10-31-2018, 01:07 AM | #176 |
Re: Anyone running CB's in their truck these days?
After reading through this thread, I'm pretty sure I want to put a CB in my 63. Is there any specific radio that y'all would recommend, or is it kinda just get something in my price range and if i like the looks of it or not?
This thread has so much information, that I think I need to read through it a couple more times
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
10-31-2018, 02:10 AM | #177 | |
I know there are some resto-purist nuts out there, who will insist you must have only a 23 Channel rig in a 67-72 truck. If that's true you'd have to have a 10, 15 or 19 channel radio to be period correct for a '63. I didn't get into the hobby until 1968, when 23 channels were available. Prior to '68 fewer frequencies were authorized. I don't know the chronology. I had old equipment with fewer channels [one quartz chrystal at a time]. 40 channel rigs came out in the '70s. I'd get a 40 so I could talk to anyone, if I were getting a new radio. Get a handle and have fun.
10-31-2018, 12:34 PM | #178 | |
10-31-2018, 08:08 PM | #179 |
If you buy a used CB, you'll have to take the seller's word that it works OK. Unless you know enough about electronics that you can test it yourself. Or have an expert friend.
One thing about Transceivers and 2-Way radios, if keyed without an antenna, or one without the correct 52 Ohm load, the final transmitter stage can burn up. Does not take long to "let the blue smoke out." That takes some expert internal work to fix. The older ones were more repairable -- made for that level maintenance -- the new ones are just junk if fried. A new rig will have a warranty and be sold by a shop who will set you up with the right coax and antenna. Buyer beware.
10-31-2018, 08:14 PM | #180 | |
I want to do it right, so I think this will be something that I need to do even more research on, and maybe hold off on for a little longer. No use in rushing to do something, just to end up doing it wrong, then having to do it again and waste time and money along the way
10-31-2018, 10:35 PM | #181 | |
10-31-2018, 10:39 PM | #182 | |
11-01-2018, 08:27 PM | #183 | |
Honda lost a class action suit by owners. Honda now sells Rodent Tape that is just like 3M ''E tape'' [or common electrical tape] except it has a mousie emoji with an X over it every few inches and is laced with capsicum. [Red pepper]. Instead of $3.00 a roll, it's $45. With my luck, here in Southern AZ, I'd get packrats who'd bite into it and say: ,,Muy sabrosa. i Los hilos de cobre con sabor picante!''
11-01-2018, 08:55 PM | #184 | |
12-30-2018, 04:54 PM | #185 |
Heres my set up
Cb is from 1976 i did not even drill a hole in the dash i used one of the screws for the heat controlls. And thats it.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
12-30-2018, 04:56 PM | #186 |
And my antana mounted to the tool box. I allso have a p/a under the hood
12-30-2018, 09:59 PM | #187 |
Nice rig. 23 Channel? How high is your antenna?
12-30-2018, 10:13 PM | #188 |
I run a general lee in my mack, good radio
12-31-2018, 02:37 AM | #189 |
It seems the easiest way to get a Public Address system is to get a CB so I may put one both in my car and my truck.
12-31-2018, 12:14 PM | #190 |
Yep 23 channel. I haven't messered it. But its fully ajustible. I can make it just a little taller then the cab. I think right now its about 2 ft higer right now. Mabe 2 1/2 ft
12-31-2018, 09:49 PM | #191 |
Just bought this Gray 300 to use with my Kris XL50
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
12-31-2018, 09:54 PM | #192 |
Quick question regarding the use of these.....does this end up being categorized as 'distracted driving' (like a cellphone) if you are using it while driving?
I wonder how the cops would approach that....but around here, I'm thinking they would hit you with a fine...unfortunately, but not sure. all good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
12-31-2018, 10:24 PM | #193 | |
01-18-2020, 05:13 PM | #194 |
Breathing new life in this thread ...
01-18-2020, 05:22 PM | #195 |
Reading you 5 by 5.
01-19-2020, 12:47 AM | #196 |
I just wanted an AM\FM radio, found this at a garage sale for free...not sure if the cb part works or not, I didn’t install the microphone. The radio works fine though, and it’s a cool piece...
01-19-2020, 10:49 AM | #197 |
Cruzin
Nice radio.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
01-19-2020, 09:34 PM | #198 |
[QUOTE=Abomb;8662040]I just wanted an AM\FM radio, found this at a garage sale for free...not sure if the cb part works or not, I didn’t install the microphone. The radio works fine though, and it’s a cool piece...
I have one of these and it worked great in the late 70’s but took it out of truck in the 1984 . I still have it and was thinking about having it restored because it fits in the radio cut out and it’s pretty cool besides. |
01-21-2020, 12:44 AM | #199 |
Just a reminder to anyone who's rusty on radio fundamentals or new to the deal -- Do Not transmit or even key the mike, without a proper antenna [or a 52 Ohm dummy load] attached to the radio. An unbalanced load can fry the final stage in the transmitter.
This used to be fixable, but with newer technology being microcircuited, and older technicians less available, it's pretty much a good way to scrap your rig. Careful.
01-21-2020, 09:47 AM | #200 |
Gee, maybe I should take one of my old Johnson Messenger II Blackface tube radios and set it up for Mobile. I could use the one that was used for police back then. It would double as a heater. LOL
1968 C-20 CST Vermillion http://imageevent.com/happy_dan/dantoys/68c20 2019 Silverado 2012 Camaro ZL1 |
