Old 08-07-2015, 11:36 PM   #2176
kjones72
A buddy told me about your build. I've just finished my p pump 24v swap. But I'm having trouble with the engine had a couple questions if ya don't mind
kjones72 is offline   Reply With Quote
Old 08-11-2015, 05:44 PM   #2177
rgreathouse
Re: 1972 Chevy 4wd Longhorn Project: Never Ending Changes
How are you liking the Dakota digital gauges? Do you have a boost and pyro? I've been looking into the cHx gauges with the bim modules but not sure where the additional readings are displayed?
1972 c10,2wd,long bed,250,4spd---->
1972 SWB Fleetside 4x4 12v Cummins build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=513791
rgreathouse is offline   Reply With Quote
Old 08-11-2015, 07:16 PM   #2178
ryanroo
ryanroo's Avatar
The factory tach position has a digital readout that you can toggle through the extra outputs. Ryan also got an auxiliary display so he can see more than one.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 08-11-2015, 07:57 PM   #2179
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Sure, no problem. Ask away.
Like Ryan said, they are dis[layed where the original tach used to be. I did get another display too. I'm not sure where I will mount it. I haven't driven the truck a lot, but I do like these gauges. I have to finish mounting my BIM modules and hooking them all up.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 08-11-2015, 07:59 PM   #2180
Dieselwrencher
The Longhorn got a room mate too. Ryan, here are a couple other pics of the back bumper that you asked for a while back.
Ryan
Old 08-20-2015, 05:12 PM   #2181
Dieselwrencher
I've been working on diagnosing the trans before I pull it out for repairs. The only weird thing is the front servo seems to have no pressure in reverse. All other pressures are fine. Out it comes.
I've been working on getting the corvette ready to go to the track next Friday night. My youngest brother is getting married on the 29th so the 28th for his bachelor's party he gets to take the car and make some passes. I just put taller front tires on it to gain some clearance. If you like Diesel World magazine, the car wil be in October or November's issue.
Ryan
Old 08-21-2015, 11:47 PM   #2182
6BT 56
6BT 56's Avatar
Hey that's cool. Not too many people that can say they got there diesel powered vette featured in a magazine . Lol. Congratulations !
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 08-25-2015, 08:41 PM   #2183
Dieselwrencher
Thanks!
Ryan
Old 08-26-2015, 08:22 AM   #2184
mcbassin
Still Learning
mcbassin's Avatar
Nice corvette! we need more pictures of that puppy. Do you have thread in the alternate tinkering area?
mcbassin is offline   Reply With Quote
Old 08-26-2015, 06:58 PM   #2185
Dieselwrencher
I can't remember if I do or not. I'll have to check.
Ryan
Old 08-27-2015, 10:17 PM   #2186
kjones72
I put a p pump on my 24 valve. And I'm not getting fuel that I should be getting out( no black smoke.) I have a airdog165 with 1/2" line from the tank straight into the inj. Pump have done all of the AFC mods. Still nothing. I was told it needs more timing and 4k gov.springs. it's at 18.5°advanced now. Since it has been advanced it seems a little better. But not what it should be. Tinkering with the AFC. I started it up with it off just for the hell of it. It's got coal for days.. Put it back on and back to crap. I don't want to roll coal alot. But I know if there's no smoke I'm not getting enough fuel and can't make power without it. Any ideas? Oh also stock injectors and turbo hx not the hy
Old 08-28-2015, 09:56 AM   #2187
burnin oil
Kjones, what what the pump off of? There are mods that can be made to the AFC to alow more travel out of it along with modding the diaphragm. My guess is that your fuel plate is pulled back and limiting full fuel or the AFC is to far back and not letting it fuel enough. The AFC housing is the only emissions equipment I ever liked. Set it up for a ton of fuel then dial it back till boost rises. Another thought is to ensure that you don't have a leak in the AFCs boost reference line or a faulty overflow valve (pressure valve in the return line). My 175hp pump and stock injectors would black out a lane of traffic when it had a stock turbo. 500HP has been hit with pump mods and a HX35 even though it was hot and smokey. You may want to reduce the timing a little. I ran 18-19* but always had head gasket issues even with studs and orings. 17* seemed pretty safe and spooled up a little better but power also dropped off earlier.
burnin oil is offline   Reply With Quote
Old 08-28-2015, 10:20 AM   #2188
kjones72
I forgot to add that. New reference line. And I took the fuel plate out to see if it would help. It's a new rebuilt unit that is suppose to replace the 175hp that I had which had sticking issues. I've done all the mods that I know of to the AFC. Including the diaphragm. Starting to wonder if the rebuilt pump could be the issue, as the shop has a 50/50 satisfactory with the community
Old 10-20-2015, 08:43 PM   #2189
Dieselwrencher
Kjones72, your timing sounds low to me for a P-pump 24v. Mine is set at 25*. I wouldn't go much lower than 23* personally. Sorry for the late response. I didn't see the new posts.
