Old 03-25-2014, 08:38 PM   #201
SCOTI
SCOTI's Avatar
Re: Project Old Blue, 1965 C10, Rebuild Version 2010
Originally Posted by aggie91 View Post
I did find a complete rear end housing with trailing arms and stock springs and all the retainers and bolts for $100 bucks from a guy in Hurst. We picked it up on Sat. on our way back home. I got the housing all stripped down minus taking out the pinion on Sunday. I will try to post some pictures in the next day or two. One brake drum was completely worn through! it came off in two pieces...
Put me 1st in line for the old 9" housing.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-26-2014, 10:15 AM   #202
aggie91
I'm just glad to be here!
aggie91's Avatar
Originally Posted by NEWFISHER View Post
You are going to be a very busy boy!
What rear gears do you have now?
It does not look like I will even touch the truck until the first weekend in May. We have plans for every weekend from now till then. I won't work on it everyday, but I will get things done in an order that I set. I will get specific things done each time I work on it. I will plan my time I spend on the truck to allow for getting that task complete.
The gears depend on what rear end we are talking about...
The 12 bolt I just scored has 3:73 with an open carrier. Even though I said I would put in 4:10 gears, I might still be on the fence about it. Either way, I still need to reprogram the PCM.
Thanks for checking in!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-26-2014, 10:16 AM   #203
aggie91
aggie91's Avatar
OK
You planning on going over to Pate Swap Meet this year? I am going for Saturday for sure, but might try to make it Friday-Sunday if the wife lets me..
Karl
The LST Challenge:
Old 03-26-2014, 12:30 PM   #204
SCOTI
SCOTI's Avatar
OK
I'd like to. My dually isn't cooperating & it's a priority. I really need to get it up & going so I can move forward on my 64 & get the chassis back to my place.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-02-2015, 02:55 PM   #205
scanman
scanman's Avatar
heater duct pics: cable connects to pull knob? i do have another cable not pictured. will send.
scanman is offline   Reply With Quote
Old 04-27-2015, 12:07 PM   #206
aggie91
aggie91's Avatar
Figured I would give this old thread a bit of life. Finally moved the truck to my house from the storage lot last month. Did not realy do anything yet to it, but the lot needed it moved so that they could put up 2 more large RV storage covers. They where not charging me for the space, so I did not have a reason to not bring it home.
In hopes to getting back to this truck this year, I started a little dirt work at the house for a shop this weekend. I have been wanting to do this for a long time, it is now time to do it.
First step is to get the pad done, but to do that, I need to level some of the area for the shop. Korbin's buddy Drew came over with his tractor and we started moving some dirt. It was a little wet in some areas, but we did get a good start. I did not get a pic of where we stopped yesterday, but I will when I get home today.
Staked out the area of where the shop would go:
Started moving dirt from the high spot to the low spot:
Where the tractor is in the picture above, is what will be the drive from the front along the side of the house that will be parallel to the shop and will serve as a place to part the boat. That will also work to help drain storm water around and behind the shop.
Progress will be slow, it rained again last night and is still raining off and on today. Tomorrow has a 50% chance of more rain, but the rest of the week looks good, so hopefully it can dry out and we can get back at it in about a week. For every 1/2"-3/4" of rain, I need 2-3 days of sun and wind to dry it out...
Karl
The LST Challenge:
Old 04-27-2015, 01:14 PM   #207
1963c-10
1963c-10's Avatar
Nice progress. Reminds me to get back out on mine as well.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-02-2015, 08:18 PM   #208
Gary V
Active Member
Gary V's Avatar
Great work Karl! Good luck with the shop. Subscribed
Best regards,
Gary
DOMERINGER BUILD
Gary V is offline   Reply With Quote
Old 05-04-2015, 10:16 PM   #209
tune_1
If we can't watch work on a vehicle then the next thing is watching work on a shop. Hope you are able to make progress on the new building.
Dwight
tune_1 is offline   Reply With Quote
Old 05-05-2015, 03:45 PM   #210
aggie91
aggie91's Avatar
Thanks Guys!
Well it has not rained for 6 days and it has dried out enough to continue working on the pad. My tractor guy is at the house today working on it. We plan to get about 12 yards of dirt for the first layer of the pad in the morning. We will see how it goes. There is a 40% chance of rain tonight and tomorrow...
Karl
The LST Challenge:
Old 05-12-2015, 09:34 AM   #211
aggie91
aggie91's Avatar
We have made some progress, but not significant. It has been raining a lot around here and keeping too wet to do any dirt work.
I took these pics yesterday evening. It rained about 2" at my house Sunday night. Looks like it drained well around the pad and only a little standing water on the pad area. Today there is a 60% chance of rain, and there is rain in the forecast (50%-80% chance) every day until the 20th. For every 3/4" of rain, I need 2 days of sunny weather to dry it out enough to work the soil for the pad. Even if it does not rain at all, it will be the 21st before I could really get any work done on the pad. At this rate, I will be well into June before they even get to start the building...
This is from the road looking down the side of the house to the back yard...
Looking from the corner of the house toward the whole pad...
