Old 12-10-2015, 09:18 PM   #2426
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
got the fixed (not shortened) drive shaft back today, if you look closely at the before and after pictures you can see that once all the whatever was cleaned out of it it actually goes in about an inch more now, see how much closer to the center bearing it is now, it used to be about 1 1/2 away now its like 3/8 away
also had the center bearing replaced which included the new rubber doughnut - out the door for just shy of $80 bucks
plan on installing it either tomorrow after work or on Saturday, will update you all if it is the right length then
Gregski is offline   Reply With Quote
Old 12-10-2015, 10:00 PM   #2427
rgunlock
rgunlock's Avatar
Re: Restoring Rusty
Sounds like $80 well spent. I'm sure it will fit fine now.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 12-10-2015, 10:13 PM   #2428
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: Restoring Rusty
Good enough!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 12-10-2015, 10:56 PM   #2429
enaberif
Re: Restoring Rusty
Wow looks good!
enaberif is offline   Reply With Quote
Old 12-11-2015, 09:57 PM   #2430
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so we had a good day today, the drive shaft fits, I mounted it back up and with wheels on the ground we have 3/8th or 1/2 inch of additional going inability that should do for now
I wanted to share pics but my stupid battery died in my phone, so I will share some tomorrow
I went around and tightened everything back up since the entire rear end was dangling finger tight as we were trying to get that driveshaft to fit, so now its all tightened and good
Old 12-11-2015, 10:04 PM   #2431
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
naturally you lower the truck, and if you get past the driveshaft problems then something else creeps up, in our case it was the rear brake rubber line that attaches to the differential and feeds the two wheels
well I'm glad I saw it, or there would be no rear brakes soon
note how we fixed it, RoadKill would be proud (who watches that show on YouTube?)
Safety Police, this is a temporary fix to drive the truck to the side of the garage, we will get a longer rubber line soon enuff and route it proper like, or maybe go turn downs on the exhaust right after the mufflers and loose the bendy pipes over the diff, hmm - what say you?
Old 12-11-2015, 10:05 PM   #2432
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
the fun continued...
as you recall we had to remove the fuel tank to grind off the rivets on the passenger side leaf spring hanger, so today we had to put the tank back on, but first, we had to drain it of gas, yes it did have TEN GALLONS of fuel in it, that's 5 trips to the wifes thirsty Honda Pilot with a 2 gallon red bucket
FUN LEVEL = 2
Old 12-11-2015, 10:10 PM   #2433
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
we tapped the old fuel sending unit out with a punch wrapped in electric tape and a hammer, and a few Hail Marys
I am glad the new single outlet sending unit came with a new rubber O ring and a new round metal retainer ring loop thingie, since in a bit of irony the old rubber O ring became hard, and the old metal retainer loop became soft, go figure
so here they are the old style sending unit and it's modern day replacement
Old 12-11-2015, 10:13 PM   #2434
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
wanted to show you the new unit in the tank and how a one man tank mounting operation goes, picture a dude under the truck working the jack handle with his foot, ha ha
but again the phone / camera battery died
so the tank is on the truck finger tight, I will button her up tomorrow as it got dark and a visitor came by, so it was time to stop wrenchin
tomorrow progress continues, hopefully we'll get a test drive in, and a pic of the truck on the ground
Old 12-12-2015, 09:49 AM   #2435
rusty76
rusty76's Avatar
Re: Restoring Rusty
Glad too see things back in shape. I watch Roadkill religiously. Been watching it since day uno.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 12-12-2015, 10:38 AM   #2436
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
That's my boy, they do have a square body in their [ahem] fleet:
The Muscle Truck
Old 12-12-2015, 06:02 PM   #2437
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so since I went to a single line fuel sending unit I decided to get a brand new vented gas cap, they had the fancy locking one, but it was made of plastic so I went for the stock looking metal one
here are the old and new caps compared, I wonder if my old one was even vented, as it looks different
Old 12-12-2015, 06:04 PM   #2438
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and here's the new one
Old 12-12-2015, 06:05 PM   #2439
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and here they are side by side for comparison
Old 12-12-2015, 06:08 PM   #2440
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
then I decided to go back and shim the hangers as the new ones are 1/4 wider than the stock ones, (in the pick it looks like maybe an 1/8th but that's because the bracket was bent in from bolting it in too much), so a quick trip to Home Depot to get some 1/2 grade 8 washers, bought 9 but 3 on either side seemed to do the trick
the distance from the frame to the inside of the hanger appeared to be the same between the old and new hangers, so I only shimmed the outside
Old 12-12-2015, 06:11 PM   #2441
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
ok, and here is the Money Shot, man I think it turned out great, I luv it
Old 12-12-2015, 06:55 PM   #2442
flashed
Re: Restoring Rusty
Looks good .
flashed is offline   Reply With Quote
Old 12-12-2015, 07:04 PM   #2443
enaberif
Re: Restoring Rusty
If you look at your old cap you can see the hole in the middle which allows the venting.
Old 12-12-2015, 07:10 PM   #2444
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so before we look at the Before and After shots, we all want to know how long did this take, how many hours did it take to lower this truck
lets see, we started on THURSDAY (October 8th) and finished on SATRUDAY (December 12th)
so what was that 3 days [ahem] weeks, what? over 2 MONTHS?!
Old 12-12-2015, 07:57 PM   #2445
Jake Wade
Jake Wade's Avatar
Re: Restoring Rusty
It looks much better.
Jake Wade is offline   Reply With Quote
Old 12-12-2015, 08:20 PM   #2446
rusty76
rusty76's Avatar
Re: Restoring Rusty
Sweet
My build thread
Crossmembers CC
Old 12-13-2015, 11:56 AM   #2447
68Timber
I know the pieces fit
68Timber's Avatar
Re: Restoring Rusty
Looks really good. What's next? Swapping the trans?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 12-13-2015, 12:35 PM   #2448
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Winter Plans
Thanks, I appreciate the positive feedback. That's a big job as I plan on pulling the enjin out to do it this time, so it will have to wait till Spring. I think I will button it up for the Winter (December 22nd being the official First Day) and work on things that don't require too much grease or painting.
Hope to Dyno Test it again in January (funds required)
Possibly install some shoulder belts.
Install one of the heavy duty truck floor mats (from LMC Truck)
Install some black mirrors that actually fit the truck.
Fix my new (used) 1978 speedometer.
We still got that Dash Pad to sand and paint.
pesky stuff like that while actually driving the truck till March 20th aka The First Day of Spring.
Old 12-13-2015, 01:19 PM   #2449
LeesTruk
Re: Restoring Rusty
Hey Gregski. When you see the working results of all your labors, it makes all those cuts , bashed fingernails, and colorful language seem worthwhile, don't it? Enjoy your truck this winter. Lookin' good
Lee
LeesTruk is offline   Reply With Quote
Old 12-14-2015, 12:58 AM   #2450
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Lee
"colorful language" that's it, where did you hide the microphone in my garage? ha ha
