03-29-2021, 07:50 PM | #2001 |
Re: What did you do to your truck today.The 3rd chapter
Couple more
03-30-2021, 08:14 PM | #2002 |
Mr. Cheyenne
Installed a new Delphi 3-line fuel pump, to replace a Carter that ticked very loud. I even did it by myself after learning here on the forums about using a longer bolt to hold the rod in place (little bolt you temporarily take out/replace on the front of the engine above the fuel pump). Which one of the fuel pumps bolt worked perfectly for this!
When my brother and I installed that POS Carter last summer, I had my finger holding that darn rod up while he was stuffing the pump in to get it bolted down! I just remember taking forever to get it back installed LOL
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
03-30-2021, 09:05 PM | #2003 |
I removed the Edelbrock Carb and fuel pump and lines. Getting ready for FI Tech fuel injection.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
03-31-2021, 01:11 AM | #2004 | |
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
03-31-2021, 01:46 AM | #2005 |
Throttle cable broke at the pedal. Seems no one has the oem replacement so went with the Lokar throttle cable and Lokar pedal. They recommended to use the kick cable as well but everything worked out and didn’t need the kickdown cable. Pedal response is better, still need to do some minor alignment adjustment but it’s back driveable. Have the matching brake pedal but lost daylight.
03-31-2021, 09:46 PM | #2006 |
Picked up some sprayable material.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
04-01-2021, 09:53 AM | #2007 |
I've used popsicle sticks in the past to do this .
04-01-2021, 11:10 AM | #2008 |
Mr. Cheyenne
Well, I like the bolt method for the fuel pump rod - can't see why not to go that route.
Today I found I have a bad light socket in my dash, was the one in between the Tach and the Fuel gauges. Then I spent some time (embarrassed to say how much) trying to figure out why the two below it wouldn't turn on.... then it dawned on me, those are the Brake (and I think) Oil idiot lights. Well, they sure made me feel like a idiot trying to make them work for dash lights. Edit: And I now have a new license plate light! It actually was working before but it didn't have a lens - I have a feeling it will look better tonight when I check it out.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 04-01-2021 at 02:50 PM. |
04-01-2021, 03:55 PM | #2009 |
04-02-2021, 06:01 PM | #2010 |
I rebuilt my front suspension a couple of months ago when I installed a disc brake conversion kit. I finally got around to getting an alignment job yesterday. I told the tech I wanted the camber to be around the negative limit of the tolerance for better cornering. He took the measurements and the software wanted him to add a shim to the rear mount of the left side to decrease the caster and increase camber. I told him to remove a shim from the front mount instead so that the caster would still be decreased and the camber would be moved toward the negative limit like I wanted, but he was convinced it wouldn't work that way. We went around and around, and then the manager got involved. Finally, they called the in-house alignment expert over and he confirmed what I was saying would work. They did it, and the numbers ended up how I wanted them. I guess that's the way it goes when you're dealing with an old vehicle and want something special done.
The caster is a bit higher than the spec, but it's not an alignment aspect that leads to tire wear. Being higher than spec should make it more stable. At least the two sides are better matched to each other than they were before. The toe is in spec, although I read in another thread that a smaller toe is more desirable. Hopefully I don't end up with excessive tire wear. Last edited by pjmoreland; 04-02-2021 at 06:07 PM. |
04-03-2021, 09:56 AM | #2011 |
Mr. Cheyenne
That's the very next thing for my truck - I just bought replacement parts from RockAuto.com (Moog) yesterday. Now I need to find a shop that will install these parts and deal with getting the rivotted upper ball joints out too. I even got a CPP sway bar too coming this week!
This morning I waxed the truck too. As I was finishing, wouldn't you know it - it started to sprinkle / rain. Popped her back into the garage real quick and dried her off.
04-03-2021, 10:16 AM | #2012 |
laying low
It sure looks nice Rich.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
04-03-2021, 10:34 AM | #2013 |
Mr. Cheyenne
Thank you!
After I gave her a quick wash yesterday before having a nice afternoon in downtown Lockhart Tx, I decided she needed a nice waxing. Yesterday was fun having the truck loaded up front with my daughter and her mom (they fought who got stuck in the middle LOL). Everyone goes on about Black's BBQ but we all like Smitty's Market much better. Lockhart is a classic Texas downtown square and it's the county of Caldwell County. The truck looked real nice parked in front of the court house. Hindsight, I should have gotten a photo.
04-04-2021, 09:07 AM | #2014 |
I got a few things done on Saturday. I installed my new air cleaner on the engine that needs cleaning up. I saw that cleaner on a member's truck and he told me where to get one at. This will get me motivated to clean up the rest of that dirty engine compartment. Also, finally got the seat together in one piece with the seat tracks mounted. The seat came out pretty nice and can't wail to have it mounted in the truck one day. I will finally have a seat instead of a milk crate to sit on
04-04-2021, 02:03 PM | #2015 |
Mr. Cheyenne
Hey, that cleaner looks familiar!
I cleaned up my engine bay for the hot water cut off, got rid of the one the A/C guy put on and picked up one from O'Riley's (thank Grumpy for the part suggestion). I also wired up the 3rd brake light. Last summer I switch out all the markers with LEDs and the Cargo has a brake light. It was a lot easier to run the wire to the brake light switch than I thought it would be - it was really a snap to run and connect up.
04-04-2021, 02:31 PM | #2016 | |
70+ ( Old Skool Club )
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
04-04-2021, 02:50 PM | #2017 | |
04-04-2021, 02:55 PM | #2018 | |
04-04-2021, 02:58 PM | #2019 |
Mr. Cheyenne
I hope you like it, it would suck if you didn't after I told you where to look for it!
Nice work on your seat, you milk crate comment reminded me of my Dad - he drove around in his Model A in the mid-60s with a milk crate (or so he said) LOL!
04-04-2021, 03:06 PM | #2020 | |
Mr. Cheyenne
I tried to stay with R12 but everything that had to do with the factory air leaked, so I switched to R134a at a A/C shop in Longview, Texas. I am pretty sure it is Vintage Air. I do know they painted it black, per my request. I know the condenser is, I saw that listed as a line item (parallel flow). Edit: after rerunning the heater lines and installing my new cut-off I used my laser light to catch the temp coming from the outlets. I was a stable low of 33° - granted it was pretty early in the morning and hardly 65° inside the garage. Edit2: attaching photo of A/C Compressor sticker...
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 04-04-2021 at 03:18 PM. |
04-05-2021, 10:38 AM | #2021 |
Only thing I did over the weekend was hang the tailgate as the last fitment check before it comes apart for scuffing and epoxy primer.
04-05-2021, 12:38 PM | #2022 |
Worked on touching up vent window and door components - paint, new rubber, etc.
04-05-2021, 11:09 PM | #2023 |
Over the weekend we got the frame cleaned and painted.Today, my son got the bed all polished out.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
04-06-2021, 12:27 PM | #2024 |
Awesome progress. Are you going to do a full repaint or keep some of the original paint, match the bed?
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
04-06-2021, 01:17 PM | #2025 |
Guest
Posts: n/a
Changed out my headlight switch and repositioned some of the spade connectors in the plug so lights would work as intended. Also added fresh headlights and adjusters. Much better now!
Update: Just hooked-up a Neutral Safety Switch...really nice to have with the Star Shifter the PO stuck in there...not always easy to tell what gear she's in with this whacky shifter. Last edited by dweikum; 04-06-2021 at 02:47 PM. |
