Old 05-07-2015, 09:17 PM   #2401
gdavis
gdavis's Avatar
Re: 1968
Originally Posted by RenoKeene View Post
Truck looks great George! I'm just north of you a bit, maybe I'll cruise down in mine after the Love Bugs disappear.
Brad
thanks a lot man and any time give me a call thru a PM
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 05-07-2015, 09:22 PM   #2402
gdavis
gdavis's Avatar
Re: 1968
Today, I went and tried to get the front end adjusted, Like I said tried. He couldn't do the toe and camber. He said that he couldn't take the bolts off. I had them off three years ago but he didn't charge me nothing. The truck has a few issues so I will be working on them starting Monday.
Check out Patches
Old 05-07-2015, 09:29 PM   #2403
Xeen
Xeen's Avatar
Re: 1968
I hope he didn't use metric tools and round off the nut's and then be like "I couldn't get them off" like a pro.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 05-08-2015, 03:33 AM   #2404
swamp rat
swamp rat's Avatar
Re: 1968
Open this Google search and read the posts, the first one especially.
https://www.google.com/search?newwin...15.wkCglJAtWhg
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 05-12-2015, 08:07 PM   #2405
gdavis
gdavis's Avatar
Re: 1968
Guys what is the worst thing that could happen to our trucks except having a accident.
Well, it is having your engine start to knock after only 10 minutes of running time. So I pulled the engine back out of the truck and took it apart. What I found was I forgot to torque the mains. I guess I was in a hurry or someone came in the shop and bothered me and I must have forgot. Well, it didn't do any damage to the engine except for the bearings. So I went and got another set of mains and rods and rings and a complete gasket set. This time I am not making that mistake again. When I seen the bolts I couldn't believe I done that. All was finger tight. I am one lucky guy. It pays to double check our work and when doing a engine get everybody out of the shop. I upgraded on the rings this time to poly rings. Longer life wear.
Check out Patches
Old 05-12-2015, 10:18 PM   #2406
colgad
colgad's Avatar
Re: 1968
Sorry to hear that bad news George! Glad no machining was necessary.
I am swapping engines (due to a knock) in my newly acquired Jimmy but I have not started the job yet. I knew it was bad when I got it.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 05-12-2015, 11:47 PM   #2407
sduckworth13
sduckworth13's Avatar
Re: 1968
Dang George, sorry to hear about the engine. Sounds like you have it under control. Good luck.
Scott
sduckworth13 is offline   Reply With Quote
Old 05-13-2015, 01:36 AM   #2408
Xeen
Xeen's Avatar
Re: 1968
Sorry to hear that George, chin up you got off cheap considering it could have been a lot worse, plus you got to improve it by installing moly rings.
Old 05-13-2015, 02:05 AM   #2409
swamp rat
swamp rat's Avatar
Re: 1968
Oh man, real glad there was no damage, just double check and triple check everything when it go's back together, torque, plasti gauge the new bearings, pistone and rods, everything. Good luck!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 05-13-2015, 09:25 PM   #2410
gdavis
gdavis's Avatar
Re: 1968
Guys thanks for the incouragement .I worked on the cleaning the parts today. Got everything cleaned and wrapper up. I sprayed everything down with WD-40 so no rust would appear. I cleaned the crank and there was a few real light scratches on the main, so I sent the crank out to be polished. I probably could have removed them with some emery cloth but I went ahead and had some machine work done on the crank. This way I know that it want give me any problems. It would always be on the back of my mine every time I heard a noise if I didn't so what the hey. It's only 60.00 so I will get it back Friday morning. My plans are for Monday morning put the engine back together. So by Friday I will have the motor back in the truck and running.
Check out Patches
Old 05-13-2015, 09:33 PM   #2411
gdavis
gdavis's Avatar
Re: 1968
pictures of the clean parts
Check out Patches
Old 05-13-2015, 09:41 PM   #2412
gdavis
gdavis's Avatar
Re: 1968
I like the army green color. It makes it look tuff, George
Check out Patches
Old 05-16-2015, 02:02 AM   #2413
swamp rat
swamp rat's Avatar
Re: 1968
I'd go ahead and dump that oil flter now and fill a new one with oil before you spin it on to the block, cheap insurance.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 05-16-2015, 09:06 AM   #2414
Xeen
Xeen's Avatar
Re: 1968
Agreed and make it a Fram tough guard while you are at it.
Old 05-16-2015, 11:44 AM   #2415
gdavis
gdavis's Avatar
Re: 1968
Yea I will get a new filter I only keeping the old one until I need it. This was it will be clean and no dust will get in there.
Check out Patches
Old 05-16-2015, 11:47 AM   #2416
gdavis
gdavis's Avatar
Re: 1968
Yea that filter came with the oil I was using to break in the engine. I always use Fram filters. I am looking forward into putting this engine back together
Check out Patches
Old 05-16-2015, 11:51 AM   #2417
gdavis
gdavis's Avatar
Re: 1968
Monday, I will be putting the engine back together. I have a friend that is a mech. and he will be helping me this time. two heads is better than one. I picked up the stuff that I know I will be needing to put the engine back together. Also the machine shop only charged me 20.00 for the polish of the crank. He said I have enough expence as it was. so he cut me a break. here is a few pictures of the items and the crank.
Check out Patches
Old 05-18-2015, 09:04 PM   #2418
gdavis
gdavis's Avatar
Re: 1968
Got the motor over hauled today. A friend came over and helped me out. I will re marry the transmission to the motor tomorrow and hopefully install it on Wednesday.
Check out Patches
Old 05-18-2015, 09:53 PM   #2419
Xeen
Xeen's Avatar
Re: 1968
I'm glad to hear it George, good job on a fast turn around time.
While the motor is out you should take advantage and seal up the holes in the drivers side firewall lower pinch weld.
Old 05-18-2015, 10:06 PM   #2420
colgad
colgad's Avatar
Re: 1968
Great news George! Hoping it all goes great from here.
Got my Jimmy's engine pulled out and ripped apart. It was the number 6 rod bearing (spun). I am junking the 89 350 engine (single rear main seal but not a roller motor) and using my 5.3 Lsx engine. It will take me longer to install but better in the end.
Again, great new glad nothing was damaged
Old 05-19-2015, 07:58 PM   #2421
gdavis
gdavis's Avatar
Re: 1968
motor back in the truck. But I do need a clutch delete plug a steel one. the platic ones just isn't worth the trouble putting them in.
Check out Patches
Old 05-19-2015, 07:59 PM   #2422
gdavis
gdavis's Avatar
Re: 1968
yea me too. I had help getting the motor back together. good luck with the LS engine
Check out Patches
Old 05-19-2015, 08:01 PM   #2423
gdavis
gdavis's Avatar
Re: 1968
Today, I married the transmission to the engine and installed it back in the truck. I will have a few items to button up tomorrow.
Check out Patches
Old 05-19-2015, 11:34 PM   #2424
swamp rat
swamp rat's Avatar
Re: 1968
Nice work George!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 05-22-2015, 07:09 PM   #2425
gdavis
gdavis's Avatar
Re: 1968
Nice work George!
Thanks a lot.
Check out Patches
