Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 12-13-2012, 12:16 AM   #1
Captainfab
60-66 Nut
Re: D52 Caliper Rear Disc Brake Brackets
Yes the Eldorado rotors could have been used when designing these brackets, but I was wanting to use a rotor that could be found in a wrecking yard. The Astro/Safari vans are fairly plentiful in the wrecking yards. The '76-'79 Eldorado's are not. I know that new rotors are not that expensive, but sometimes a guy needs to be resourceful. Also the long term availability of the Eldorado rotors may be hard to predict. The Astro/Safari rotors are slightly larger in diameter than the Eldorado rotors.
The Eldorado master cylinder should work just fine with most GM boosters. If you happen to find an Eldorado in a wrecking yard, grab the proportioning valve also.
Originally Posted by 1972BackInBlackC10 View Post
just out of curiosity i dont know anything about the cadillacs but if the rear calipers work would the rotors not work as well since they should be the same thickness as the astro rotors or would there be a back space issue since its a car? what about the master cylinder as well since it should be a disc/disc setup
sorry not trying to pick your brain just trying to see if theres more options
Old 12-13-2012, 09:32 PM   #2
Greywolf200
I picked up all the Eldo parts at PullAPart but have been holding off because I want to retain my 6-bolt pattern. A bore and sleeve at White Horse and they'll be better than new.
Jack Byrd
'70 Chev Custom SWB(new to me), 307CID(added Weiand Stealth, headers and Edelbrock Performer carb, up to 17 MPG now), 700R4
'76 Airstream Argosy MH(want a longer one), 454CID, TH400
Greywolf200 is offline   Reply With Quote
Old 12-14-2012, 04:35 PM   #3
True 67
captanifab,
Are these still avalaiable?
True
True 67 is offline   Reply With Quote
Old 12-14-2012, 11:34 PM   #4
Captainfab
60-66 Nut
Yes they are......in fact I just got another order of laser and plasma cut parts for them earlier this week.
Originally Posted by True 67 View Post
captanifab,
True
Old 12-15-2012, 11:45 PM   #5
Captainfab
60-66 Nut
I received your payment today. I will get those shipped out on Monday.
You do realize that the D52's are the only caliper that will bolt up to these brackets, right?
Originally Posted by MJs69CST View Post
Good morning Captain. I am going to place an order this morning for the Astro brackets--I will be using the D52 calipers eventually.
Thanks.
Old 12-15-2012, 06:52 PM   #6
gringoloco
A guy with a truck
gringoloco's Avatar
Was there ever a solution to the pad rubbing the rotor hat issue? Mine are scoring pretty hard...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-15-2012, 11:51 PM   #7
Captainfab
60-66 Nut
I have not had that issue with what I have mocked up here. One other customer has had that issue, but he has not gotten back to me with the measurement I need to determine what needs to be done to correct the situation. I don't want to just move the caliper out farther, and have the pads hanging past the outer edge of the rotor, if I don't have to. I just need someone to help me out with the measurement I need.
Old 12-15-2012, 11:52 PM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
Let me know what you need and I'll try to get it for you
Old 12-16-2012, 12:54 AM   #9
Captainfab
60-66 Nut
I don't have a pic of the dimension I need, on this computer. I will get it from my shop computer tomorrow and post it here.
Old 12-17-2012, 12:14 AM   #10
Captainfab
60-66 Nut
Here is a pic showing the dimension I need from those that have had a brake pad to rotor hat interference issue. Once I know what you have I can make the necessary change, and get you a set of brackets to correct the issue.
Old 12-17-2012, 02:46 PM   #11
gringoloco
A guy with a truck
gringoloco's Avatar
You need the 3.5182 distance? I'll see what I can do this eve...
-Chris
Old 12-18-2012, 12:29 AM   #12
Captainfab
60-66 Nut
Yes, that is the measurement I need. Yours may or may not measure 3.5182. Once I know what yours measures, I can have a set made that will solve the pad rubbing issue.
Old 12-21-2012, 01:58 AM   #13
Captainfab
60-66 Nut
Thanks for the purchase, and the compliment
Brackets arrived! Quality stuff. Thanks Capt!
Old 01-02-2013, 07:47 PM   #14
Hazieview
Building Dreams out of Dimes!
Question Re: D52 Caliper Rear Disc Brake Brackets
Will these parts work with the D52 brackets? Just checking before I order them.
ROTORS:
http://www.summitracing.com/parts/eb...ro?prefilter=1
CALIPERS with ebrake:
http://www.summitracing.com/parts/aa...model/eldorado
I know i will have to get one for the passenger side and one for the driver side but I wanted to make sure I had the right ones.
Thanks guys!
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 01-03-2013, 12:37 AM   #15
Captainfab
60-66 Nut
Those look like the right parts......
Old 01-29-2013, 09:01 PM   #16
Hazieview
Old 01-29-2013, 09:05 PM   #17
Hazieview
Got me some astro van rotors but they are way to thick for my Eldo calipers. Has anyone had this problem?
Old 01-30-2013, 12:18 AM   #18
Captainfab
60-66 Nut
Do you have the '76-'78 calipers? Which pads do you have?
Old 01-30-2013, 06:30 PM   #19
Hazieview
Yes I have the 76-78 calipers and I got Wearever silver brake pads. MFG NAD 122
Duralast Rotors
Bolt Pattern Diameter (mm): 127
Rotor Bore Diameter (mm): 78.5
Rotor Initial Thickness (mm): 32.70
Rotor Outside Diameter (mm): 295
Rotor Overall Depth (mm): 83
Wearever Silver Brake Pads - Rear
Friction Material Thickness, Inner Pad: 0.4 in
Friction Material Thickness, Outer Pad: 0.43 in
Front or Rear Brakes: Rear
Fenco Disc Brake Caliper, Rear Right & Left
I can not figure it out. I mean the rotors will NOT fit in the calipers with the brake pads installed....? The rotors are like .25 in too big..?
Old 01-30-2013, 11:47 PM   #20
Captainfab
60-66 Nut
Did you check to see if the shaft is rotated as to engage the parking brake function of the caliper. If not you might try turning the shaft coming out of the back of the caliper. A box end wrench or a deep socket should work to grab it. I just don't remember what size off hand.
Old 01-31-2013, 07:00 PM   #21
Hazieview
The parking brake is not engaged. The caliper piston is all the way back. The rotor will not fit with the brake pads installed. My rotors are 1.29" thick. Have you ever heard of this issue before? What is the inside width of your calipers and how thick are the brake pads you are using?
Old 02-03-2013, 06:54 PM   #22
Hazieview
Old 02-04-2013, 12:41 AM   #23
Captainfab
60-66 Nut
I checked out the D52 pads today and the Astro rotor fits with those pads also. It is a little tighter, but they do work.
I'm not sure what is going on with your calipers and pads Hazieview.
Old 02-04-2013, 07:43 AM   #24
Hazieview
Do you have a part number for the D52 AND THE D122 pads you purchased? I will just go buy the exact same ones and hope for the best.
Old 02-05-2013, 01:08 AM   #25
Captainfab
60-66 Nut
I bought both sets of pads from O'Reilly's. The Brake Best part numbers are MKD52 and D122
