Old 01-19-2015, 02:05 AM   #201
Captainfab
60-66 Nut
Re: LVPhotos 1962 Build
Looks like everything is coming together quite well
Will you be able to use the same clutch slave cylinder with the TKO 600? If not you may need a different clutch master cylinder.
Old 01-19-2015, 10:55 AM   #202
LVPhotos
LVPhotos's Avatar
According to guys at Fig Speed here in town it's a direct replacement for my 26 spline t5. Little longer and that's why I might as well do it now while I have to make another driveshaft.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 01-19-2015, 01:23 PM   #203
LVPhotos
LVPhotos's Avatar
Daylight. Motivation Mondays!
Old 01-19-2015, 07:32 PM   #204
LVPhotos
LVPhotos's Avatar
Apparently this is ride height! 5 inch at cab mount.
Old 01-19-2015, 07:47 PM   #205
duallyjams
duallyjams's Avatar
just dig n all the front pics of the cool 62 grill
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-19-2015, 08:52 PM   #206
LVPhotos
LVPhotos's Avatar
One more!
Old 01-20-2015, 11:32 PM   #207
Monte's62
Lookin sweet LV. I love the stance. Are you going to fab some inners?
Monte's62 is offline   Reply With Quote
Old 01-21-2015, 08:28 PM   #208
LVPhotos
LVPhotos's Avatar
Whoooaa!
Old 01-24-2015, 12:16 PM   #209
LVPhotos
LVPhotos's Avatar
Hi/lo hump comparison.
Old 01-29-2015, 04:28 PM   #210
77lesabre
77lesabre's Avatar
What are you doing for your 2 piece drive-shaft? I'm have the porterbuilt installed in my 61 right now and need to make the swap to a 2 piece also.
Instagram: 77lesabre
*1961 Chevy Long Stepside-350/700r4
*1977 Buick Lesabre Lowrider-350/th350
*2003 Chevy Silverado 2500HD-Duramax Diesel
77lesabre is offline   Reply With Quote
Old 01-29-2015, 05:18 PM   #211
LVPhotos
LVPhotos's Avatar
I am waiting on TKO 600 then taking it to Adams driveshaft in Las Vegas.
http://www.adamsdriveshaftoffroad.com
Old 02-06-2015, 08:08 PM   #212
LVPhotos
LVPhotos's Avatar
FREAKY Fun Friday. Hooker Headers and TKO 600. Full tank of argon. Beer on ice. Let the weekend start!
Old 02-06-2015, 08:14 PM   #213
LVPhotos
LVPhotos's Avatar
Forgot new chrome on original parts. Not perfect but at least you can tell they are og.
Old 02-06-2015, 09:23 PM   #214
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Very, very nice!
Lovin the tranny, and the sill plates!
Modges'66 is offline   Reply With Quote
Old 02-28-2015, 08:26 PM   #215
LVPhotos
LVPhotos's Avatar
McLeod hydraulic clutch bearing for new TKO 600. Header won't clear fork, so fork it, we are going forkless! New Black Magic 3300cfm fan. The first set of brackets were short of what I wanted so I JB Welded a piece to fill gap. I'll finish it in the morning.
Old 03-03-2015, 09:11 PM   #216
LVPhotos
LVPhotos's Avatar
Motivation Monday! Electric fan install, flex-a-lite black magic 3300 CFM
Old 03-08-2015, 11:44 AM   #217
LVPhotos
LVPhotos's Avatar
Seems my local Job has ended and now I have to get to Utah for some 12s. Guess I will have to bank some cash and get more goodies when I get back. Stay tuned! Some local truck and junk yard shopping is a must.
Old 04-21-2015, 09:01 AM   #218
LVPhotos
LVPhotos's Avatar
Been working. So how about a 300,000lb turbine?
Old 04-21-2015, 09:13 AM   #219
JamieGallien
JamieGallien's Avatar
That should give you a bit of boost! Nice!
1965 Chevy C10 SWB Step
(Family Restoration Project)
http://67-72chevytrucks.com/vboard/s....php?p=6043410
1972 Chevy C10 LWB Fleet
(factory auto/l6)
http://67-72chevytrucks.com/vboard/s...d.php?t=580342
JamieGallien is offline   Reply With Quote
Old 04-21-2015, 09:36 AM   #220
1963c-10
1963c-10's Avatar
Plated parts came out great and nice job on the fan install.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-21-2015, 12:49 PM   #221
Nacho_Paras N.L.
Cut the pan-hard bar mount off. Reposition the rear. Did valve cover swap, with hint of the body color. Full down on frame and fender, time for a nip/tuck and pipe notch. Swapped in the MSD Distributor and coil, no more HEI.
Nice build..... What headers do you have?
Nacho_Paras N.L. is offline   Reply With Quote
Old 04-24-2015, 11:34 AM   #222
LVPhotos
LVPhotos's Avatar
Hookers. 67-72 truck. Did not clear stock clutch arm and tight on driver side. Maybe they need to heat up to burn off coating left overs but not impressed overall with coating. My Patriots at half the cost looked better out the box.
Old 05-09-2015, 08:43 PM   #223
LVPhotos
LVPhotos's Avatar
Aired out!
Old 07-11-2015, 06:02 PM   #224
LVPhotos
LVPhotos's Avatar
Back apart to set transmission! Green Primer on Omaha Orange truck? Only on bottom of cab. Knocked another 5 lbs of build up off cab and frame.
Old 07-12-2015, 06:25 PM   #225
LVPhotos
LVPhotos's Avatar
One step closer! McLeod hydraulic bearing installed!
1962 chevy, bagged c10, manual transmission, short bed c 10
