Old 05-08-2018, 08:05 PM   #201
Joe Pass
Joe Pass's Avatar
Re: New 64 Stepper Project
Are those hood hinges cad plated?.....gold looks nice..
Joe Pass is offline   Reply With Quote
Old 05-08-2018, 08:10 PM   #202
jimmythompson1964
jimmythompson1964's Avatar
You are crazy detailed on your build...I am impressed
jimmythompson1964 is offline   Reply With Quote
Old 05-08-2018, 09:02 PM   #203
The Rocknrod
Moderator
The Rocknrod's Avatar
Cadillac plating did the cad plating, they have a new plating now though.
Thanks for the compliment guys.
Old 05-09-2018, 08:50 AM   #204
aggie91
I'm just glad to be here!
aggie91's Avatar
Wiring for the park/turn signals looks nice and clean. That is the way I did mine that I tried to explain before.
Are you using a nylon washer under the head of the bolts? Looks like something is between the bolt head and the inner fender where they bolt to the firewall.
Very clean and detailed build!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-10-2018, 09:14 PM   #205
The Rocknrod
Moderator
Watch out for your hood sponges. I bought a set from LMC and a set from I think The Truck Shop and the Truck Shops were narrower, same thickness though.
Old 05-10-2018, 09:16 PM   #206
The Rocknrod
Moderator
Also I put my dome lamp in. Waiting on the courtesy foot-well lights to finish the wiring.
Old 05-12-2018, 08:04 AM   #207
The Rocknrod
Moderator
Okay I installed the hood running/turn lamps, they are LED, new housings, plug, fasteners. I clear coated the housings and plugs masked where needed of course.
Old 05-12-2018, 08:07 AM   #208
The Rocknrod
Moderator
Received the courtesy lights and installed them wired except for the passenger side. Going to work on the when I get a glove box that I will get when I get an air conditioning unit. Want the wiring to be nice so running it will all be together.
Old 05-12-2018, 08:12 AM   #209
The Rocknrod
Moderator
I bought a dash speaker from retro-sound I think, anyway one of the brackets didn't line up so I did some modification to the location and bracket. Lines up now.
I'm not big into stereos, so I will have one but the boom-boom thing isn't mine. People try to "school" me on what is boom-boom and what is not - I cant tell the difference.
Other than the green items you see I got from an original bracket and the rubber piece too, the rest came with the speaker.
Old 05-12-2018, 09:43 AM   #210
Indian113
Indian113's Avatar
I am with you on the Boom Boom Thing! My hearing sucks and all I need is some Music, besides I would rather hear my wife and the exhaust note when I am cruising. Thanks for the updates I really like the way your truck is taking shape.
Indian113 is offline   Reply With Quote
Old 05-12-2018, 11:34 AM   #211
The Rocknrod
Moderator
Thanks I'm tryin.
I still want to install foam around the speaker and put some black material on it before I install it for good. So I'm going over today and look for that stuff locally.
Old 05-12-2018, 04:20 PM   #212
The Rocknrod
Moderator
Okay here is my plan on the front seat. Cream and Red with material, not sure which of the two materials on the right yet.
Old 05-12-2018, 06:04 PM   #213
jimmythompson1964
That is one sharp truck, if you were a little closer I would stop by and see it in person. Nice work
Old 05-12-2018, 06:10 PM   #214
jimmythompson1964
Originally Posted by The Rocknrod View Post
I started working on the hood lamps. I used an American Autowire grommet for the firewall plug for the hood wires to include a ground wire to the lights, I used some push-mount wire ties in the interior of the hood wiring, they are hard to even notice. The pad isnt installed in the hood on the pic below, hard to see with so much red.
How did you get the wires to the front of the hood? Under the bolt on brace ? Mine is just wire tied and exposed, yours looks really clean.
Old 05-12-2018, 06:17 PM   #215
The Rocknrod
Moderator
Pretty much thats how I did it. Thank you for the kind comment, I wish you were closer too you could stop by once in a while.
Old 05-14-2018, 12:39 AM   #216
The Rocknrod
Moderator
Installed the speaker, cant even tell it's in there. And The cowl leaf/trash screen is in there also.
Old 05-14-2018, 08:16 AM   #217
Joe Pass
Joe Pass's Avatar
That worked well...nice idea
Old 05-14-2018, 08:57 AM   #218
aggie91
aggie91's Avatar
I like the pattern on the right, but the one in the middle is a little more subdued so it might be a better choice. All I know is, you are doing a great job on the truck and no matter which material you choose, it will look outstanding.
Would you mind sharing the part numbers from SMS for those two fabrics?
Keep up the great work!
Karl
The LST Challenge:
Old 05-17-2018, 02:07 PM   #219
The Rocknrod
Moderator
So I installed the gauge panel after finishing the wiring behind it. Have everything else ready to plug in when I get the rest.
Old 05-17-2018, 04:27 PM   #220
jchav62
1962 C-10
jchav62's Avatar
Looking beautiful! Very clean...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-17-2018, 07:52 PM   #221
shp4man
shp4man's Avatar
Wow, you must be a perfectionist because that looks like a really nice build.
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline   Reply With Quote
Old 05-17-2018, 08:03 PM   #222
The Rocknrod
Moderator
Thanks guys.
Old 05-17-2018, 09:48 PM   #223
60short
60short's Avatar
I just read through your thread, this is gonna be one heck of a truck...
can I ask how / what you attached under the cowl as the trash screen?
60short is online now   Reply With Quote
Old 05-17-2018, 11:08 PM   #224
The Rocknrod
Moderator
Thank you, I hope it will be.
I purchased a roll of 1/4" X 1/4" screen and formed it ever so carefully almost wire by wire to fit in the underside so that it would support itself. Then I read recently where one of our members here used some hot glue ensure his stayed a few years ago (still works) so I used some too.
Old 07-13-2018, 12:10 PM   #225
The Rocknrod
Moderator
Back when the local trailer guy brought my truck home from the painter - 1 year, 1 month, 1 day after I let them have it.
In your "wildest" dreams - what do you think the cost was, all new sheet-metall before the painter got it.
