#2426 |
Re: 1969 Short Wide
Thanks for the extra pictures! Your truck looks great. I am so far seat from where you are, but I will get there... eventually
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
#2427 |
Re: 1969 Short Wide
One day when I grow up.... Truck looks amazing, and I may just have to "borrow" that filler setup idea for mine.
#2428 |
![]() Join Date: May 2013
Re: 1969 Short Wide
It's been a while since I checked in and I missed a lot. Your truck turned out absolutely amazing.
67 SWB LS2/4l70e... http://67-72chevytrucks.com/vboard/s...d.php?t=587435 |
#2429 |
Re: 1969 Short Wide
very cool!!
Dean 1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187 in God we Trust ![]() |
#2430 | |||
Still Learning
Re: 1969 Short Wide
Thanks Dean. |
#2431 |
![]() Join Date: Mar 2011
Re: 1969 Short Wide
Mike,
Have you been putting some miles on the truck? How's the LS working for you? Looks great buddy! |
#2432 | |
Still Learning
Re: 1969 Short Wide
Apparently, I didn't get everything perfect so there was a howl noise when coasting. I took everything back apart last night and am going to try to set again tonight. Hope to be back on the road soon. I will get some pictures of the progress. |
#2433 |
Re: 1969 Short Wide
Looking forward to this update because I've got this in front of me too. I know you'll show us the right way and some trick way to do it! What set did you have running in the video?
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 ![]() |
#2434 | |
Still Learning
Re: 1969 Short Wide
![]() As for the video, I was running the stock 2:73 gears. I know I like the way the 3:73 gears pull much better, I just couldn't deal with the howling noise. |
#2435 |
Still Learning
Re: 1969 Short Wide
Random Pictures of what I have going in the shop.
#2436 |
Re: 1969 Short Wide
Mike your pinion depth is too shallow. You need to get it moved deeper into the mesh.
I have done hundreds of rear ends and I can tell you that when I first started doing them it was a lot of trial and error. The biggest thing is to not get frustrated and just take your time. Luckily I was young and in a dealer when I was learning and was shown some of the tricks to make pinion shim corrections quickly. Another big thing when checking your patter is to make sure you have some drag on the unit. This will ensure you get a good read every time. Let me know if you have any questions, I am sure I can help you out. I am swapping in a new 3:42 and posi currently in a 12 bolt this weekend.
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
#2437 | |
Still Learning
Re: 1969 Short Wide
If you don't mind me pestering you about the setup send me a pm. Thanks. You have an awesome project going yourself. BTW I think 3:42 would be better choice for my setup but I had the 3:73s already so I figured I'd give them a try. |
#2438 |
Re: 1969 Short Wide
Sorry to hear about the rear end problems. But you will get it soon. It makes the signature line even more real "Built not bought". Another story to add to the truck.
Dwight |
#2439 | |
Still Learning
Re: 1969 Short Wide
![]() I have it back together and on the road again. I am now confident I can set up my new posi when I get to that point. I wanted to say thanks to Mark (Crash_OK) for helping me pull an extra rear end I had in a 68 chassis my stash. It was in a tight spot and I couldn't have gotten it out without your help. I also had a bunch of help setting up the gears from member boostedc10 (Thanks Brandon!). |
#2440 | |
Re: 1969 Short Wide
![]() Now get the front aligned and drive it...!!
Mark ----------------------- Crash's 69 4x4 SWB Crash's Roof over Lake Home Crash's 1988 Land Cruiser Build |
#2441 |
Still Learning
Re: 1969 Short Wide
I'm glad to have it back on the road too. I am taking it to alignment shop this week. I will definitely be driving it some too. Count on it.
#2442 | |
Re: 1969 Short Wide
#2443 |
Still Learning
Re: 1969 Short Wide
Pics from gear swap:
Setting backlash for the hundredth time ![]() Not right: ![]() ![]() Back together ![]() |
#2444 |
Re: 1969 Short Wide
Way to go on the R&P setup Mike!
#2445 |
Still Learning
Re: 1969 Short Wide
Thanks. Just chalk up more of my phrase "still learning" to the build.
#2446 |
Still Learning
Re: 1969 Short Wide
Don't worry I will hit you up. Thanks again
#2447 |
Re: 1969 Short Wide
Glad you got 'er back on the road. I's eskeered o' them geer thangies.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#2448 |
Re: 1969 Short Wide
Good to see you rollin' again Mike...
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
#2449 |
![]() Join Date: Dec 2006
Re: 1969 Short Wide
Glad to see you got the gears figured out Mike, now you can get back on the road and enjoy her.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#2450 | |
Still Learning
Re: 1969 Short Wide
Thanks Jason Thanks Keith |
