09-18-2008, 03:25 PM | #202 |
Re: 67 C-30 Dually pickup build.
I have a question:
If you use the 69 big block motor mounts, will the rest of the running gear(trans(automatic) and drive shaft) stay in the stock location? |
09-18-2008, 06:02 PM | #203 |
I have a radical idea!
If it is already a V8 truck, yes. If it is a cylinder truck (like mine was) the tranny crossmember will have to come forward and the front driveshaft would have to be from a V8 truck. The big block frame mounts bolt in the same location as the SBC mounts, but sit the engine about an inch or so higher.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
09-19-2008, 11:33 AM | #204 |
[QUOTE=67_C-30;2895674]If it is a cylinder truck (like mine was) the tranny crossmember will have to come forward and the front driveshaft would have to be from a V8 truck. QUOTE]
What does that mean? |
09-19-2008, 04:24 PM | #205 |
I think he meant 6-cylinder truck. They have the tranny/clutch housing mounts back further that the V8 trucks do.
09-19-2008, 07:38 PM | #206 |
Duh! Sorry about that! Palf70step is right, I meant 6 cylinder truck!
09-21-2008, 11:00 PM | #207 |
Is the motor sitting in its final resting spot? If it is, did the front end sag at all from the additional weight from the diesel to the 6 cylinder? When I had the 6.2L in place of the chevy 350, the front drop about 1.5-2.5 inches... What springs do you plan on running?
thanks, David |
09-22-2008, 09:20 AM | #208 |
Rottenwood Garage Member
I raised the front of mine with some 3" lift springs, and I am running some taller tires on the front. I went from a 9" "red neck" rake to about 4" of rake rear to front. If I keep it she will get a 4TB.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! Last edited by 72freak; 09-22-2008 at 09:22 AM. |
09-22-2008, 09:33 PM | #209 | |
09-22-2008, 09:54 PM | #210 |
Resident of Here
Good job man! Cant wait to hear it run!
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
09-23-2008, 01:55 PM | #211 |
Look at that! Good job. This is a 6.2 with the turbo parts from a 6.5L, right? Keep up the good work.
09-23-2008, 04:28 PM | #212 |
Yes, it is '86 J code 6.2L from a military CUCV with '93 6.5TD parts on it.
09-24-2008, 01:49 PM | #213 |
Are you going to run the 86 drive assy, or are you going to upgrade to the 89 serpentine system? Thanks for the pics.
David |
09-24-2008, 09:04 PM | #214 |
For time being I'm going to run the V belts just for the fan and alternator. The military set-up is different that civilian, and I'm going to run dual belts on the alternator. I have a serpentine set-up from a '97 6.5TD that I'm going to put on it when I put on the A/C and the hydroboost setup.
09-26-2008, 08:10 PM | #215 |
I started building my exhaust this evening. I am going to run a 4" mandrel bent custom system from the turbo back with the Warpspeed straight- through design muffler. The factory exhaust housing on the rear of the turbo is restrictive and causes a lot of back pressure on these GM-X series turbos. The inside of the casting measures a touch under 2.600" at the outlet and is more restricted than the where the 90 degree bend is. I decided to build a custom system that will be 4" from the turbine housing back. I machined the flange at work on the CNC, and I'm building the pipe from pre-bent 90 and 45 degree pipes that I will have to cut and butt-weld to the straight lengths. I am going to run outside of the frame rail due the position of the turbo and the narrower frame on these year trucks vs the newer ones that the 6.5TD were designed for. I'm planning on turning it out right before the rear wheels on the passenger side. Here's a few mock-up shots.
09-26-2008, 09:06 PM | #216 |
Resident of Here
Good work! But no stacks?!?!
09-27-2008, 01:58 AM | #217 |
Texas Big Wig
Where in Alabama do you live ???
I think I need a vacation & would love to come work on your truck We have to do some black smoke pics |
09-27-2008, 07:16 PM | #218 |
Looks good.
10-06-2008, 06:30 PM | #219 |
Any updates?
10-06-2008, 07:05 PM | #220 |
Yes, I was actually about to post this. I finished up the down pipe today. I FINALLY got the pipe fitted and welded top the flange. It took quite a bit of persuasion to make it fit all the way around due to odd shape of rear exit of the turbo. The opening is bigger than the factory opening so there is no overhang. The ended up being a little over 4.5" at it widest point and around 3.5" at its smallest. It is still WAY bigger than the inside of the cast. The last shot shows how wide open the exit is. It makes a nice smooth transistion down for a 90 degree turn. The rest of the exhaust should be pretty straight forward.
10-16-2008, 04:33 PM | #221 |
I'M TRUCK CRAZY!
nice
10-16-2008, 06:49 PM | #223 |
Resident of Here
Schaweet!
10-21-2008, 11:31 AM | #224 |
I was looking over the pics again...this is one clean build. Whats new in the south? any updates?
11-19-2008, 08:43 PM | #225 |
Resident of Here
Updates?
