man's Avatar
I put one on mine ( I run 33 x 12.50 tires). Mine did not have any cracks, but I feel even if the 2wd trucks can crack around the frame, it is cheap insurance to buy the brace if the frame is not cracked. Also on the 73-80 trucks the frames can crack even easier, because on 81 and up they have a little mini brace around that area from the factory. After I installed mine, it made quite a difference in the frame flex around that area, before I could actually see it move a little bit, now it doesn't move at all.
Old 09-11-2015, 01:50 PM   #195
77K10Silverado
I guess I should consider it. I may even fab something up myself off the idea.
Mike B.
Old 09-11-2015, 02:19 PM   #196
68Timber
I know the pieces fit
68Timber's Avatar
Now if someone fishes around in your map pocket you can tell them their hand is in your underwear. Sub'd.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 09-11-2015, 02:22 PM   #197
77K10Silverado
Lol!
Mike B.
Old 09-11-2015, 02:26 PM   #198
77K10Silverado
Here's the dis-assembly of the front auto locking hubs.
Mike B.
Old 09-11-2015, 02:27 PM   #199
77K10Silverado
Mike B.
Old 09-11-2015, 02:28 PM   #200
77K10Silverado
Mike B.
