10-07-2021, 12:06 PM | #1 |
Positive Camber with CPP drop spindles
Anyone else end up with severe positive camber after installing a set of CPP drop spindles? I am running a 3" lowering spring as well. Even with all the shims and spacers removed I think I would still be positive on the camber.
10-09-2021, 06:47 PM | #2 | |
Re: Positive Camber with CPP drop spindles
Do you have any pics you can share? That might generate some ideas or suggestions.
10-10-2022, 07:31 PM | #3 |
Getting back to this post to hopefully find a solution. I am using stock cross member and control arms. I installed CPP's 2.5" drop spindles and a 3" lowering spring. Truck is a 1966 GMC 1/2 ton. It looks like even if I removed all the shims and spacers from behind the upper control arms the arm would hit the frame before the camber would be corrected.
10-10-2022, 07:52 PM | #4 |
You can't measure camber until you get the weight on it. No engine/cab/etc will equal much positive camber.
10-10-2022, 08:11 PM | #5 |
This is an old picture. The fully assembled truck still has really bad positive camber
10-10-2022, 09:29 PM | #6 |
What does the camber look like? Having the upper control arms on the wrong side makes everything off. From the pictures they look flipped.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
10-10-2022, 11:07 PM | #7 |
How much camber are you talking? Use a phone app to measure down to the tenths if you don't have a digital angle finder to check with.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
10-11-2022, 09:28 AM | #8 |
I second what PG Sign says. I don't want to admit it, so I won't LOL but I had mine switched when I did my frame off.
10-11-2022, 09:36 AM | #9 |
I know having the uppers on the wrong sides will definitely skew the Caster.
Not sure how much it would impact Camber though. Weight on the chassis will make a difference.
10-11-2022, 01:57 PM | #10 |
I had a look at the assembly manual. I am pretty sure the controls arms are on the right sides. Looks like the angled side and the bump stop are to the rear. This is a photo of the passenger side
I stuck an angle gauge on the hub. It is showing 2 degrees. I am surprised it isn't more, it looks ridiculous looking at the wheel I am going to pull all the shims and see where that gets me. |
10-11-2022, 02:36 PM | #11 |
