Old 05-01-2021, 01:52 PM   #1
hubdawg
Amp location
Anybody mount an amp in the center console, would it have enough circulation. I have a sub amp located under the passenger seat and looking for a location for a four channel amp for the front and rear speakers. Did a mock up under the drivers seat and it was a no go. I'm 6'3 so raising the drivers seat is not an option. 4 Channel to passenger and relocate sub amp? Sub is behind rear seat in a custom box. Any Ideas?
hubdawg is offline   Reply With Quote
Old 05-01-2021, 02:59 PM   #2
hemi43
hemi43's Avatar
Re: Amp location
My amp and SUB are in here !
If you're using a Softopper or no top, dont even waste your time putting in a stereo unless you want to listen to tunes while parked. Too noisy when driving.
hemi43 is offline   Reply With Quote
Old 05-02-2021, 12:27 AM   #3
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Amp location
Now that's cool
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 05-04-2021, 05:48 PM   #4
ochre1971
ochre1971's Avatar
Re: Amp location
I have 2 amps under rear seat, but they're small-ish in size, one for the speakers and one for the subs. FWIW, I can hear mine great going down the road with no top.
ochre1971 is offline   Reply With Quote
Old 05-05-2021, 01:13 PM   #5
hubdawg
Re: Amp location
Ended up with 4 channel under the passenger seat and sub amp under the rear seat
Old 05-05-2021, 01:32 PM   #6
A1971Blazer
A1971Blazer's Avatar
Re: Amp location
My amp is under the driver seat...but I had to modify the slider brackets so it would fit
Didn't want it under the passenger seat..exposed every time the seat was tilted forward.
I also made some shims from black plastic to raise the rear seat enough to put the sub under it.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 05-05-2021, 07:02 PM   #7
SunSoaked
SunSoaked's Avatar
Re: Amp location
That's badass!
SunSoaked is offline   Reply With Quote
Old 05-09-2021, 07:43 PM   #8
Mike C
Mike C's Avatar
Re: Amp location
I have a 5 channel amp under the rear seat. It drives a single 12" in a box behind the back seat, a pair of 6 1/2" speakers in the side panels right behind the front seats and a pair of 4"s in the door panels. 50x4 and 150x1 if I remember correctly.
I have NO problems hearing my tunes with the windows zipped out of my SpecialtyTopCo soft top.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-09-2021, 10:18 PM   #9
SunSoaked
SunSoaked's Avatar
Re: Amp location
Boom.
