Old 05-31-2019, 08:28 AM   #201
Low Elco
Re: Shop truck build
Wow! How'd you trick her? Nice work on all fronts!
Low Elco is offline   Reply With Quote
Old 06-09-2019, 10:47 AM   #202
rusty76
rusty76's Avatar
Congrats
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 06-20-2019, 09:38 AM   #203
skyphix
Well, first and foremost, congratulations on the marriage!
Now, on the truck front; would you care to share some details on that dash? What did you find was the best method of stripping the old padding off? Rip/tear and sand?
That look is exactly what I was thinking for my dash since my dash pad is... bad... to say the least.
Eric
1980 C10 SWB
2003 Chevy Suburban 2500 LT
skyphix is offline   Reply With Quote
Old 07-03-2019, 10:50 AM   #204
Whamo
Whamo's Avatar
Man, I am behind on updates...I apologize fellas, and I will get caught up over the next couple days...but 1st
I am not sure there is a good method...I detailed it back in the thread starting with post #43...It was and pain and tedious.
Basically, I went crazy with a putty knife.......FOR HOURS!!!
I can't remember the exact number but there are over 70 of those stamped holes in the dash (I am guessing for weight reduction) that are very sharp and left me with several finger slices...
The black mesh is gutter guard that I picked up at Menards and JB Weld'd to the bottom...cheap and doesn't look too awful...
The wood accent is actually 100yr old barn wood that I planed down and trimmed up to fit the existing trim holes...
I know that Gregski stripped his down in his Restoring Rusty thread and I believed he was phosphoric acid, but I can't remember exactly...
Just a Hillbilly in the Hood
http://67-72chevytrucks.com/vboard/s...d.php?t=622194
Whamo is offline   Reply With Quote
Old 07-05-2019, 10:07 AM   #205
skyphix
Thanks! I wound up peeling it all by hand, then using flat head screw drivers on the stubborn stuff, then sandpaper to get the remainder off. It took probably 2 hours or so to get it to paintable condition.Sprayed with flat black rust converter... I haven't done the gutter guard yet, but also agree on the sharp edges! Looks way better than what was there before.
Eric
1980 C10 SWB
Old 07-05-2019, 11:34 AM   #206
naphtali5725
naphtali5725's Avatar
I did the same to my dash... post #132 bare metal, then i bought custom aluminum one
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 07-06-2019, 03:57 AM   #207
LT7A
Congratulations on gettin' hitched! Good catch!
And the motor looks good "perched" in its newly cleaned environs.
Old 09-10-2019, 09:16 PM   #208
Whamo
Whamo's Avatar
Originally Posted by Tsoptich83 View Post
Im digging it. I can't wait to hear how that EFI system works and watch the install. Also looking forward to more of your Africa trips.
Man! I have really neglected this thread and again, I apologize...
I'll start with the Sniper EFI...quite simply, this thing Rocks! Total install (fuel pump and fuel lines) and wiring time was about 2 hours - it was a bit easy because of Rusty's lift. Truck fired on the 1st turn and it took about 10 minute for the computer to "learn" the motor...them puters have come a long way since my ole Commodore 64...
The only complaint about the system is the same one that everyone else has...The pedal is STIFFFFF and the throttle response takes a bit getting used to...all four flaps flap at the same flapping time! Sooo, at intersections you either creep through like your 98 and fell asleep waiting for the light to turn or you are spinnin your one legged beast like a 16 yr driving his cheerleader girlfriend's mustang...
I just ordered the progressive link that Holley does not recommend and I'll let you know how it works...everybody says it makes things mo better and everybody is always right...
Other than that, the truck fires immediately, there's no quadra-junk stumble, no gas fumes (kinda miss that) and it just works!
Old 09-11-2019, 07:41 AM   #209
bluex
bluex's Avatar
Send the progressive link back an order the throttle arm extension. That's what you actually need. I tried the progressive link an didn't like it. I have since found out you need to do more tuning to the system for it rather than just checking the box an telling it what % the rear opens. Mine didn't open the rear until 52% throttle which was way to late imo, it needs to be more like 22-25%. Hope your results are better with it but I think you'd be happier with the arm extension.
