09-20-2021, 07:51 PM | #2426 |
Re: What did you do to your truck today.The 3rd chapter
To day I installed a new set of Fiat 500 black leather seats. Now I get to build a custom center console.
09-21-2021, 01:18 AM | #2427 |
Pulled 'em outside while I pack up the garage to move.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. |
09-21-2021, 09:19 AM | #2428 |
Looks good. Now you have some engine work to do to get it to match the seats.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
09-21-2021, 10:29 AM | #2429 |
I think those ^^^^^ seats might look better without the headrests .......
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
09-21-2021, 12:47 PM | #2430 |
Good call on the headrest, I will remove them and see. Could always make some rectangular ones. Or turn these seats into shop chairs.
09-21-2021, 12:55 PM | #2431 |
09-21-2021, 12:56 PM | #2432 |
09-21-2021, 02:01 PM | #2433 |
70+ ( Old Skool Club )
Tried to hookup horn and signal light cancellor thing between the new sport steering wheel and the original tilt wheel on my truck but coudn't figure out how the yellow wire connects to the cancellor so horn will work.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
09-21-2021, 02:09 PM | #2434 | |
1) Spring 2) Aluminum post, with large end facing into the tube first 3) Red plastic lock ring, stuffed into the top of the tube The aluminum post was then spring loaded, and it contacted a tab on the back of the horn button mount. It looks like you've got the stock components inside your original broken canceling cam, but the aluminum post might be mounted in there upside down. |
09-21-2021, 07:14 PM | #2435 |
Mr. Cheyenne
Got my new Lloyd's Embroidered floor mats today, ordered from high-end-motorsports.com.
YAY, love the blue bowtie! They have a few different options for logo, text, and colors. They also come with anchors to "screw" into the trucks carpet to keep the mat from moving around on the driver side. Though I am not so sure how well those anchors will stay.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
09-21-2021, 07:46 PM | #2436 | |
09-21-2021, 08:06 PM | #2437 |
You guys are right again. I removed the head rest...much better look
09-22-2021, 07:27 AM | #2438 |
[QUOTE=cab4word67;8974192]You guys are right again. I removed the head rest...much better look
Agreed, the truck will look better when looking from behind the truck thru the back window also. Rich, very nice mats, love the seats n all as well
09-22-2021, 01:14 PM | #2439 |
These mite be a repeat that just didnt show up?
09-23-2021, 11:00 AM | #2440 |
Took my valve cover off to see what caused all the noise under the hood yesterday (trip home on AAA flatbed).
One of my rocker arm studs broke off, and other than running rough there was a lot of nasty clattering. Not sure yet what caused it or what else may have broke. Truck was running great with 200 miles on an engine "refresh" that included installing a mild COMP cam. I drained the oil and it was perfectly clean with no metal. I am sure I'll have more surprises when I pull the head off.
Steve/NH 1967 K10 327 Short Bed Stepside 2008 F350 Power Stroke 2007 BMW X3 2020 BMW 540xi 1995 Harley FLSTC |
09-23-2021, 11:24 AM | #2441 | |
1971 SWB step side: Original NM Forestry and then NM Fire truck |
09-23-2021, 11:51 AM | #2442 |
OK I recently built a ford 289 / 480 lift and after snapping off 4 of my studs in a total of 60 miles I found I had spring bind. Check your adjustment. If adjusting cold make sure you can spin the push rods when the valves are closed. If you adjusted while running its just past clatter then 1/2 turn, and before you pull the head make sure you can get a feeler gauge in between the springs when at full lift (about 5-10K). You are ether to tight or lifting more than the valve can go down.
09-23-2021, 12:23 PM | #2443 | |
My cam is a COMP cams CS 268H-10 grind which has a valve lift with factory rocker arm ratio of 0.454 int./0.454 exh. I also installed the COMP recommended 981 valve springs which have a bind height of 1.150in. Edit: Forgot to mention that it is a 220HP 327ci with factory heads.
Steve/NH 1967 K10 327 Short Bed Stepside 2008 F350 Power Stroke 2007 BMW X3 2020 BMW 540xi 1995 Harley FLSTC Last edited by ohboy321; 09-23-2021 at 12:29 PM. |
09-23-2021, 01:10 PM | #2444 |
Stock rockers can't take some high lifts
09-23-2021, 07:36 PM | #2445 |
All done. Still leaks from the input shaft though
09-23-2021, 07:53 PM | #2446 |
I got my roller tip rockers from Amazon, they are Crane. I would send you the link but they were for a SBF
09-25-2021, 04:01 PM | #2447 |
Raptor lined the inside and epoxy primed the outside of my rear fenders. Raptor lined my steps as well so I won’t freak out when someone actually steps on them.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
09-26-2021, 01:45 PM | #2448 |
Good call on the steps. I used anti slip tape 20 years ago and seems to still be in place
09-26-2021, 09:38 PM | #2449 |
09-27-2021, 12:22 AM | #2450 |
They are honda Accord I believe. Out of the 4 switch's I got 2 windows, the tilt hood, and door looks/unlock. And the window lock is my torq converter lock up for the hwy.
