Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 06-07-2009, 10:54 PM   #201
19723DR
19723DR's Avatar
Re: 1972 3dr Suburban Build Thread
I took some pictures with the Suburban and the Cheyenne together.
Plans are to remove the front lower bag brackets with cups and make new rear brackets. I will also modify the inner fenders so the tires will tuck.
I also need to finish up the air system.
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser
71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished
93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's
98 Chevy short bed DD
97 Z71 3 Door
51 Suburban-S-10 swap
"What other hot rod can you carry 7 of your friends in"
19723DR is offline   Reply With Quote
Old 06-08-2009, 12:23 AM   #202
gmbpmidway
great pictures. great progress
gmbpmidway is offline   Reply With Quote
Old 06-08-2009, 12:35 AM   #203
nuke1
nuke1's Avatar
gotta love the look of the two of them just sitting next to each other loving life and knowing they have a good home, awww family. well done
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 06-08-2009, 07:10 AM   #204
babyblueoval
babyblueoval's Avatar
WHAT?!?!
The compressor and tank just sitting in the back wasn't finished???
It looks much better with the spacer in the back. I'm probably gonna do it the same way on mine.
And no, I haven't started yet. I know, I know. I will. I promise.
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 06-09-2009, 12:28 AM   #205
19723DR
19723DR's Avatar
Thanks. It's nice having a project you can take the whole family in.
I am so lucky that I came across these two trucks. I know that both would have become parts trucks. It goes to show the potential these trucks have. And with an insane amount of work, a lot of patience, and some help from your friends, you can save a truck from the crusher.
Originally Posted by babyblueoval View Post
WHAT?!?!
I never said I was moving the tank and the compressor.
With all the empty space in the quarter panel, you'd think I could hide it in there.
97 Z71 3 Door
Old 06-09-2009, 11:44 PM   #206
capev86
i like how you got that low rider look without butchering up a beautiful classic truck(no c-notch). a street truck is better looking than some hack job scraping on the ground anyway. air suspension is supposed to give good handling and you can make it sit up like a stock truck too. i think i would have gone with corvette yellow personally......keep it a little more true to gm, but still a beautiful show quality truck. keep the body mods and interior to a minimum. these trucks were just sooo sharp from the factory.
capev86 is offline   Reply With Quote
Old 06-10-2009, 10:34 PM   #207
19723DR
19723DR's Avatar
Thanks. My intentions were to make this build my way. I wanted to retain the classic style these trucks are known for. I was looking for a yellow that had a green tint similar to the original color, I had my paint shop custom mix a color for me. It seems like the corvette yellow is a common choice. I wanted to have a color no one else has.
I do have a bolt in C-notch. That is the only thing I've cut. Most people will say it doesn't devalue the truck. I am going to make a few improvements to the air system, like bag brackets. I did make the mistake of ordering the wrong kit--or should I say the kit from the wrong company. I am going to be replacing those parts with some that function more efficiently. This suburban has been in my friend's family for 26 years, hopefully it will be in mine for 26 more.
97 Z71 3 Door
Old 07-04-2009, 12:19 AM   #208
19723DR
19723DR's Avatar
Well I finally found some time to fix the air brackets. The old bracket that the original kit came with is for any coil spring application and not specifically designed for our type of trucks. Not to badmouth AIM industries, I started with the rear, cutting the bottom plate and then welding a four inch pipe to make the new one. I only gained a half inch so the next step will be to make some blocks.
97 Z71 3 Door
Old 07-04-2009, 12:51 AM   #209
19723DR
19723DR's Avatar
Over the winter I made some cups for the front. I took the top plate from the same bracket I made the rear cups from and a four inch rigid pipe. I also cut some of the bump stop bracket to clear the bag but still retain the steering stop.
Then I pulled out the inner fenders, which I'll mod latter. If you haven't been following this thread, my front brackets were two plates from AIM ind. I would not recommend using this kit. After I installed my cups, I gained an inch and a half. During the short drive to my brother's house I noticed the ride is much smoother both front and rear.
97 Z71 3 Door
Old 07-04-2009, 01:46 AM   #210
Frizzle Fry
Frizzle Fry's Avatar
Looking good! Why use a bracket in the rear at all? Mine are mounted right to the frame, no issues.
Frizzle Fry is offline   Reply With Quote
Old 07-04-2009, 02:21 AM   #211
38chevyhotrod
38chevyhotrod's Avatar
That looks very simple to do, what type bags are using.
