Old 06-15-2016, 06:44 PM   #201
ptc
ptc's Avatar
Re: 66 Pro Street Build (Domeringer)
Wow, extreme truck build! --- very impressive Gary.
great inspiration too....
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 06-16-2016, 04:00 PM   #202
Isaiah
Hello nice build was just had some questions about the roll cage and bracing you added like what spec cage is this going to be and would you be willing to make a kit like bend some bars and cut them to mimic what you have
Isaiah is offline   Reply With Quote
Old 06-16-2016, 06:04 PM   #203
Gary V
Active Member
Gary V's Avatar
Originally Posted by chad64chevy View Post
damn bro!! that's a lot of braces, lol!! but got to have them
Hi Chad, going to put some big HP to it some day!
Thank you
Hello Isaiah, Thank you! I worked to the 25.3 SFI spec, but really don't want to install a funny car cage for street use. Maybe some day when it's tuned to go that fast I'll put it in. Sorry but really don't have the time to put a kit together... this project is just a hobby. My day job leaves me little time as it is to work on it.
Best regards,
Gary
DOMERINGER BUILD
Gary V is offline   Reply With Quote
Old 06-17-2016, 02:54 PM   #204
Isaiah
That's unfortunate I can't find anything for my truck I have been following your build to the t I have the same frame setup etc only thing different Is my motor and transmission I have a 632 ci nelson racing 2500hp motor and a Lenco 4 speed or three I still have to decide
Old 06-17-2016, 03:15 PM   #205
Isaiah
And thanks for the reply if you know anyone with a chassis plan for it let me know I'll buy it off them I can bend my own tubing just need to know where to bend lengths etc
Old 06-17-2016, 04:32 PM   #206
forestb
forestb's Avatar
MAN ALIVE!!!! if this hole truck thing doesn't work out you could seriously have a career building jungle jyms.
forestb is offline   Reply With Quote
Old 06-18-2016, 01:12 AM   #207
Captainfab
60-66 Nut
Have you checked with Art Morrison? They can make mandrel bent rect tube frames for these trucks. I don't know about a cage though. They aren't that far from you.
If you have a tube bender you might take a look at the Bend Tech bending software. They do have a roll cage module with many templates and you just enter your desired measurements and it gives you a parts list with lengths, bend positions and notching info. Or you can also design your own in the assembly interface.
http://www.2020softwaresolutions.com/
Old 06-24-2016, 01:29 AM   #208
Isaiah
Can I get links to the shocks your using for front and rear
Old 06-24-2016, 01:30 AM   #209
Isaiah
If you could find a template for 66 c10 let me know
Old 06-25-2016, 01:03 AM   #210
Captainfab
60-66 Nut
Bend Tech does not have templates for specific vehicles. You just pick the design you want and then input your dimensions. Then the software will give you a parts list with cut lengths, notching and bending locations and degrees.
Old 07-05-2016, 11:53 PM   #211
Isaiah
Hey Gary could you give me the length on where you cut the the original frame and spliced to the custom 4 link I got all my parts in and I'm trying to copy what you have
Old 07-06-2016, 12:21 AM   #212
Isaiah
Do they have templates for a 25.3 with a stock/modified frame I'll buy it as long as I am not going to waste money
Old 07-06-2016, 12:34 AM   #213
Captainfab
60-66 Nut
I have no idea, I do not have the module yet. You should email or call them.
Old 07-06-2016, 12:36 AM   #214
Isaiah
I understand thanks for leaning me there way I will call them in the morning have a good one man
Old 07-06-2016, 12:47 PM   #215
Isaiah
After a hour long call they told me they don't have anything past a 12 point roll cage thanks for trying to help though I'm just gonna keep asking around and see if anyone has made one before that I can edit for my application
Old 07-06-2016, 10:32 PM   #216
clemdaddy
clemdaddy's Avatar
just read your build and I agree with Modges… You got some serious fab skills.
Keep after it bro. we'll be looking' in on this build. Great write-up & Good Work...
clemdaddy is offline   Reply With Quote
Old 07-09-2016, 04:07 PM   #217
Gary V
Active Member
Gary V's Avatar
Thank you much!
Hi Isaiah,
Give this company a call AUTOWELD
... think they might be able to get you enough of the cage to get you started.
Ok haven't updated in a bit because it would appear that not much was done. Lots of finish welding was completed and added something new! Fabbed up and mounted a 4130 removeable drive shaft tunnel... boy that was fun.
Best regards,
Gary
DOMERINGER BUILD
Old 07-11-2016, 07:54 PM   #218
mud.man.rj
mud.man.rj's Avatar
Might have to change the name to Overkill, suits the truck.
This build makes me smile bigger everytime you accomplish something else.
Nice work, so is the drive shaft cage/tunnel required?
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 07-12-2016, 06:01 AM   #219
Gary V
Active Member
Gary V's Avatar
Thanks again my friend... LOL yea it does look like it's going that Overkill way. Well is it required? I intend to have the center of the floor removable for maintenance. Could have got away with just a loop and the oem floor. But as long as I have access to do it now... why not. Here's the rule
Best regards,
Gary
DOMERINGER BUILD
Old 07-12-2016, 07:31 PM   #220
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Gary, I read that as you plan on going 7.49 or faster? NICE!! Cant wait for the track videos!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 07-13-2016, 12:43 AM   #221
mud.man.rj
mud.man.rj's Avatar
Well he is set up for 7.49 and quicker anyway..
We can a similar setup for mud drag classes with out trucks, almost identical.
Thanks, a video is a ways off but sure will be nice to see someday.
5.0 4spd std.
7" lift w 35's.
Old 07-20-2016, 05:34 AM   #222
Gary V
Active Member
Gary V's Avatar
We'll see
Pretty much sums it up at this point... we'll put that LS power to it and see what happens.
Best regards,
Gary
DOMERINGER BUILD
Old 12-28-2016, 11:58 AM   #223
grunt5510
Anything else happen on this build? Is it done? I'm hanging by a thread here!!! Hahaha. Beautiful truck. What materials did you use for your frame rails? I'm gathering parts for my 62 grudge/pro street build as I'm typing.
grunt5510 is offline   Reply With Quote
Old 12-28-2016, 12:31 PM   #224
61_FL_Apache
Who Me?
I enjoy this build too!
Happy Holidays Gary!
Steve
2001 Blazer 4D 2WD
Old 12-28-2016, 11:52 PM   #225
Gary V
Active Member
Gary V's Avatar
Thank you... been a busy few months at work and home so the project progress has stalled a bit. I have been able to do some work on it and will post some picks this weekend.
The rectangular pieces are 1/8 X 2 X 6. The flat stock for boxing the frame rails is 1/8 also.
Thanks bud! Have a Happy New Year! Will post soon.
Best regards,
Gary
DOMERINGER BUILD
66 c10, drag truck, pro street, twin turbo ls1
