Old 08-18-2023, 09:32 AM   #176
57FleetsideC4
Re: 57 Fleetside C4 build
Originally Posted by dsraven View Post
that looks really good, nice job. keep the pics coming, its great to see forward motion on a project and really good to see it when the parts get put together for the final time.
Originally Posted by youngrodder View Post
Looking great. Final assembly is the best.
Originally Posted by Jason 56 View Post
Looking good! I like the original white roof look.
Thank you for the kind comments. My goal was to have all the color on it by fall then spend all winter putting it together and hope to have it burning gas in the spring. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is online now   Reply With Quote
Old 08-30-2023, 08:19 PM   #177
57FleetsideC4
More progress on the 57 project. Got the bed panels and inner wheelhouses all painted. Still a ways to go but getting closer. also took a piece of pine and put a lighter and darker stain then 4 coats of the same clear I used on the body. here are the pics of the panels. Steve
Old 10-28-2023, 09:13 PM   #178
57FleetsideC4
made more progress on the 57 project. Got the Vanilla Shake on he bedsides and cab. Also got the raptor bed liner sprayed on the bedsides, front fenders, rear wheelhouses, front inner wheel houses and front shields. Here are some pics. Steve
Old 10-28-2023, 09:15 PM   #179
57FleetsideC4
second batch of pics from previous post. Steve
Old 10-28-2023, 10:41 PM   #180
dsraven
nce job!
I like the way you have the dark color "stripe" on the upper body line. that breaks itup very nicely in my opinion.
keep on posting the progress, it keeps us slackers interested. i actually had time between other jobs to do a little work on my 57 the last few days,. been awhile.
Old 10-28-2023, 10:42 PM   #181
dsraven
man, i gotta proof read a little before hitting post. it seems like I mess up a lot typing this stuff up. fat fingers.
Old 10-29-2023, 09:50 AM   #182
Rickysnickers
Um, didn't we already discuss this Dennis???? I mean really.....
Old 10-30-2023, 09:11 AM   #183
Jason 56
Looks great! Is that the start of a cut n buff I see on the back of the cab?
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 10-30-2023, 07:15 PM   #184
57FleetsideC4
nce job!
Thank You. I did the upper strip of brown to break up the two tone.
Thank You. Yes that was the start of the cut and buff. That area is buffed out now. Steve
Old 11-18-2023, 09:10 PM   #185
57FleetsideC4
I started to work on the inside of the cab and core support. I put down some fat mat on the floor, back wall, firewall and kick panels. I want to put it on the roof where the headliner goes put not sure it will stick good. Got the Vintage Air box installed, radio, wiper motor and transmissions and started running hose for the heater and a/c. Little bit at a time. Steve
Old 11-19-2023, 02:49 PM   #186
daveshilling
daveshilling's Avatar
Nice job! Looks clean, intentional, and professional.
daveshilling is offline   Reply With Quote
Old 11-26-2023, 08:02 PM   #187
57FleetsideC4
Thank You. Steve
Old 12-15-2023, 03:10 AM   #188
Nut Case
Nut Case's Avatar
*****in Strong Work
Keep on Keepin on
nutz
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 12-15-2023, 03:12 AM   #189
Nut Case
Nut Case's Avatar
Bit
nutz
Old 12-15-2023, 03:16 AM   #190
Nut Case
Nut Case's Avatar
CHIN
nutz
there that will blow hatz and that's all i have to say about that
Old 01-03-2024, 08:19 PM   #191
57FleetsideC4
Hi, Making some more progress on the 57 pickup project. Got a lot of the wiring done, decided where the PCM, TAC module and relay center will live. Installed the steering column, almost done with the vintage air install, started making brake lines and battery cables. I should be able to power up the truck and see if I can communicate with the PCM, see if the fuel pump has its 2 second prime and run the fans. Getting closer all the time. The ligh is getting brighter at the end of the tunnel. Steve
Old 01-06-2024, 09:31 PM   #192
57FleetsideC4
Some more progress pictures of my project. Test fit the steering wheel after, finished making battery cables, brake lines and made the aluminum panels for under the back window which will get covered with carpet. Getting closer. Steve
Old 01-09-2024, 12:17 AM   #193
Jason 56
Looking great. I’m in the same assembly phase with my build. I’ve been trying to figure out what to do with my back wall. I may be borrowing your idea. I like it. Keep up the pace. You’ll be done before the thaw!
Old 01-09-2024, 09:39 AM   #194
57FleetsideC4
Thank You. I used .060" aluminum for those pieces. the end pieces were pretty tough to bend as I have know bending tools so had to use the vice and my Argon tank. It worked out and should look good. I started on the door stuff and found out the reproduction vent window mounting holes were all off and had to be redrilled. Yes!! I hope to have it running in the spring Steve
Old 01-27-2024, 08:11 PM   #195
57FleetsideC4
Got a few more things going on my project. Put the vent windows and door glass in, finished the fuel lines and began mocking up the exhaust. Steve
Old 01-28-2024, 11:04 AM   #196
dsraven
looks great, nice and clean.
don't forget to leave room for some heat shielding in the gas tank and fuel line areas.
Old 01-28-2024, 11:06 AM   #197
dsraven
will you use stepped band clamps to hold it all together so it can be taken apart for maintenance or repairs of nearby stuff?
Old 01-28-2024, 02:51 PM   #198
57FleetsideC4
Hi, Yes I have shields to put on the bottom of the bed wood. I am going to try the stepped band clamps to hold it together and like you said if I need to move something or for access. Steve
Old 02-04-2024, 10:40 AM   #199
RockinKees
RockinKees's Avatar
Just read the whole thread.
Amazing work in such a “short” time.
You make the conversion to C4 suspension look easy!
Real craftsmanship here!
I also like the two-tone colorcombination, great choice.
Tag along for the rest to come….
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 02-04-2024, 10:12 PM   #200
57FleetsideC4
Thank You for the comment, I can't take credit for the C4 setup as I bought this at a started project. I finished some of it and did everything else. Steve