Anybody can restore a classic, takes a man to cut one up.....
http://www.arnoldscustoms.com
38chevyhotrod is offline   Reply With Quote
Old 07-05-2009, 09:32 PM   #212
19723DR
19723DR's Avatar
Aww come on, I spent all that time making those brackets for nothing? Thanks, I'm glad you're watching out for me.
Next week I'm going out to my father-in-laws shop to make some 1'' blocks. That should put me on the bump stops.
It took about 3 hours to make and install the brackets and a lot of that was waiting for paint to dry. My bags are Firestone 2600 front and rear.
97 Z71 3 Door
Old 07-05-2009, 11:06 PM   #213
Frizzle Fry
You'll be golden then. I just honestly don't see the need for the brackets. Unless you simply want to avoid more holes in the frame. Here's a thread that shows it done bracketless. Nice job on the brackets anyway.
Old 07-19-2009, 10:47 PM   #214
19723DR
19723DR's Avatar
Yeah you're right. The time and money spent on blocks and u-bolts would be worth it alone. Thank you for the link, I will probably end up doing that.
97 Z71 3 Door
Old 10-18-2009, 09:44 PM   #215
Slick67
Sofa King Crazy!!
Slick67's Avatar
Yep....these Burbs are making me drool. I want one! You did a great job with it! Love the panels you made, guess I gotta do mine custom now.......you're making more work for me. Oh yeah...it's good to see some other artwork out there, you got talent!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 10-18-2009, 10:16 PM   #216
19723DR
19723DR's Avatar
Well when the old panels are warn out and the new one are 500 bucks you'd make your own too. Dude your truck is going to rock. I'll have to take picures of the rest of my art work.
97 Z71 3 Door
Old 10-18-2009, 10:37 PM   #217
19723DR
19723DR's Avatar
Well since you brought this to the top, I might as well share the pictures from a car show me and my family attended a few weeks ago, it was a blast. The wheels are off my Cheyenne they are 18/20 MB Old schools with 245/45/18 275/4520. I really like those wheels. Hope you enjoy them.
97 Z71 3 Door
Old 10-19-2009, 08:17 AM   #218
babyblueoval
I like the wheels.
Truck still looks good too. lol
How is that carrier bearing holding up?
Jim
Old 10-19-2009, 06:01 PM   #219
Frizzle Fry
Still looks super-nice. Those wheels work on there too.
Old 10-19-2009, 07:33 PM   #220
19723DR
19723DR's Avatar
I like the wheels.
Thanks Jim. They ride 10X better, very smooth. Carrier bearing; there's no clunk when I take off, I guess its holding up.
Thanks Mike. I'm thinking of selling the wagon wheels and buying another set of MB's. If they start making a 20X10 I'm going for it.
97 Z71 3 Door
Old 10-20-2009, 01:03 AM   #221
kyull67
kyull67's Avatar
Those wheels look great!
kyull67 is offline   Reply With Quote
Old 11-15-2009, 11:37 PM   #222
r1lorenzini
Wow one of the best build threads ever. I actually read every page (im a geek about to get a burb) anyhow one of my favorite things is your kids growing up through the pics very funny. Your daughter by the wheel then way older in the car. Awsome .sweet truck! Showa how long it takes to do it right!
r1lorenzini is offline   Reply With Quote
Old 11-16-2009, 09:11 PM   #223
19723DR
19723DR's Avatar
Thanks kyull. Sorry for the delay. Congrats on the magazine.
Originally Posted by r1lorenzini View Post
Wow one of the best build threads ever. I actually read every page (im a geek about to get a burb) anyhow one of my favorite things is your kids growing up through the pics very funny. Your daughter by the wheel then way older in the car. Awesome .sweet truck! Showa how long it takes to do it right!
Thanks. I've enjoyed working on my Suburban for the last three years. I still have a few more things to complete before it's finished. That is my youngest, she loves to steal the scene.
Good luck with your suburban purchase. Maybe you should start your own build thread. Remember, if you need any advice, it's always free!
97 Z71 3 Door
Old 01-05-2010, 03:58 PM   #224
yawdie1
yawdie1's Avatar
You are very talented! I like that fact that you did all the work yourself. The burb kicks ass! I like it alot.
1950 chevy PU work in progress.
yawdie1 is offline   Reply With Quote
Old 01-07-2010, 12:27 AM   #225
19723DR
19723DR's Avatar
Thanks. How else can I learn all this stuff but to do it on my own? Plus I'm too cheap to pay somebody. But now, it's put away for the winter.
I noticed that you have a build starting, I'll have to check it out.
97 Z71 3 Door
