05-28-2021, 04:09 PM | #1 |
Automatic transmission tilt steering column
This a GM automatic tilt steering column for a truck that was converted from a van. The neutral safety switch was moved to the correct truck location on the column & the old hole was filled back in & it now has the correct length splined shaft for a truck. The column was as stripped & cleaned, checked for worn & broken parts & replaced as needed. All bearings were greased. The column was painted satin black & had the following new parts installed. New turn signal switch & wiring harness with correct horse shoe shaped wiring harness connector, neutral safety switch, indicator lense & indicator pointer, upper & lower rubber seals with correct firewall retainer, new flasher knob, lower bearing adapter, new shift lever, turn signal lever, & tilt lever. This is really a nice column & is now a clone to a original. Ready to bolt in. $ 435.00 plus shipping. No shipping to Alaska or Hawaii / Postal Money a Order or Personal Check
Posted via Mobile Device |
05-31-2021, 10:22 PM | #2 | |
