Old 10-15-2020, 09:01 PM   #176
J3rm0ff
Re: 72 Swb starting from the bottom
Work on the besides is underway and the front tires have been mounted. Work to the front fenders coming up next. Also bought the Amd wider rear wheel tubs to clear the rear tires.
J3rm0ff is offline   Reply With Quote
Old 12-10-2020, 11:08 PM   #177
J3rm0ff
Been working on the truck here and there. Still working on the bedsides. About finished up with them. I raised the tubs and welded in new nuts. Also made “inner” tubs which will be getting welded into the bedsides next.
Also made some progress on the rear brakes. Ended up having to use rear rotors from a hellcat because they have more of an offset which allowed more caliper to wheel clearance. The diameter and thickness is the same as the camaro so no issues with the caliper. Did some work to the axles including redrilling them and pressing in longer studs. Also had to redrill the rotors. I 3d printed some mock-up brackets for the calipers and got them pretty much spot on. Just need to order some material to get them made.
Old 03-07-2021, 08:42 PM   #178
J3rm0ff
Rear caliper brackets are done.
Old 02-17-2023, 04:11 PM   #179
J3rm0ff
I now can relate to the feeling of being in body shop jail. Lol except it’s my own jail. Slowly picking away at the body work. The dash is finally in and I ended up getting new fenders and hood to hopefully make the body work go faster. The fenders fit good after a little work. The hood will take a little more work. The used front clip had some issues that I am not skilled enough to fix.
Old 02-18-2023, 08:12 AM   #180
72 tigger
72 tigger's Avatar
Making progress!! Keep it up!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 11-23-2023, 10:53 AM   #181
J3rm0ff
Still picking away at the body work lol. The AMD fenders and hood fit absolutely terrible.
