01-14-2010, 09:43 PM | #201 |
Re: Project: Agent Orange
I was hoping you were talking about a dirt bike, not a jeep or a ford.
01-14-2010, 10:25 PM | #202 | |
that rink is very cool...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
01-17-2010, 07:15 PM | #203 |
Okay, got the heep done enough to kick it out of the K5 space.
Time to get somethin' done! Took some passenger side header pics while I was out there today, the headers fit the frame well but look to be uber tight exiting towards the bell housing. |
01-21-2010, 10:54 PM | #204 |
"something witty here"
why cant I find those headers for sale anywhere? I went to see if the headers I had would fit and passenger hits the tranny, so Ill be needing a new set, and I remembered these looking good. do you know anywhere that sells them?
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
01-22-2010, 06:59 AM | #205 |
01-22-2010, 09:29 AM | #206 |
GEARHEAD
Can you get a ratchet on all of the spark plugs? Looks like #6 might be tight.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
01-22-2010, 12:41 PM | #207 |
thanks man you are my savior!
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 Last edited by Wildstreak; 01-22-2010 at 12:42 PM. |
01-22-2010, 04:14 PM | #208 | |
They're always tight... The bigger question in my mind is, "will it burn the plug wires" Had a set on the blue one that were literally impossible to stop from burning through and arcing out. |
01-22-2010, 04:30 PM | #209 |
GEARHEAD
Just curious because I was looking at those for my C-10. They have shorty plugs available but want to avoid that if I can.
01-22-2010, 04:41 PM | #210 |
would those spark plug wire kevlar boots help prevent burning?
01-22-2010, 04:48 PM | #211 | |
I spent big money with a company called 'Live Wire' for wires that are "gauranted" not to burn...yep they burt. I used those boots on my blue blazer with the 2.5" rams and after time, even the center two would burn through. I just saw an add where Accel is making some with ceramic ends, I think I'll be looking into a set of those. |
01-22-2010, 05:28 PM | #212 |
just checked out the accel set you were talking about, theyre around 150 a set. I would need the 90 degree ends for those headers right?
01-22-2010, 05:59 PM | #213 |
GEARHEAD
If the ceramic boots are hard, they might not have the flexibility needed to fit over the end of the plug when you put them in. I'll let someone else spend the $150 to find out.
01-22-2010, 07:31 PM | #214 |
01-22-2010, 07:39 PM | #215 |
from summit, pretty much the only place other than jegs or mopac I order fromhttp://www.summitracing.com/parts/ACC-9001C/
01-22-2010, 09:06 PM | #216 |
Maybe we should share a pic.
Thanks for the link. |
01-25-2010, 07:43 PM | #217 |
One more question on the headers. How does the shift linkage from the column to tranny clearance look? are the headers interfering?
01-25-2010, 09:21 PM | #218 |
01-25-2010, 09:51 PM | #219 |
well Im ordering a flaming river column tilt too and have a 700r4 as well so i was just worried about the linkage. Ive never hard of the cable shift before I was just going to order the lokar linkage. ill have to take a look into these cable shift.
01-26-2010, 01:29 AM | #220 |
The headers run pretty close to the firewall. What is the temperature rating of the lizard skin? Will it withstand the heat in the engine compartment without cracking, shrinking, or burning? I've never seen it used in that area.
01-26-2010, 07:49 AM | #221 | ||
As for the cable shift, I got it through Summit and it's made by Lokar. Note that this is not what I'm using this time, the pic is from the blue blazer which had a factory column. Quote:
The Lizard Skin is a two part application with the 1st layer being a sound control and the 2nd being heat protection. Taken right off of the container stating what it will do: *Reduce engine and solar heat transfer by 25-30 degrees or more *Reduce noise by as much as 10-12 decibels *Protect sufaces from moisture and corrosion *Withstand temperatures to 500 degrees F (260 C) *Class 'A' fire rated, does not support combustion The stuff is made for 'exactly' this application. Last edited by vtblazer; 01-26-2010 at 08:06 AM. |
01-26-2010, 02:19 PM | #222 |
New Member
Here's a set I have with 90 degree ceramic ends. I believe these are made by Taylor. Might be cheaper than the Accels.
01-26-2010, 02:47 PM | #223 | |
Future TOTM Winner
Your engines looking good, always loved those valve covers.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
02-18-2010, 12:33 PM | #225 | |
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