It may be too late to buy the mag off the stands now. The Vette was in Ultimate Diesel Builder's Guide October/November issue, instead of Diesel World. I had a hard time finding a copy a few weeks ago. It seems they were still on the racks last weekend though.
As far as the Longhorn, the trans should be done at the trans shop this week. Hopefully in the next two weeks I can get it put back together. The engine has developed an oil leak. I need to fix that before I put the trans back in. I haven't had time to mess with it with work and helping a friend with harvest.
Ryan
Old 10-20-2015, 09:08 PM   #2190
COS399
COS399's Avatar
Good job on getting in a magazine.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 10-27-2015, 06:20 PM   #2191
Dieselwrencher
Today I picked the trans up from the trans shop. It should be fixed now. The engine has developed an oil leak. I need to remove the engine adapter and see where it is coming from. once that is fixed, then I can get back to installing the trans. Ten I need to finish a lot of things I haven't gotten too, to make it a daily driver. Like, mount the air compressor, tank, and leveling valve. Install and wire the compu shift mini, wire the heater circuit, wire in the cab lights, cargo and third brake lights, and check the operation of the wipers. I need to re-visit the LMC heated washer reservoir as I think that may be a nice addition too.
Ryan
Old 10-28-2015, 08:13 PM   #2192
Chevy_mud_truck
Chevy_mud_truck's Avatar
I've read over both of your builds man you got all of work into your builds Ive been gathering parts and a lot of information and ideas from reading your two builds to help when I finally start actually building mine thanks for sharing all your hard work definitely show stopping attention getters
Chevy_mud_truck is offline   Reply With Quote
Old 10-31-2015, 08:23 PM   #2193
mx289
mx289's Avatar
Congrats on the magazine feature of the Vette.Very nice.
And good to hear your back on this again.
Tom
71 K2500
71 K5 Jimmy
mx289 is offline   Reply With Quote
Old 11-02-2015, 07:56 PM   #2194
Dieselwrencher
Thanks guys!
Ryan
Old 04-05-2016, 03:43 PM   #2195
Dieselwrencher
Same old stuff here. The truck has sat on the jack stands all winter out of the snow, ice, hail, rain, and even a tornado. Haha I've been acquiring more parts for it, and working on it when time allows. I managed to get my right and left seat belts in. A friend came over and worked on fitting the stereo to the billet radio mounting plate. He also hooked up the front speaker wires and mounted the speaker brackets I got from Bigblock73. I removed the brackets and painted them, then ran the speaker wires and reinstalled them. I also ran new wires to my cargo light and 3rd brake lights. Now I have to get a new cargo light switch to finish that. I also got my sill plates installed. Whoops, I almost forgot. I also installed my new precision push on door seals. I had to work them around pretty good with the rubber mallet to get them to fit end to end. Now the doors really shut hard but maybe they'll seal awesome. I also got the rear main replaced, and am picking up the expansion plug tonight that was my oil leak. I sent my torque converter in to get turned back into a diesel converter too. So when its back, I can get the trans put back in it. I'll try to add pictures later.
Ryan
Old 04-06-2016, 11:30 PM   #2196
Dieselwrencher
I forgot that I also ordered a 19gal Boyd aluminum tank. I had to have them change the mounting brackets, and it has a 1/2" feed instead of a 3/8". Now I have to decide on a side marker filler, tail light bed filler, or a bed floor filler.
Ryan
Old 04-06-2016, 11:34 PM   #2197
Dieselwrencher
Here are pictures of the new door weather stripping, sill plates installed with SS hardware, speakers, and seat belts. I also finally got my oil pan, rear main, and cam expansion plug all done. I also got a catch can for it. I think I'm going to mount it in the LH inner fender well. Now, once the torque converter comes back, I can put the trans and transfer case back in.
Ryan
Old 04-07-2016, 02:22 AM   #2198
COS399
COS399's Avatar
Looking Good!
Old 04-07-2016, 09:13 AM   #2199
1972K20
1972K20's Avatar
Looks good! I guess I overlooked it, but what did the seat and seat belts come out of? Also, are the belts mounted in the factory hole in the b pillar?
1972K20 is offline   Reply With Quote
Old 04-07-2016, 09:45 AM   #2200
brimc
brimc's Avatar
All looks very good!
I like the idea of side marker fill if you are wanting it hidden.
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
