10-22-2024, 11:11 PM | #1 |
Blower motor issue
I’ve got a 1984 C10 and over the weekend my heater blower stopped working. I’ve been chasing wires a trying to see what happened and I discovered that the fuse for the blower is grounded. It didn’t pop or anything, but when I hook up my test light to it, as in the alligator clip side to a positive lead and the probe end on the fuse, it’s grounded. Is that correct? Doesn’t seem right.
If not, anyone have any idea why or how that happened and what I can do to fix it? Let me know if any further information is needed. Thanks in advance! Last edited by rhamer88; 10-23-2024 at 12:03 AM. |
10-23-2024, 11:59 AM | #2 |
Re: Blower motor issue
If you have the alligator clip hooked to a 12+ source and the probe end to the fuse and the heater switch is in the fan run position the test light should light as the probe is finding ground through the fan motor.
I'm not familiar with the early 80's C10 heater circuits but I am familiar with the late 80's and early 90's S10 circuits. I can't imagine they are very different. I would start by disconnecting the blower and with the test lights alligator clip on the battery's negative post put the probe in the rubber connector that was connected to the blower. If things are working correctly you should be able to see differences in the test light as you cycle through the different settings on the blower control. If you get no light and your positive the fuse is good carefully inspect the connector as they can break inside the rubber boot. If that appears to be good move the probe to the purple wire on the resistor mounted on the heater box and test again. If still no light move the probe to the tan wire on the resistor. Here you should have the light on with the fan speed in low. If still no light ad you know the fuse is good then you will need to pull the heater controls. My S10 knowledge probably won't help you as the switches are different switches. Over the years that I've owned S10's I've had numerous blower switches fail, 2 of connectors at the blower motor fail and one resistor fail. If you inspect the blower control you should be able to visually see if it has overheated and failed. I hope this helps.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-27-2024, 02:14 PM | #3 |
1st place I would look is the blower resistor. Comes out with 2 screws. Normally you just lose a speed but it can fully open as well.
Also look inside the blower resistor connector for melting. If an AC truck, theres a relay mounted to the evaporator box that feeds power to the blower resistor. But start with the resistor. |
10-28-2024, 01:50 PM | #4 |
Do you have AC in your truck or just the heat controls?
79 Chevy 2wd BIG10 350 TH400 |
10-29-2024, 12:46 AM | #5 |
I would check the resistor to check the Plug as none A/C is two wire plug and A/C plug 4 to 5 -6 rust some time there just to rusty bad connection or may strict out spring crack at the pin. on the fire wall passenger side
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
11-07-2024, 02:31 AM | #6 |
Thank you everyone for the replies and help, I greatly appreciate it.
I replaced the resistor and the relay and neither fixed the issue. After tracing wires and diagnosing problems, I’ve discovered that I’ve got a short somewhere beyond the HVAC system. The orange accessory wire coming from the steering column is grounded, and that’s as far as I’ve gotten at this point in time. If anyone has any idea why or where that wire is getting ground from, I would greatly appreciate any insight. Thanks again! |
11-07-2024, 07:13 AM | #7 |
Pull the motor and test. A locked up motor or one that isn't spinning can appear as a ground to test instruments.
Motors can quit spinning because of mouse nests clogging up the works or just because it goes bad. |
11-07-2024, 11:15 PM | #8 |
The blower starts blowing when 12V is applied to the terminal.
Question for everyone; is the little stud on the starter supposed to be grounded? (Pic attached for reference) My test light is showing that stud that the smaller wire attaches to to be ground (with the starter still in the truck obviously, key on or off). Is it possible something within the solenoid has broken and that stud is now supplying ground rather than 12 volts? |
11-08-2024, 12:01 AM | #9 |
Are we talking about a starter or a blower motor.?
Because the blower should ground to the firewall by case pin screw bolt, or some have a ground tab connection wire. I forget now think there is 5 or 6 screw bolts holing the case one of the firewalls one is the ground, and it does not keep in line all the other screw bolts.
11-08-2024, 12:07 AM | #10 |
The starter should ground throw the case to the motor.
11-08-2024, 01:57 AM | #11 |
I thought maybe that circuit drew power from something to do with the starter. Not too great with electrical.
Long story short, I found the issue. There was a short in the horn circuit that was shorting out the IGN ACC circuit (doesn’t make much sense to me, but it fixed the issue). Now the new issue I’m having is the fuse for the blower blows when fan speed is on high. Any idea what the heck would be causing that to happen? I replaced the blower relay and resistor while chasing down this other issue. Possible one of those is bad out of the box? EDIT: I figured it out, it was the brand new relay that was bad. I put the old one back in and the fuse stopped blowing. Imagine that! Last edited by rhamer88; 11-08-2024 at 03:20 AM. |
