Old 01-11-2016, 11:19 PM   #201
Drifters
Re: Lss3
The trucks coming along? Looks good
Drifters is offline   Reply With Quote
Old 01-12-2016, 09:16 AM   #202
mcbassin
Still Learning
mcbassin's Avatar
Re: Lss3
Nice progress on the project. Love the Vintage air upgrade. Good luck with that rust. I know how much fun that can be.
mcbassin is offline   Reply With Quote
Old 04-07-2016, 12:04 AM   #203
69cunningham
69cunningham's Avatar
Re: Lss3
A couple of weeks ago I decided to test the fuel system in preparation for starting the engine. The Vapor Worx electronic fuel pump controller was crudely wired to the pump. When powered up, the pressure at the fuel rails came up to 50 PSI. A little low, but the control module has an adjustment to bump it up. Just as I was about to make the adjustment, I noticed fuel leaks in several locations. I hoped I just needed to tighten a few joints. No luck. With one of the lines removed, I discovered a crack in the flare. It turns out that stainless tubing is not seamless. The cracks occurred on the seam. I may have work hardened the tubing by using a tubing cutter. All the SS lines are junk. Most of the flares are cracked. The lines are being replaced with aluminum lines. I have really good patterns and the aluminum is much easier to work with.
69cunningham is offline   Reply With Quote
Old 04-07-2016, 11:35 AM   #204
notchbackgta
Re: Lss3
I have done all my lines on projects in stainless and havent had a problem with the tubing splitting at the seam. It looks like you have a regular flare on that instead of the inverted flare? That may be your issue
notchbackgta is offline   Reply With Quote
Old 04-07-2016, 08:18 PM   #205
69cunningham
Re: Lss3
I'm using AN fittings that have a single 37 degree flare for my fuel system. My brakes use traditional inverted flares. I'm going to have to take them apart and inspect them before I add the fluid. Do you know if the tubing you used was seamless?
Old 04-08-2016, 11:12 AM   #206
notchbackgta
Re: Lss3
No, I used cheap Summit stainless 3/8 tube and it is not seamless, but the tool I have does the flare for the 37 degree differently. I may be using the wrong terminology, but my tool folds the tube in first, then I put the flare on afterwards, so the end of the tube is on the inside, not outside like that. I have no leaks or splits with it, and I have pressed a lot of ends on that cheap tube. I also used the cheap Summit tube nuts and fittings for the fuel systems on several cars.
Old 04-09-2016, 04:34 PM   #207
69cunningham
Re: Lss3
Last week, I got a tire mounted on my one rim to see how they fit. The tire is a Toyo Proxes ST II 285/60R17. Today, the bed was assembled on the frame. The tire just kisses the bed side. There is a ton of clearance to the fender.
Old 04-11-2016, 08:31 AM   #208
mcbassin
Still Learning
mcbassin's Avatar
Re: Lss3
Very nice looking wheel and tire combo, I guess you'll need a small spacer in the rear?
Old 04-11-2016, 02:50 PM   #209
roushinator
roushinator's Avatar
Re: Lss3
Awesome progress!!
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 04-11-2016, 02:52 PM   #210
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: Lss3
Wheels look nice!
ChuckDriver is offline   Reply With Quote
Old 04-11-2016, 09:07 PM   #211
69cunningham
Re: Lss3
I am hoping to get away with a 3/8" spacer. The problem I used too short wheel studs. I will need to remove the axels to replace the studs.
I considered tubbing the bed slightly to get the clearance needed, but that left the tires tucked in too far.
Old 04-22-2016, 07:03 PM   #212
LongC'67
Re: Lss3
Fantastic build. I'm going to be watching this.
LongC'67 is offline   Reply With Quote
Old 05-09-2016, 10:21 PM   #213
69cunningham
Re: Lss3
I just received a hub cap to go along with my wheel and tire. It is a PDC1 from Year One. It looks nice, but it is a chrome plated plastic piece, not cast metal like GM used. It is what is recommended for the wheel.
