Old 06-14-2011, 07:37 PM   #201
robnolimit
robnolimit's Avatar
Re: Bolt in steering rack
You can see the upper shaft connecting to the column and top u-joint.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 06-14-2011, 07:38 PM   #202
robnolimit
robnolimit's Avatar
Using factory G.M. lines, we plumbed the power steering hoses.
Old 06-14-2011, 07:42 PM   #203
rob32472
Rob, any ideas for a bushing or something on the top side of the frame? Could the bearing be turned over with a spacer so that it is flush with the frame on the top? Maybe it is just me but it looks a little unfinished as it is..... not to mention a great place for trash to settle... give me your thoughts..
rob32472 is offline   Reply With Quote
Old 06-15-2011, 09:20 AM   #204
FeNiX
FeNiX's Avatar
Originally Posted by robnolimit View Post
Next is the spindle modification. Using a 5/8 drill bit, drill out the tie-rod mounting hole. Start from the top side. Try to drill it straight down through the original hole.
Is this safe? What hapens to the the cone shape hole?
FeNiX is offline   Reply With Quote
Old 06-15-2011, 09:43 AM   #205
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
you're changing the tie rod end type too....so its fine.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-15-2011, 09:53 AM   #206
Scot_Douglas
Scot_Douglas's Avatar
I think Rob's a little light with his pictures on the install in this thread; I think after he drills out the steering arm with a 5/8" drill - he then reams it to the proper size / taper for his kit.
i.e. - when you use a MII or Ford R&P and associated tierod ends - they have a different taper than our trucks do. Not saying this is a MII rack - I'm just expounding on what my research on racks learned me.
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 06-15-2011, 10:03 AM   #207
lolife99
67-72 parts collector,…
lolife99's Avatar
great work.
Keith
Convert to disc brakes.
Old 06-15-2011, 10:48 AM   #208
gringoloco
A guy with a truck
gringoloco's Avatar
You can see the tie-rod hanging loosely on the spindle in this pic. It looks like a through-bolt with misalignment spacers not unlike the modification required for the Dropmember...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-15-2011, 11:27 AM   #209
robnolimit
robnolimit's Avatar
Turning the bearing over is a no-go. It would raise the second U-joint and cause a bind in the steering angles. I'm sure you could use a cut section of a shock boot to cover the opening. We all thought it looked nice and clean, having the shaft go through the frame with the bearing under it.
Old 06-15-2011, 11:29 AM   #210
robnolimit
robnolimit's Avatar
Easy now, were not done yet. spindle mods and tie rod ends, and alignment are the last bit to go. We will be using a High-Misalignment rod end, so there is no re-tapering of the spindle.
Old 06-15-2011, 12:54 PM   #211
Scot_Douglas
Whoa. Good eye!
1966 C10
Build 'Fread
Old 06-20-2011, 02:43 PM   #212
robnolimit
robnolimit's Avatar
Here's the last steps. We finally recieved the adjuster sleeves today! The hex shock is threaded with 5/8" x 18 on one side, and 14mm x 1.5 on the other. We then had them heat treated. Tie rod ends are high-mis-alignment 5/8" chromoly.
Old 06-20-2011, 02:46 PM   #213
robnolimit
robnolimit's Avatar
Start by removing the spring clamps on the rack boots
Old 06-20-2011, 02:47 PM   #214
robnolimit
robnolimit's Avatar
Thread the rod end into the adjuster sleeve. Leave approx 1/4" of thread showing, tighten the jam nut - TIGHT!
Old 06-20-2011, 02:52 PM   #215
robnolimit
robnolimit's Avatar
** Thread the adjuster sleeve onto the inner tie-rod end. Leave approx 1" of thread showing. Leave the JAM NUT Loose
Old 06-20-2011, 02:55 PM   #216
robnolimit
robnolimit's Avatar
Bolt the new tie-rod assembly to the bottom of the steering arm. The large U.S.S. washer installs on the bottom, as a saftey stop for the rod end.
Old 06-20-2011, 02:57 PM   #217
robnolimit
robnolimit's Avatar
The Complete Install. Toe adjustment is made between the inner tie-rod end and the adjuster sleeve. Don't forget to put the spring clamp back on for the rack boot. For smooth cruisers, set toe at - 1/8" . For more spirited driving, try 1/8" toe out.
Old 06-20-2011, 03:17 PM   #218
ebfabman
Any way to lube those heims? There are heims with zerks. Any reason why you're not using them? Not being negative. Just asking
ebfabman is offline   Reply With Quote
Old 06-20-2011, 03:36 PM   #219
robnolimit
robnolimit's Avatar
At this time we have'nt found a supplier with that item. - High mis-alignment, chromolly, with a grease zerk. if you know of any, let me know.
Old 06-20-2011, 03:42 PM   #220
ebfabman
Give me the size and I'll check it out right away.
Old 06-20-2011, 03:46 PM   #221
dougminton
dougminton's Avatar
post #212 said 5/8
The TEAL GMC build thread is HERE
1972 GMC SWB
454 oval ports
TH400
fastest 1/4 mile time so far
13.05 @ 104
If you think you have too much horsepower
you obviously have a traction problem !
dougminton is offline   Reply With Quote
Old 06-20-2011, 03:54 PM   #222
ebfabman
I pretty much figured 5/8ths. That's what all the racks used on all the race cars we built that used r&p. I got a call in to a supplier right now. It may be the high misalignment won't allow enough material for a zerk. It would be good to be able to keep lube on that joint with all the movement there.
Old 06-20-2011, 04:04 PM   #223
PBFAB.COM
PBFAB.COM's Avatar
Just my two cents on the greasable rod ends.... I wouldn't recommend using them due to the fact that they are MUCH weaker. The area where the rod end is drilled and tapped for the grease fitting creates a major weak spot. I have seen several rod ends fail due to this. They split and peeled right apart... wouldn't be a fun ride.
A quality rod end like the ones that Rob uses are kevlar injected and will not need to be lubricated.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 06-20-2011, 04:07 PM   #224
rob32472
Ship them out!!!!!
Old 06-20-2011, 04:38 PM   #225
tubbedII
needs more $$$
tubbedII's Avatar
I don't know how much has changed from this production version to the one in the old Joe, but will the production version still work with a pancaked crossmember?
1970 2wd Blazer
tubbedII is offline   Reply With Quote
