Old 03-30-2015, 08:07 AM   #201
bnoon
Re: Project Mr. Green Jeans (now 5.3 LS turbo build!)
I got the oil pump, windage tray, pickup, and pan installed as well as the front and rear covers. Stored in a plastic bag for now until the heads are reconditioned. I found two broken exhaust manifold studs. One came out easily, but the other is broken below the mounting surface and will need drilled to extract it. Oh joy.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 03-30-2015, 09:42 AM   #202
bnoon
Ordered today: New exhaust studs with nuts and OBX stainless shorty headers. Still on the "to order" list is fuel line and fuel line connectors.
Old 03-31-2015, 08:07 AM   #203
bnoon
Cylinder head repair last night. Broke the metric tap, so just drilled it out larger and tapped it at 3/8 16 thread and used a SBC header bolt. Done. Tonight is lapping the valves and seating everything up with the new LS9 springs.
Old 03-31-2015, 09:11 PM   #204
Hankster
Hankster's Avatar
Your puttin in the work man! props!
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 04-01-2015, 08:35 AM   #205
bnoon
The transmission is here in town! I just have to wait for a call back from a delivery manager to set up the lift gate delivery to my house. Excited because I spent more on the transmission and delivery to my house than I did on buying the truck delivered to my house LOL!
Ordered today: Knock sensors and fuel line with parts.
Old 04-01-2015, 10:45 PM   #206
bnoon
Transmission will be delivered tomorrow.
Tonight, I worked on the heads. Lapped the valves in and reassembled with new seals and the LS6 springs.
Old 04-02-2015, 10:45 AM   #207
bnoon
Ordered today: HPTuners VCM Suite, one knock sensor (my connector broke), o2 sensors.
Old 04-02-2015, 03:25 PM   #208
NewType72
NewType72's Avatar
Impressive work my friend!
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 04-03-2015, 08:47 AM   #209
bnoon
Thank you!
Transmission was there last night so popped it open and got a few pictures. Sign on top says Fragile. Please give a shift LOL!
I also worked under the hood of the truck for the first time in a while. Swapped out the brake booster (had a small leak), and had to cut and chisel the old brackets off to bolt to the newer one. Luckily the holes already lined up, so it wasn't too bad at all. Cleaned up some wiring and figured out a few changes that I'll need to make for the new stuff to go in... And also, I FOUND MY MISSING FUEL GAUGE WIRE! Someone had cut it and tucked It inside the harness covering and taped it up. I hooked up the wires to a test source and Poof, working gas gauge!
Old 04-04-2015, 08:41 PM   #210
bnoon
Stainless shortly headers from Amazon showed up today. 105 shipped!!!
Old 04-05-2015, 07:43 PM   #211
bnoon
Cylinder heads on and torqued, pushrods and rockers in place and ready to adjust, valley cover and new knock sensors in place.
Old 04-07-2015, 03:25 AM   #212
NewType72
NewType72's Avatar
Nice steady progress brother!
- Dylan
(209)-985-7721
Old 04-07-2015, 08:32 AM   #213
bnoon
Thanks!
Got the intake on and accessories too, though the picture doesn't show it all. Quite an ugly intake for such a beautiful engine.
Old 04-07-2015, 05:51 PM   #214
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
It's looking great!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-07-2015, 06:27 PM   #215
Dads79GMC
Dads79GMC's Avatar
Smoke'n!!
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 04-08-2015, 09:12 AM   #216
bnoon
Next up, making some plugs for the EGR and the evap sensor holes. Hopefully the used valve covers I purchased from Ebay will be here soon and I can button it up.
Old 04-11-2015, 09:23 PM   #217
bnoon
Assembled the engine to the transmission today and got it into the engine bay!!! Several more parts coming in the mail that should be here soon. Next is swapping out the two piece bolt on yolk TH400 drive shaft for a one piece slip yoke TH350 drive shaft to make sure it all lines up, then I can tighten down the Dirty Dingo engine mounts fully and drill the frame for the moved transmission mount.
Old 04-12-2015, 10:45 PM   #218
bnoon
Engine mounts adjusted, transmission mount installed, EGR block off (1 3/8" freeze plug, plus a bolt on cover, both epoxied in place too), vapor line plugged with a 3/8" threaded allen plug plus epoxied, messed with the ac compressor to see if I could make the stock position work (looks like it will if I notch the frame and I modified the factory bracket a little bit too).
Old 04-16-2015, 02:28 PM   #219
bnoon
I got the 1998 Camaro temp sensor installed. It's a 3 wire sensor where 1 wire will go to the factory temp gauge and the other two wires tell the ecu the temp. Wiring pigtail is not here yet.
Installed the used EBay valve covers.
Ordered 16 gauge 304 stainless steel mandrel bends, stainless t4 flange, 304 stainless Silverado manifold flanges, t4 oil feed flange... Hot side mockup will begin shortly.
Old 04-16-2015, 02:35 PM   #220
skeet85silverado
Can u let me know how those headers fit once u install them?
skeet85silverado is offline   Reply With Quote
Old 04-16-2015, 09:14 PM   #221
bnoon
I will post pictures when they go in.
Put together the power steering pump tonight. Aside from needing to bend the return line a little, it bolted right up.
Started on the wiring tonight as well. Trimmed back the fuel gauge wire a bit and reterminate it. Starter wires need a couple of feet removed too. Then run power to the tank area for the pump. Then add the engine harness and ecu. Getting closer!!!
Old 04-17-2015, 12:30 PM   #222
naphtali5725
naphtali5725's Avatar
man i wish i could get a new set of stainless headers for 105.00 for my Olds 455, instead of almost a grand... WTF?
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 04-17-2015, 02:17 PM   #223
bnoon
Yeah, I've had a few of the non-mainstream hot rods before. These Chevys are MUCH more fun and EASY!!!
Old 04-17-2015, 02:25 PM   #224
naphtali5725
i'm not sure i can agree about the more fun part, cause my Olds is in my 86 C10
My build thread...
Disabled Veteran
Old 04-17-2015, 02:26 PM   #225
bnoon
Well then why not a 472/500 caddy???
