Old 05-23-2022, 01:51 AM   #1
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
suspension (airbags)
So for some odd reason my passenger side seems to ride as if there is no shock installed. Bounces a lot more than the driver side. I've replace the shocks with new ones. but i still get that passenger side bounce. not sure if maybe my A arms shafts might need to be replace maybe?
Thanks for help...
Sick5 is offline   Reply With Quote
Old 05-23-2022, 05:24 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: suspension (airbags)
IHmmm that sounds strange, do you have sway bars?
Old 05-23-2022, 01:08 PM   #3
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Yeah i got that as well. I know it can't be the shock angle since both side are the same. Maybe it's my cross bar shaft.
Old 05-24-2022, 08:25 AM   #4
SCOTI
SCOTI's Avatar
It could be bind. If you're not sure, re-check things to eliminate that.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-24-2022, 11:22 PM   #5
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
now im wondering where could of i be getting a bind? shafts too tight?
Old 05-24-2022, 11:34 PM   #6
SCOTI
SCOTI's Avatar
Yes. Unless you're 100% sure, it's worth checking.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-25-2022, 10:11 AM   #7
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
So the shaft needs to be loose enough to turn by hand right?
Old 05-25-2022, 10:54 AM   #8
SCOTI
SCOTI's Avatar
There shouldn't be much resistance on the older threaded rubber lined steel bushings when pivoting them from compression to extension. Check upper & lowers.
The later 73-87 rubber pieces will have more resistance/bind.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-25-2022, 10:06 PM   #9
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
ok ill re check them and see thanks for the info.
Old 06-04-2022, 10:54 AM   #10
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Issue was fixed when i installed new rear shocks
Old 06-04-2022, 12:45 PM   #11
SCOTI
SCOTI's Avatar
Thats good then 😎
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-05-2022, 03:47 PM   #12
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
yeah thanks for the help Scott
Old 06-05-2022, 04:16 PM   #13
SCOTI
SCOTI's Avatar
Anytime. I ruled your shocks out because of the mention about them already being replaced. You wouldn't expect that so it makes trouble shooting more difficult.
Share some pics!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