Karl
The LST Challenge:
Old 05-12-2015, 05:53 PM   #212
smbrouss70
smbrouss70's Avatar
I'm further South and East of you, but I feel your pain. I put a deposit on my shop in January, and they still can't start the dirt work yet, because of the water in my yard.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 05-20-2015, 04:35 PM   #213
aggie91
aggie91's Avatar
Had more dirt delivered yesterday. He got over today and moved it to the back and started spreading it out. Once I get home, I'll look it over and get a few pictures for you guys. I will see if we need more dirt before moving forward...
Karl
The LST Challenge:
Old 07-13-2015, 11:51 AM   #214
aggie91
aggie91's Avatar
Well after a very long wait, I got the call that they are ready to start my shop last week. Unfortunately, I was on vacation...
Last night I called him, set up a time to meet him this morning. Last night I marked the one side wall of where I wanted the shop on the pad and pulled a string line for reference. Here is what it looked like last night before I went to bed:
Karl
The LST Challenge:
Old 07-13-2015, 11:59 AM   #215
aggie91
aggie91's Avatar
Met the Framing Crew this morning about 9am. Spent a few minutes discussing with them where I wanted the shop and showed them the string line to use as a reference.
By 9:30am here is where they were at:
They have a crew of 6, the guy in the white T shirt and straw hat is Matt, he is the lead for the crew, its him, his son and 4 other guys. He use to frame houses and now only does these pole barns for Ark-La-Tex builders. He said I should be surprised when I get home today. By the time I left at 9:45am today, they were setting the second corner post. They are not messing around.
Karl
The LST Challenge:
Old 07-13-2015, 04:46 PM   #216
C@rnut001
It is great to see you finally getting your shop! Please keep updating on how it is going. Looks like they will be putting it up quickly.
C@rnut001 is offline   Reply With Quote
Old 07-13-2015, 05:15 PM   #217
aggie91
aggie91's Avatar
At 2:30, my son sent me this pic...
I'm heading home in about 45 minutes, can't wait to see what it looks like!
Karl
The LST Challenge:
Old 07-13-2015, 05:59 PM   #218
C@rnut001
Wow, they are not wasting time. That is so awesome. Keep the updates coming.
Old 07-14-2015, 10:54 AM   #219
aggie91
aggie91's Avatar
Got home last night and the framing was complete. Only one or two issues with the framing, mostly the lower skirt board that will be used as a form for the concrete. Some are bowed out a good bit, but not bad. They could be moved back in place with some stakes along the outside and pinned to the concrete when it is poured.
Here is a pic of the finished framing:
My two youngest kids thinks its a jungle gym to climb on...
I did start on locating the extra footings for the future install of the lift. I marked out areas with string and will use the string as a reference for the depth. It got late and dark, so no pictures today. I will take a few tonight when I did them out...
Karl
The LST Challenge:
Old 07-19-2015, 02:40 PM   #220
McMurphy
McMurphy's Avatar
I am jealous !
Am talking with contractors now to build me a 30 by 60 three bay, with a half loft office up stairs.
I swear I will lose my mind if I have to search in the dirt one more time for a dropped bolt or screw....
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 07-20-2015, 09:11 AM   #221
aggie91
aggie91's Avatar
Thanks for checking in McMurphy. I really enjoyed reading about your travels from Alaska to you new home. What an adventure!
Well this project (like all of my projects...lol) has stalled. The concrete is next, but I am about 3-4 weeks down the list. So in the mean time, I plan on getting my footings lined out and then maybe concentrate on what I want to do with the driveway back to the shop. I have a bunch of options, but my budget is tight for that this year. I am leaning towards laying down some crushed concrete and rolling that smooth.
Stay tuned!
Karl
The LST Challenge:
Old 07-20-2015, 10:36 AM   #222
smbrouss70
smbrouss70's Avatar
I am jealous of your progress on the shop. My yard has finally dried up, but I still have to bury some conduit for power and put down some big rock for a driveway before I can have the trucks start hauling in dirt.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 07-21-2015, 09:11 AM   #223
aggie91
aggie91's Avatar
I am waiting on the shop to be completed by the contractor before doing my electrical. I have about a 60-75' run I will have to make from the panel for the house to the shop.
I started looking at lighting and how bright I want it to be. Man, there is a lot of info on the web for how much light to use for a given task. I will be shooting for about 60-75 foot candles of light in the shop once it is all said and done. My plan is to start with 4, 8 foot fixtures that use 4 32-watt T8 bulbs. Most likely I will use the 6500K color bulbs.
Karl
The LST Challenge:
Old 07-22-2015, 03:25 PM   #224
dantimdad
dantimdad's Avatar
I would definitely use daylight bulbs. Have you considered LED? I am going to DIY my own LED setup when I get a new shop. It's cheap, bright and doesn't use nearly as much electricity as other types of lighting.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline   Reply With Quote
Old 07-23-2015, 12:20 PM   #225
barnold
barnold's Avatar
Take a look at the new lights that Big Ass Fans have they are really impressive.
72 Blazer
69 Stepper (sold)
72 Burb
barnold is offline   Reply With Quote
1965, c10, old blue
