10-30-2024, 10:18 PM | #201 |
Re: 1967 buick special wagon
With the front and rear of the wagon looking so aggressive, the sides between the tires look so skinny. So I flipped the bracket that mounts the side skirt, spaced it out with 1.5 x 3 inch rectangular steel spacers and pushed the skirts out 5 inches in total.
Josh
1967 Buick Special wagon 1968 Jeep Wagoneer 1958 Chevy Panel Truck 2017 Suzuki M109R |
10-30-2024, 10:28 PM | #202 |
With the bracket flipped and the 3 inch spacers, the skirts moved out about 5 inches. Now I have to figure out how to best fill the space between the body line at the bottom of the doors and the skirts.
Josh
11-07-2024, 02:33 AM | #203 |
Using cardboard templates to figure out the filler panels for the side skirts. I painted it white for better visual reference.
Josh
11-07-2024, 02:40 AM | #204 |
Nice.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
11-07-2024, 11:07 PM | #205 |
I started working on making wedges for the bottoms of the doors.
Josh
11-07-2024, 11:12 PM | #206 |
I started mocking up the driver's side when my dad's friend walked into the shop and we were discussing the design. I told him it wouldn't work as a single piece, and mocked it up to show him. Turns out, I was wrong. It totally works as one piece. I'll just need to sweep the leading edges of the extensions back just a little. So, Version 2.0. They'll be one piece.
Josh
11-16-2024, 06:29 PM | #207 |
I bought a length of 16 gage sheet metal for the skirt filler panel
Josh
11-19-2024, 11:07 PM | #208 |
The passenger rear tire keeps rubbing on a bolt head under acceleration. It's barely touching the raised letters on the sidewall, like the dot numbers and things like that. Well I got curious enough to remove the bolt to see what it held on. Apparently there are vibration dampeners on either side of the rear suspension cradle. Well the bolt heads snapped off, so I just cut the dampeners off with a sawzall, and now they're plenty of clearance.
Josh
11-19-2024, 11:12 PM | #209 |
I removed the front bumper and air dam. I cut out the center panels and made new ones that have a smoother transition to the chevelle bumper I used. There's still a lot of finish work to be done, but I think it'll look a lot better this way
Josh
11-24-2024, 01:31 AM | #210 |
I separated the air dam and bumper. I painted the air dam white and cleaned the bumper with steel wool and some paint cleaner. I installed them on the wagon and took a few vantage point pictures to show the ground clearance and the general stance.
Josh
11-24-2024, 09:02 PM | #211 |
I'm putting the cargo windows back in, so I can road test longer distances. The driver's side fit snuggly in the pocket. I just held it in place with a few self tappers against the chrome trim. The trim has been bonded pretty securely to the glass.
Josh
11-24-2024, 09:08 PM | #212 |
I made a plywood panel to fit in the passenger cargo window pocket since it's a lot worse off and will need more repair work.
As I was putting the tail gate glass in, the bolts for the tracks broke off. So I drilled them out and installed riv-nuts. Josh
11-29-2024, 01:20 AM | #213 |
First road trip successfully in the books. 750 miles round trip from Atlanta to Biloxi, ms and back. The only thing that broke was the left tail light fell off. Apparently the bolt holding it on vibrated loose and the light was dangling by the wiring. Since the bolt in question requires the tail gate to be opened and I wedged the back glass up and in place for the trip, I secured the light with some muffler strapping and some self tappers.
On the way down, I was running 83 mph, getting 18.5 mpg. On the way home, I set the cruise to 75 and got 20.6 mpg. Not too shabby, if i do say so myself Josh
Yesterday, 09:27 PM | #214 |
As much as I like the srx tail lights, they just seemed a little too bulky and stuck out passed the rear bumper. I finally found a cadillac ats in the junk yard, so I grabbed the tail lights, harnesses and cut out the quarters for the mount buckets. These lenses are cracked, but I'm going to buy the clear lens tail lights with the integrated amber turn signals, so these are just for mock up. But the ats lights do not have reverse lights, so I have to either find lights that fill in the gap between the bumper or get a 65 el camino bumper with reverse lights. I'm keeping my eyes peeled for some late model pick up fog lights that mount on a slight angle in the front bumper to use a reverse lights.
Josh
