#2376 | |
Lucky Teter at the wheel
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
I have a whooshing noise coming from my brake booster and no power brakes. Did I mess it up? Muffler was contacting a cross strut and vibrating. (fixed that this afternoon) Tow haul light comes on by itself and the tranny starts holding gears longer. Glass is in and worked out well. $225 for a Precision front weatherstrip, glass, and installation. The best part is - if it leaks, it's their problem.
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
#2377 |
![]() Join Date: Mar 2011
Nice going, truck looks just great....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#2378 | |
VA72C10
![]() Join Date: Mar 2008
maybe an electrical thing on the tow/haul? Sounds like a bad seal on the booster/bad booster itself???
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#2379 |
Chevy Enthusiast
Good thing you have a spare booster!
Good job man it looks great!
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
#2380 |
I couldn't be happier for ya!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#2381 |
Still Learning
Sounds like a good deal on the glass.
So you have a few bugs to work out. You knew there would be some things to tweak after the maiden voyage. Keep it up! FYI, at the rate you're going this thread will hit 300k visits by year end ![]() ![]() |
#2382 |
Junk Yartist
I watched the video real loud so that everyone could hear.... Seems like I was the only one who appreciated it here
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#2383 |
![]() Join Date: Aug 2010
Loved that video. Cant wait to see it done. I LOVE PRACTICAL TRUCKS!
Jeff 1972 Blazer CST 2wd- My son Sam's Project "S" Project "S" 1970 Suburban - SOLD "One Bad Burb" Photobucket Album 1986 C30 Crewcab - 63K original miles, original paint Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP... |
#2384 |
I'm going backwards here again. Booster was bad so I had to cut off my adapter and re-weld it to the spare booster I got from Eddie. I should be able to get it back together tomorrow. A disk inside was cocked and may have been the problem.
I figured out the 2 wires that are used for the tow/haul feature. I can wire a momentary switch to activate/deactivate so that if I ever need it when towing the 65 Vette to a car show I'll have it. ![]()
#2385 | |
#2386 |
VA72C10
At least it was a relatively fast fix and you have a booster. Windshield looks good (in the tiny part of the pic I can see
#2387 |
![]() ![]() Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
#2388 |
Amazing work! Cannot wait to see in person
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
#2389 | |
Booster is back in and works now, time for a real drive!
#2390 |
Junk Yartist
Drew, are you gonna use that 99-02 gauge cluster, or dig around for a lower profile GM cluster that fits better? ....... when the time comes
#2391 |
My project is using a 93 silverado running gear and am not sure what or how to do the speedo and guages. looking forward to your fix
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344 1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494 R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438 1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250 |
#2392 |
Looks great, how are the brakes now?
#2393 |
Collector of Projects
Not cheap, but fits the origianl cluster and will blend the old school look with your modern twist (and drive train)... HERE
Fully lit needles, backlit faces, and three highly visible LCD message centers are a few of the things that you can see which set the VHX Series apart from yesterday’s traditional approach to instrumentation. A few of the features which you don’t normally see are the micro-controlled precision stepper motors, solid state sensors for unparalleled accuracy, and user-customizable display feedback, all supported by an unrivaled limited lifetime warranty which has become the standard for Dakota Digital instrumentation systems . Completely engineered and manufactured at our facility in Sioux Falls, South Dakota, the VHX Series has completely revolutionized the instrumentation industry ![]() |
#2394 |
#2395 |
I knew I would get some responses with that gauge picture. That cluster is just sitting there while I do some shakedown runs, I will have the old one installed in the end, but I don't think I can afford to rebuild it with new gauges. I will probably get the voltmeter and oil pressure working, but that's it for now.
#2396 |
VA72C10
Looks good!
#2397 |
![]() Join Date: Jul 2010
Have you thought of intergrating that cluster in the factory bezel?..
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
#2398 | |
#2399 |
Finally got a bright sunny, dry day!
Definitely too loud with only the factory Denali muffler. I am amazed that just taking off the cats made it so much louder. Anybody got any suggestions for adding a small resonator or something???
#2400 |
