Old 05-01-2011, 09:45 AM   #201
oldman3
oldman3's Avatar
Re: My 50 roadster pickup build
Sorry I didn't post yesterday, friends over.
Here I have removed paint from left rear fender, ready for hammer and dolly work.
oldman3 is offline   Reply With Quote
Old 05-01-2011, 09:47 AM   #202
oldman3
oldman3's Avatar
After getting the metal close as I could. I had removed all the old crap from the inside of fenders, blasted and coated with encapsulator paint.
Old 05-01-2011, 09:49 AM   #203
oldman3
oldman3's Avatar
Pic 1 This is the fender after a little filler, primer sanding and reprimer.
Pic 2 Both rear fenders ready for paint.
Old 05-01-2011, 09:52 AM   #204
oldman3
oldman3's Avatar
Pic 1 This is the final layout of my console. Got the radio and AC control openings cut and units installed.
Pic 2 Another view.
Old 05-01-2011, 09:56 AM   #205
oldman3
oldman3's Avatar
Need to tell a little story here. I'm no different than most home builders on here, things get in our way and work on our trucks take a back set. At this point I was about 1-1/2 years into the build. The next 5 months hardly anything got done. This will happen a couple of times during my build, just wanted everyone to know, no build goes as smooth as we want. Jim
Old 05-01-2011, 10:01 AM   #206
oldman3
oldman3's Avatar
Pic 1 Here I have installed Alan Grove brackets and installed the alternator and compressor.
Pic 2 Started running AC lines and heater hoses. Spent hours trying to figure out the right layout (don't think I ever did).
Pic 3 Fabing the hard lines for the fuel system.
Pic 4 Inside view of bulk head and AC lines.
Old 05-01-2011, 10:05 AM   #207
oldman3
oldman3's Avatar
Pic 1 Starting to fab up my exhaust system, mandrel bends from J.C. Whitney.
Pic 2 For over rear axle.
Pic 3 Making up hangers and fitting to mufflers (stainless steel Borla).
Old 05-01-2011, 10:09 AM   #208
oldman3
oldman3's Avatar
Pic 1 From header back toward mufflers.
Pic 2 From mufflers to the end of pipes.
Old 05-01-2011, 10:13 AM   #209
oldman3
oldman3's Avatar
A couple years, YES YEARS later, they were taken apart. I drove to HPC in Oklahoma City, observed their parts check in system. Toured their facility and left my parts to be coated to match my headers.
Well thats today's post. Next post is on the aluminum lift off top. If I get clear I may post that later today, no promises. Jim
Old 05-01-2011, 06:40 PM   #210
flatbed51
flatbed51's Avatar
Originally Posted by oldman3 View Post
By mounting the latch in the body it allowed me to make up this manual button system for opening the doors. A hole was drilled in the cab corner, pipe welded to the hole in corner, and a threaded rod thru the pipe with a knob on the end. Push up on the knob and the door pops open. Part way up the threaded rod is a tee mounted, to this I added another rod that will stick out passed the interior panel for inside use. The top of the threaded rod is secured to the lever on the latch.
Jim, I have to see more about this install. I just got home after spending four days at Pate Swap Meet in Ft.Worth Tx. and fell fell in love with this door handle install I saw on a 51 for sale. Don
My Build Thread
51 chevy
http://67-72chevytrucks.com/vboard/s...d.php?t=437496
48,49,50 Chevy trucks. 41 Olds
flatbed51 is offline   Reply With Quote
Old 05-01-2011, 07:19 PM   #211
oldman3
oldman3's Avatar
Don't know how this one is set up, but it is neat looking. Was that whole cab chrome, or some type of chrome paint??
Old 05-01-2011, 07:34 PM   #212
flatbed51
flatbed51's Avatar
No the truck was a very very slick Black,I guess it was my camera or something caused it to look like that.
My Build Thread
51 chevy
Old 05-02-2011, 06:36 PM   #213
oldman3
oldman3's Avatar
I've been asked to give a little more detail on my door latch system. I'm not a mechanical engineer, so I'm sure there is an easier way. I have a tendency to make things more complicated that they are, so I'm sorry in advance. I would have taken pictures of the set up, but I would have to remove the interior, and that I don't want to do. As mentioned earlier this is for a manual button system.
Old 05-02-2011, 06:38 PM   #214
oldman3
oldman3's Avatar
I will break it down from the top of latch to the bottom of cab. The latch is mounted upside down so that it works as a push up (an not a pull down) latch.
Old 05-02-2011, 06:41 PM   #215
oldman3
oldman3's Avatar
Sketch 1 shows the top part that is attached to the bear claw latch arm. I welded a 1/4X20 bolt to the latch arm, then I added a 1/4X20 nut, then an eyelet fitting, another 1/4X20 nut. A 1/4X20 threaded rod also screws into the bottom of the eyelet fitting that will go thru the pipe in the cab body.
Old 05-02-2011, 06:45 PM   #216
oldman3
oldman3's Avatar
Next you will need to thread a 1/4X20 nut up on the threaded rod. Find a location for mounting a brake line holder (mine is on the exhaust tube brace). Mount that holder so the nut rest on top of holder. This will allow you to keep the latch arm in a netural position, when door is closed (see sketch 2).
Old 05-02-2011, 06:50 PM   #217
oldman3
oldman3's Avatar
Depending on where you want to mount your inside lift handle will determine how far you thread the tee fitting up on the threaded rod. The tee fitting is made out of two 1/4X20 1" long nuts (you can get this at the local bolt place). Weld one up to the face of the other to form a tee (see sketch 3 "A". Add 1/4X20 threaded rod to length and put knob on the end.
One you have a location for the threaded rod, drill a hole in the cab corner, large enough for your pipe, and weld to cab. Insert threaded rod thru the pipe, and cut to length, and add the knob (see sketch 3 "B").
Old 05-02-2011, 06:57 PM   #218
oldman3
oldman3's Avatar
Pic 1 shows my inside lift handle, near floor, easy to reach while in the seat.
Pic 2 shows the knob at the bottom of the cab corner coming thru the pipe. Push up and the door opens.
Old 05-02-2011, 06:59 PM   #219
oldman3
oldman3's Avatar
With everything in place adjust the nuts at the latch to have a little play between the eyelet, once you have everything lined up and working, put red locktite on all the nuts to keep them from moving. If anyone wants more just PM me and we will work in out.
Be back in a few for my regular daily post. Jim
Old 05-02-2011, 07:28 PM   #220
oldman3
oldman3's Avatar
Had not worked on pickup for about 4 months, helping friends with their rides, etc. Anyhow, I fabed up a wooden structure to mock up the roof. Here the wood is covered with white poster board. Gave me a good look at how the top might be.
Old 05-02-2011, 07:31 PM   #221
oldman3
oldman3's Avatar
Here are three views of the wood structure, nothing fancy, just for mockup.
Old 05-02-2011, 07:33 PM   #222
oldman3
oldman3's Avatar
Somewhere during this time I had also worked on the hood, primered and installed.
Old 05-02-2011, 07:34 PM   #223
oldman3
oldman3's Avatar
Started making up the aluminum angle across top of header.
Old 05-02-2011, 07:35 PM   #224
oldman3
oldman3's Avatar
Bent the 3/4" x 3/4" aluminum tubing to match the outside shape of cab.
Old 05-02-2011, 07:37 PM   #225
oldman3
oldman3's Avatar
Here I have bent the aluminum tubing to match the shape of main upright support.
