Old 04-06-2013, 10:37 PM   #201
king-918
king-918's Avatar
Re: project 86
Big thanks to "Scoti" he help get me one step closer to a chassis
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 04-12-2013, 11:34 PM   #202
luifer76
luifer76's Avatar
Re: project 86
right on bro this thing is gonna look sweet....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 05-04-2013, 04:37 PM   #203
cmyc5575
Re: project 86
any updates?
cmyc5575 is offline   Reply With Quote
Old 05-07-2013, 01:04 AM   #204
king-918
king-918's Avatar
Re: project 86
Originally Posted by cmyc5575 View Post
any updates?
Ordered some Michigan metal works upper control arm, going to buy a stock set of lowers for now; cash is running low. need a rolling chassis for paint then on to building the trans and rear end
<----Christopher
Oklahoma
Old 05-07-2013, 08:24 PM   #205
cmyc5575
Re: project 86
What was wrong with the one you had?
Old 05-08-2013, 12:34 AM   #206
king-918
king-918's Avatar
Re: project 86
OLD and stock, plus a pain in the bum to rebuild
<----Christopher
Oklahoma
Old 05-08-2013, 12:47 AM   #207
maxxxy
maxxxy's Avatar
Re: project 86
Hopefully you ordered some upper "dodger" arms from MMW, because I think with the Sectioned crossmember they're required. Keep up the progress!
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 05-08-2013, 05:12 PM   #208
cmyc5575
Re: project 86
Oh man, I thought you had the one painted up and all.
Old 05-15-2013, 01:37 AM   #209
king-918
king-918's Avatar
Re: project 86
Not just yet, but I am back working on it
<----Christopher
Oklahoma
Old 05-15-2013, 09:58 AM   #210
67c10rustbuket
67c10rustbuket's Avatar
Re: project 86
Lookin' good buddy, I like the sectioned cross member. I saw a thread on those MMW arms they are slick. I am curious to see if it lays all the way out with stock steering shaft. Did you get the "Dodger" upper arms?
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 05-19-2013, 08:36 PM   #211
king-918
king-918's Avatar
Re: project 86
Yep just waiting on the mail
<----Christopher
Oklahoma
Old 05-21-2013, 12:50 AM   #212
king-918
king-918's Avatar
Re: project 86
Starting back up in between the tornadoes and all. Received my rotors, replaced my body mounts but I need bolts, and hopefully my control arms will be in soon
<----Christopher
Oklahoma
Old 05-22-2013, 07:40 PM   #213
cmyc5575
Re: project 86
Did these new mounts straighen up the truck lines for ya?
Old 05-22-2013, 09:57 PM   #214
king-918
king-918's Avatar
Re: project 86
SHOULD but will not know until later down the road
<----Christopher
Oklahoma
Old 05-24-2013, 10:51 PM   #215
cubber
Re: project 86
I like it, man! I'm in.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 05-25-2013, 02:55 AM   #216
king-918
king-918's Avatar
Re: project 86
<----Christopher
Oklahoma
Old 05-29-2013, 09:51 PM   #217
SCOTI
SCOTI's Avatar
Re: project 86
For what it's worth, MMW builds the Dodger arms to clear the shaft on 'stock' located x-members when trying to lay out. They would not say their Dodger series arms would benefit or clear in a raised x-member application. Looking @ where the arm 'dodges' the shaft, it's hard to say w/o having everything assembled.
That being said, the standard flat c-10 arms should provide the clearance necessary for lowered trucks using raised x-members (those not trying to lay out) & be cheaper/cleaner vs using u-joints.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-13-2013, 01:20 AM   #218
king-918
king-918's Avatar
Re: project 86
Thanks again, as for the dodger arms we will find out
<----Christopher
Oklahoma
Old 06-13-2013, 08:40 AM   #219
SCOTI
SCOTI's Avatar
Re: project 86
Unfortunately, they didn't work for me. The bushing barrel OD was the object that now came too close to the steering shaft. I wound up notching my upper a-arm for the required clearance.
The MMW arms are nice pieces though. Let me know if you run into a similar issue. Not sure since my app is a C30....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-22-2013, 08:20 PM   #220
king-918
king-918's Avatar
Re: project 86
Some people have asked me how is the truck coming so I figured I would let you guys know what I have been doing. Stopped working on the truck to help a friend. Now that's when it got interesting. I received a 2003 rav4 with the engine and transmission in the trunk. The engine was seized number 4 cylinder was welded to the block and the oil passages was sludge. Ordered parts and took the engine to the machine shop, got every thing back built the engine in the garage then installed in the suv in the drive way on good days
<----Christopher
Oklahoma
Old 06-22-2013, 08:30 PM   #221
king-918
king-918's Avatar
Re: project 86
Did all that just to find out the head was still warped and leaking oil at the deck soo another 10+ labor
https://www.youtube.com/watch?v=Q0GK...e_gdata_player
<----Christopher
Oklahoma
Old 06-22-2013, 08:38 PM   #222
cmyc5575
Re: project 86
Dang!!!
Old 06-22-2013, 08:43 PM   #223
king-918
king-918's Avatar
Re: project 86
Now got the head back from the machine shop for the second time tried to hurry and get this thing together and get it out my yard to only make a rookie mistake forget to securely tighten the exhaust cam sprocket jumped time on the second start and bent values 2 to be exact. Time to buy more parts and rebuild the head 10 + hours of labor again
<----Christopher
Oklahoma
Old 06-22-2013, 08:56 PM   #224
king-918
king-918's Avatar
Re: project 86
So keep in mind the truck was given to my friend but the previous owner tried to rebuild and did not know what the hell they was doing so I had to rebuild the engine and reassemble the complete front end and harnesses. So third times a charm rebuilt the head installed run like a champ
https://www.youtube.com/watch?v=tVUy...e_gdata_player
topped off all the fluids cleaned the vehicle up, time to test drive!
<----Christopher
Oklahoma
Old 06-22-2013, 09:05 PM   #225
king-918
king-918's Avatar
Re: project 86
Test driving a car neither one of us had ever seen run is a move we both regret. While driving the transmission would drop 1st and harsh shift into 2nd "now f#ck me sideways". I had a clue what it was but hoped this was not the case. This series of rav4 is notorious for the ecm to take a dump and take the transmission with it. There's a TSB for it too. My friend decided to sell the vehicle, made a profit on his end so I learned a great lesson and he got paid
<----Christopher
Oklahoma