If you are dead set on keeping the progressive link I can help you get the tune set up for it after you install it.
bluex is offline   Reply With Quote
Old 09-11-2019, 08:12 AM   #210
Whamo
Whamo's Avatar
Right on, man! I am not dead set on anything and I appreciate the advice...I'll order the extension and give it a go...I've heard others complain about getting the % right and that it can be a pain...
I'll report back...thank you...
Old 09-11-2019, 11:46 AM   #211
daddyjeep
daddyjeep's Avatar
The fuel Injection badge is pretty cool.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 09-11-2019, 11:56 AM   #212
Whamo
Whamo's Avatar
65 Vette badging...wanted sumptin different
Old 09-11-2019, 12:05 PM   #213
daddyjeep
daddyjeep's Avatar
I was thinking Vette. I have a '72 J10 badge on my Jeep that I really like. I just need to find the other one.
04 1500 crew cab
Old 09-11-2019, 12:07 PM   #214
Whamo
Whamo's Avatar
Now that! is cool!!
Old 09-11-2019, 01:24 PM   #215
bluex
bluex's Avatar
The problem lies in some other tables that need to corrected with the laptop software for the progressive linkage. Its not a big deal but that's why it isn't "officially" supported by holley.
An the guys saying it will help on mileage are full of it. The engine needs a certain amount of fuel to run. It can come from all 4 injectors or 2 but it's still going to use the same amount of fuel.
I went an took Holleys efi classes (through level 2) in August so if you get stuck on anything just shoot me a PM. If you haven't found it already I recommend saving this manual.
http://documents.holley.com/techlibrary_199r11259.pdf
If you do Facebook avoid the sniper groups. Its full of people who can't/won't read the manuals an want to argue about why you have to do certain things the way it says. I won't get off on that rant though lol.
Old 09-11-2019, 04:57 PM   #216
Whamo
Whamo's Avatar
Redneck tip of the day...lost center caps? Steal the caps off your neighbors fence, wire wheel them, wrap the base in electrical tape and slam them in the hole! Better than spending $50 per on new ones... .
Old 09-12-2019, 09:35 AM   #217
daddyjeep
daddyjeep's Avatar
Now you have made us all accomplices in your criminal activities... thanks
04 1500 crew cab
Old 09-13-2019, 08:40 PM   #218
rusty76
rusty76's Avatar
Thanks for all the info.
My build thread
Crossmembers CC
Old 09-14-2019, 07:39 AM   #219
Whamo
Whamo's Avatar
In the "you get what you pay for but sometimes cheap works" category...we have this radiator...
Fitment was perfect and install was pretty simple...had to fab up some top brackets out of a piece of metal door trim (yes...that bracket is SEMA quality, I know), but it settled in place nicely...
I knew sumptin would go wrong with this piece and it showed itself when the trans cooler outlet threads stripped out immediately...no biggy...picked up a junkyard external and all is right in the world...
Next issue was getting this baby to burp...she didn't want to...took a while and she made sure to spew multiplemany times...
Really, this unit works pretty well (he said unit) for what it is...in normal, stupid traffic during hot days, it keeps the motor about 185 degrees...if I am running the A/C (don't judge), it hovers around 205 but I gotta keep an eye on it in heavy traffic...
All in all, I cain't complain...$255 for a radiator/fan combo...I'd by that for a dollar...
Old 09-18-2019, 07:19 PM   #220
Whamo
Whamo's Avatar
Bluex! Thank you Brother...that was stupid easy!! Throttle is smooth as whipped butter now....
Old 09-20-2019, 07:42 AM   #221
bluex
bluex's Avatar
Glad it helped. They should include that extension part with them imo...
Old 01-20-2020, 01:50 PM   #222
Whamo
Whamo's Avatar
saved these seats from a Caddiwack...
Old 01-21-2020, 01:49 PM   #223
daddyjeep
daddyjeep's Avatar
Oh...those are nice
04 1500 crew cab
Old 03-19-2020, 03:32 PM   #224
Whamo
Whamo's Avatar
finally getting around to installing the buckets...doing a little mock here...
Old 04-12-2020, 05:53 PM   #225
Whamo
Whamo's Avatar
Seats installed and some "paint" clean up with boiled linseed and mineral spirits...
Gonna lower the rear some more and go with a posi rear end...I'll detail the work...
