Old 10-11-2010, 09:56 PM   #26
3r!c84
Badass
3r!c84's Avatar
Re: 85 Shortbox Low and not so slow
Originally Posted by 85_prairieboy View Post
I built a 350 for it with AFR 195 Eliminator heads and Speedpro forged pistons. On that pass I was spraying a 150 shot but it didn't pull as hard as I thought so I put the bottle on a gauge and it was only reading 600 psi. It should be a minimum 900 psi. It was a cool day and I don't have a bottle warmer yet so I guess it was the best I could do. In the rear all I have is the stock suspension and slicks. I was surprised how well it hooked. But I only have 3.42 gears so that is probably part of the reason. When I bought those gears I was still wanting to drive the truck and get good mileage. I am getting 17-18 mpg so not too bad. That is all going to change soon. I am back halfing the truck and increasing the cubic inches either by stroking my smallblock or starting fresh with a bigblock.
man nice set up. i will be crazy happy if mine even runs 14s with my new 400sbc set up
need to redeem myself from the 17.0 stock 305 time
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 10-12-2010, 12:59 AM   #27
nightglide
nightglide's Avatar
Was planning on doing the same paint scheme except white with blue stripes. Can you tell me how wide yours are and how far apart they are?
Owen
nightglide is offline   Reply With Quote
Old 11-01-2010, 02:49 PM   #28
85_prairieboy
85_prairieboy's Avatar
Originally Posted by SS Delux View Post
Where did you get the l88 scoop from and do you have any pics / tips on installing it cause I asume that it is glass.
I bought it used so I'm not sure who made it. I don't know what the best way to mount these scoops is. I used fiberglass strips and resin to bond it to the stock hood and then filler to blend in the transition. It lasted about 4 or 5 years but is now starting to crack a bit at the 2 front corners.
85 GMC toy Lowered, newer box swap, 350 .060 over with AFR 195s, forged pistons, TCI TH350
1.83 60' 13.14 @ 100 on motor
1.49 60' 11.52 @ 116 w/150 shot
1952 Chevy truck project
1980 Z28 Camaro
1967 Camaro drag car 10.60@126
85_prairieboy is offline   Reply With Quote
Old 11-01-2010, 02:55 PM   #29
85_prairieboy
Originally Posted by bigblock73 View Post
I don't think he is back halving the truck just for looks, by reading his above post.
Correct I first wanted to make sure i would have no traction issues and then increase the power rather than the other way around
1980 Z28 Camaro
Old 11-01-2010, 11:39 PM   #30
MikeJones16
MikeJones16's Avatar
Hey! another guy from Saskatchewan!
Nice run from SIR!
I take my black 02 mustang gt out there on street legals.
MikeJones16 is offline   Reply With Quote
Old 11-02-2010, 01:32 AM   #31
smokedat
smokedat's Avatar
Sweet ryde, god I love squares that go fast
have you dynoed it? how much pwr u think u got at the rear? what is youre current rear set up?
smokedat is offline   Reply With Quote
Old 11-02-2010, 09:48 AM   #32
85_prairieboy
MikeJones Yes another prairieboy lol. I'm sure I've seen your car go down the track. I race the street legals too
Smokedat I haven't dynoed it but to go 12.7 in a 3600-3700 lb truck you need around 300 hp at the rear wheels. I have a narrowed 10 bolt rear with a spool, c-clip eliminators and 4.88 gears
1980 Z28 Camaro
Old 03-12-2011, 12:39 AM   #33
85_prairieboy
I had to use my trailer so I backed the truck out, Took a few pics. Its actually the first time I have seen it in the daylight since I started working on the rear suspension. I still have to get some tires for the matching front rims and finish up a few things in the rear (including lowering the rear now that I see the stance)
1980 Z28 Camaro
Old 03-12-2011, 01:04 AM   #34
MikeJones16
Looks good. PS if you need your bottle warmed up let me know. I'll warm it up for ya. I Like doing the N/A passes more then the bottle anyways.
I'm hoping for mid 12's this season on the 125 shot. Finally have some decent tires and suspension.
You'll see me pulling it in my truck from now on. well. Once I build a trailer after..
Old 03-12-2011, 01:18 AM   #35
85_prairieboy
Yeah that would really help Mike. I would really like to run a 12.99 on motor this year. And I'm curious to see what it would do with a warm bottle. Its pretty sad when my brother has a better 60' than me. His 97 Camaro with street tires and my truck with slicks and nitrous
1980 Z28 Camaro
Old 03-12-2011, 01:21 AM   #36
MikeJones16
Mhm. last years 60's were 2.2 Hopefully 1.6-.7 this season. See you then!
Old 04-19-2011, 01:03 AM   #37
85_prairieboy
Got my front wheels on. Still waiting for lowering blocks
Name:  new wheels.jpg
1980 Z28 Camaro
Old 04-20-2011, 09:19 PM   #38
Chris Guthro
How much wokr involved was it getting that box on the frame?
Chris Guthro is offline   Reply With Quote
Old 07-14-2012, 12:33 PM   #39
85_prairieboy
Haven't had any updates for a while. I had it out at the track last night. First time in probably 2 years. I was hoping to at least be as fast as I was before with a 12.74 at 104 mph. I ended up running an 11.81 at 114 mph. All that was different this time is the gears and tires. Same powertrain with no changes to timing or jetting. I was pretty excited. The track was poor so I know I can improve my 60 ft. It was 1.77 sec. I'll upload the video asap
1980 Z28 Camaro
Old 07-14-2012, 09:26 PM   #40
85_prairieboy
1980 Z28 Camaro
Old 10-07-2012, 06:11 PM   #41
75ChevyGuy
GM Parts Guy
75ChevyGuy's Avatar
Did all the bed bolts line up when you were putting the newer box on?
1975 Chevrolet C-10 Custom Deluxe (DD/WIP)
1989 Chevrolet C1500 reg cab stepside (Winter Truck)
1977 Harley Davidson XLH 1000 (Summer Cruiser)
75ChevyGuy is offline   Reply With Quote
Old 10-09-2012, 11:18 PM   #42
85_prairieboy
No I don't think any of them lined up. Also, the frame is shaped differently so you have to use spacers in the front and make brackets for the rear.
1980 Z28 Camaro