I also received the 3/8” wheel spacers for the rear (Billet Specialties WSG5L375) and longer wheel studs (Baer Brake 6280012). The studs were a lot harder to find than I expected. The Moser A3065GMT5 5 lug conversion axles use an odd size knurled section on the half inch studs. The holes in the axles is .525”. The knurled section is supposed to be .530” for a 5 thousandths interference. The Baer part were the only studs I could find other than the stock length ones. I’ve disassembled the rear end so the studs can be replaced.
Old 05-10-2016, 08:30 AM   #214
mcbassin
Still Learning
mcbassin's Avatar
Re: Lss3
That wheel and tire setup looks good!
Old 05-20-2016, 09:21 PM   #215
69cunningham
Re: Lss3
The new rear wheel studs are installed. It was easier than I expected as long as a press is available. The hardest part was disassembling the True Trac differential to get the axles out. The C clip did not want to come out.
Old 07-10-2016, 05:27 PM   #216
69cunningham
Re: Lss3
I wasn’t entirely happy with the shifter. The throw was longer than I liked at 5.75”. That long throw caused the position of the knob in second gear with the seat all the way forward, the way it would be for my wife, was too far back to be comfortable. I discovered a new shifter base from Core Shifters. It moves the pivot point up, reducing the throw to 3.5”. It unfortunately moves the stick mounting point up and cants it over 14 degrees. This means another stick is needed. Since I am using the center stick location in the T56 Magnum, the base would cant the stick away from the driver. Due to symmetry in the base that was easily corrected.
Old 07-18-2016, 10:10 PM   #217
69cunningham
Re: Lss3
I’ve been looking for a place to relocate the battery to from under the hood. This seems to be the best place. I like cleaning things up under the hood and transferring some weight to the rear.
Old 08-22-2016, 09:59 PM   #218
69cunningham
Re: Lss3
LSS3 has reached a major milestone today. The engine runs! It was cranked over with the ECM unpowered to check the oil pressure. It got up to 20 PSI after about 10 seconds of cranking. Next, the fuel system was powered to get 60 PSI at the fuel rails. Last, the ECM was powered and the starter engaged. It came to life after just a few cranks. It idles smoothly and revs easily. The cooling system isn’t filled yet nor is the belt installed so I only ran it for about 5 seconds at a time. So far I only started it twice. It sounds mean.
Things are rather cobbled together. The wiring harness is just draped over the engine with a few tie wraps keeping wire away from moving or hot parts.
Ever since I bought the motor I’ve been worried about the throttle body. It is from the 2010 Camaro which uses the 12605109 with a gold colored throttle blade. GM crate engine the ECM was designed to work with uses the 12570790 with a silver blade. I haven’t been able to find enough information comparing the two and thought the gold one might not work. For now, everything seems to be working well. When the pedal is not being pressed, the blade is nearly closed. When fully depressed, the blade just fully opens.
Old 08-23-2016, 09:15 AM   #219
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Lss3
That is a major milestone, congrats!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 08-24-2016, 12:13 AM   #220
cornerstone
cornerstone's Avatar
Re: Lss3
Man thats gotta be a great feeling... congratulations!
cornerstone is offline   Reply With Quote
Old 10-15-2016, 10:31 PM   #221
69cunningham
Re: Lss3
The new rear wheel studs were way too long for the derby caps to fit. Chopping off 5/8” makes it just right.
Old 10-15-2016, 10:42 PM   #222
69cunningham
Re: Lss3
The Wilwood rotors are bolted to the hats. These bolts need to be safety wired. It’s a bit challenging, but I’m starting to get the hang of it.
Old 10-16-2016, 02:31 AM   #223
mechanic350
mechanic350's Avatar
Re: Lss3
coming along great man. keep up the work.
1972 Chevrolet swb fleet side. - SOLD
2018 Toyota Tacoma but hunting for another C10
Link to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=607303
Instagram: https://www.instagram.com/72c10shortbox/?hl=en
mechanic350 is offline   Reply With Quote
Old 10-16-2016, 06:34 PM   #224
69cunningham
Re: Lss3
LSS3 reached a milestone today. It is finally sitting on tires and wheels. No more blocks and jack stands.
Old 10-16-2016, 06:42 PM   #225
ChuckDriver
Re: Lss3
Looking good!
