06-12-2022, 11:44 AM | #1 |
Anyone running Edelbrock 7116 Vortec intake with carb heat?
Putting L31 heads on an earlier 350 block for my K20. Truck will be driven in the winter so I will need to use the heat plenum on the 7116 at least seasonally. I would like to run exhaust thru there, but plumbing it, especially with heat resistant shut off valves might be an issue. Running coolant would be easier, but I wonder if 180-190 degree water would keep it warm enough, especially as the carb sits so far above the plenum. Looking for input from anyone who has dealt with this.
06-14-2022, 02:39 AM | #2 |
Re: Anyone running Edelbrock 7116 Vortec intake with carb heat?
For what it's worth my L31 runs great in the winter with a summit no air gap no heat cross over Intake.
06-14-2022, 09:33 AM | #3 |
I can’t get away with that in this climate. I’ve run old school heads/intakes here, but with the exhaust crossover blocked. 3-4 times on the way to work I’d have to pull over to let the carb thaw. If i jumped out quickly enough and looked I could see the carb covered with frost. The laws of thermodynamics at work, I guess
06-14-2022, 10:52 AM | #4 |
To help with carb icing you might need to limit cold air flow.
The major cold air source is thru the rad. Easiest way to limit that is with a winter front. I used the ones with flaps you could open when needed. Like this. https://www.amazon.ca/Fia-Custom-Win.../dp/B00075X8RA |
