Old 02-02-2011, 10:58 AM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Cam selection help
I am trying to nail down a good cam for my build. I am looking at the Texas Speed Torquer V2 (232/234 @.050" .595/.598) and I have a choice of 112, 113, or 114 lobe seperation. What seperation should I go with? Does this sound like a good cam? I am going to keep the stock Truck intake for the time being and upgrade it later on down the line to a Vic Jr w/elbow or Pro-Flo XT. Help me Please!!
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 02-02-2011, 08:30 PM   #2
Notch1988
Notch1988's Avatar
Re: Cam selection help
It's a very good cam with supporting mods (headers, gears, convertor). Personally, I'd go 112 lsa for the idle.
Notch1988 is offline   Reply With Quote
Old 02-02-2011, 10:55 PM   #3
swb85
On a budget like Fred Sanford
swb85's Avatar
The lower lsa will produce:
more overlap, rougher idle
narrower power band but higher peaks at lower rpm
decreased piston to valve clearance
The higher lsa will produce:
less overlap, smoother idle
broader power band with slightly lower peaks but carry further past peak
increased piston to valve clearance
I personally like tight lobe separations on my n/a motors for the torque curve they produce.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 02-03-2011, 04:07 AM   #4
matthew20061
69' Chevy Stepside
matthew20061's Avatar
It sounds like a pretty good cam to me, but I don't know the specifics of your engine, ect. I would personally go with the 112 LSA like swb85 said, that way you get a nice sounding idle!!
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 02-03-2011, 08:06 AM   #5
softballnrd27
The motor is going to be stock internally(rebuilt), Stock 317s, aftermarket intake, and headers with the supporting converter and gears. I will more than likely throw a 150 shot of funny gas on it when I go to the strip.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 02-03-2011, 05:59 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I called TSP when I was looking at the torquer and a few other cams. I asked pretty flat out; "I've got a stock 6.0, with larger injectors, and I'd like the most cam I can get without PTVC problems" After a few minutes discussing my goals (similar to yours, stock mostly with some juice possible in the future), and they suggested the Tsunami, in 111 LSA. Given, it may hump more than some like for street manners but its a hefty cam.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-03-2011, 08:06 PM   #7
Notch1988
Notch1988's Avatar
Do you have this cam in yet? Experience with it?
Old 02-04-2011, 01:33 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The cam is in the engine, but the engine is not yet in the truck. Its -3 WC here and we just got 20" of snow...haven't been to the garage in a bit lol.
Old 02-04-2011, 09:37 PM   #9
85burb
85burb's Avatar
Got a 111LSA in mine and boy let me tell you it sounds great. Power comes in very fast. Cam is listed in my sig. It will idle at 600 RPM in gear at 22 degres outside.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-04-2011, 09:48 PM   #10
Notch1988
Notch1988's Avatar
LOL, when it's cold and snowing here the only place you'll find me is in the garage.
Did you check piston to valve?
