Old 05-09-2013, 10:44 PM   #201
Bomp
Bomp's Avatar
Re: 1965 chevy truck one piece @a time
Oh the joys of frame cleanin'
Bomp is offline   Reply With Quote
Old 05-10-2013, 09:34 PM   #202
niterider65
niterider65's Avatar
Cool Re: 1965 chevy truck one piece @a time
I must have had about 20 pounds of red river dirt on the frame
and the under side of the cab is next
niterider65 is offline   Reply With Quote
Old 05-16-2013, 09:52 PM   #203
niterider65
yes Bomp clean all the drity stuff off the frame Oh Joy
and getting extra grid tasting too
what was done sunday and to day ..
to day we played with fire you'll understand after the pics
Dang i guess i went frame off now
Old 05-16-2013, 09:56 PM   #204
niterider65
looks like the use of thr redneck jack stand
Old 05-16-2013, 10:00 PM   #205
niterider65
the joy of bushing removal but i got a new toy for them bushing
Old 05-16-2013, 10:04 PM   #206
niterider65
i told you there would be fire
and the smell of burnt rubber
Old 05-16-2013, 10:08 PM   #207
niterider65
now its time to strip the arms and get new bushings and ubolts and maybe
up grade the pan bar
Old 05-19-2013, 09:17 PM   #208
niterider65
spent little time in the shop sanding the rear trailint arms it was to dam windy to use the sand blaster over 35 mile an hour wind
Old 05-19-2013, 09:20 PM   #209
niterider65
need to order the budhings and the u bolts to put this back to together again
Old 05-26-2013, 06:20 PM   #210
niterider65
3 Days off and it starts off with three stiches just as i was starting the clean up on the frame to final sand for paint i was using a scrud busting wheel from the pic with the sanding wheel made an nice
1 inch cut or shoud said and grind out on the top of the finger you can see the glove pic . i go in to the doc to have it check in the moring and of cource i worked for couple of hours with the heaver glove i stop to get somening to drink and the bandage is soked in red and the spater trail of blood on the shop floor i guess i earned the busted knuck and bled on this project ..
Old 05-26-2013, 06:27 PM   #211
niterider65
so its wait and see if im out there tomarrow i can go right handed with the sanding the last coupe of pics is from my 1930 coupe with the ls3 brakes and strearing mounted about time to pull the body to take to the paint shop
Old 05-27-2013, 10:40 AM   #212
Bomp
Bomp's Avatar
Sorry to see your finger got the worst of it. I have one of those red cleaning wheels but have never gotten around to using it.
Now about the '68 Chevelle hanging?
Nice work so far. Don't let the finger get infected.
Old 05-27-2013, 08:04 PM   #213
niterider65
Thanks Bomper the finger sure is sore doc said looked like a scoop takin out of the finger . kinda had looked like a flame
but i cleared by the doc today it looks like its healing no problem and if i keep from bumping it on the frame censored: while sanding the tight spots
Any way here a little i did get done that i should have had done saturday .:
Old 05-27-2013, 08:15 PM   #214
niterider65
here a couple of more and what could there be paint ?
or just a test spray ...
should i paint it hot rod black or go simi gloss black
Old 05-27-2013, 08:21 PM   #215
niterider65
just a couple more
Old 05-27-2013, 10:40 PM   #216
Bomp
Bomp's Avatar
Hot rod black or go simi gloss black, both are great.
Which one I couldn't tell ya. I have to make the same decision in the future and Im still at a loss.
Good work your doin' even with a finger down.
Old 06-09-2013, 08:20 PM   #217
niterider65
spent a little time in the shop today after the morning rains washed out the
dust out of the air .. i got the truck primed and under coated this after noon the undercoating sure is messy used 4 cans so far got a little touching up to do need to let it set up ill finish it tomarrow nite.
Then ill build the roller for the cab to move it over to the paint booth.
Old 06-09-2013, 08:24 PM   #218
niterider65
couple of the frame and underside will make ready the frame this week need to build the roller box for the cab so i can move the frame back to final prime and paint so i can use the space to tear the motor down
Old 06-13-2013, 10:55 PM   #219
niterider65
just spent a little time in shop rebuilding the cradle it sat to tall
i shortend it a little and reset the cab so i can move it back and roll the frame back to paint this weekend ..
Old 06-16-2013, 06:23 PM   #220
niterider65
spent some time in the shop moving the cab and frame around .
set and removed the wheels and covered the roters up and sanded somore on the frame . but didnt get much done on fathers dad going to dinner with good ol dad
Old 07-07-2013, 10:15 PM   #221
niterider65
just a littlec update been in vegas for a couple of days and out of town for the forth. but spent a little time in the shop sandblasting parts and picked up the trailing arms from murrys had them make new sleeves for the bushing in the trailing arms and stich weld them up on both sides . also
sand blasted the small parts for the rear end and shock mounts . they will be powder coated some time this week or next . hopfully its on the rebound of putting it back to gether . theres no more to tear down ,
Old 07-07-2013, 10:19 PM   #222
niterider65
couple of more
Old 07-26-2013, 09:51 PM   #223
niterider65
I guess i need to add this one to the fire .. one more project A 1950-52
international pick up 6cyl 4 spd
ill let the pictures tell the story the best part it was FREE its got some rust But this thing gott some metal to work with and its got the original 90 hp motor @ 3600 RPM !!!! not a speed demon but it got torq ! just not sure about the duel rear tires
but hay like i said it was free all i had to do was pick it up
Old 07-26-2013, 09:59 PM   #224
niterider65
ok pics won't load up size wont go
are we haviing issues
Old 07-26-2013, 10:31 PM   #225
Ta2Don
Ta2Don's Avatar
Site is changing servers, not sure how long the pic upload feature will be inop...
This is what Budman56 posted on another thread...
I dont know why they didnt tell everyone that this was going on, but here is the link and I posted a little explanation on how to shrink your photo with a program that is free and easy to use.
http://67-72chevytrucks.com/vboard/s...d.php?t=589138
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
