09-15-2021, 05:26 PM | #151 |
Always on the hunt...
Re: F/S OE 72 Big Block Parts, Brackets, Stove Pipe, Air Cleaner, Towers and/or Reque
We will offer this new set of 72 style BBC steel/rubber mounts (the isolator/wear part) that bolt between the towers and clam shells for $35./pair to the buyer of the above BBC tower setup if combined and sent together as one shipment. Thanks, Mel
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our paypal account & info has been changed as of Jan. 2022. Thanks... |
09-15-2021, 06:48 PM | #152 |
In need of just the 2 crank pulleys
09-15-2021, 07:28 PM | #153 |
pm sent
09-16-2021, 12:19 AM | #154 |
I know that we have an extra inner 414 BBC crank pulley stored on the shelf but if not in need of/wanting a BBC remote fill p/s pump setup, we would need to check on availability of the outer 525 BBC p/s add on crank pulley by itself in the morning. Mel
09-16-2021, 12:51 AM | #155 |
At this time we are only offering shipping in the Cont. U.S., do you have a lower 48 address to use for receiving parts shipments? Will check on the availability of the OE steel vacuum lines and air cleaner stud/wing nut per your 72 BBC 402 parts request in the morning, currently our only on hand 71-72 style OE throttle return springs are listed in the below linked f/s thread paired/offered with the matching OE accelerator cable to carb mounting brackets. Mel
http://67-72chevytrucks.com/vboard/s...d.php?t=821213 .
09-16-2021, 08:31 AM | #156 |
ok let me know what pulley you have thanks
09-16-2021, 09:56 AM | #157 |
Let me know what you want for the acc. brkt and spring as well as the other parts listed in the pm. I do have a US shipping address.
Thanks |
09-16-2021, 01:06 PM | #158 |
Mel, I'll take the big block mounts with the towers and clam shells and hardware. Let me know the total and payment info. Thanks, Mike
09-16-2021, 06:17 PM | #159 |
Hi Mike, if wanting the whole 72 BBC tower, clam shell and hardware setup with the new pair of mounts as offered the pricing would be: $250./OE 72 BBC tower setup + $35./New mounts + $21.90/USPS ship + $9.64/pp fee = $316.54 total. We have returned our info for sending funds on 09/16, please confirm your full shipping address and we'll get the parts ready to go out. Thanks, Mel
09-16-2021, 08:12 PM | #160 | |
09-17-2021, 07:03 PM | #161 |
Did you have a chance to check on the vacuum lines and carb stud/wing nut?
Thanks ...Scott |
09-18-2021, 12:12 AM | #162 | |
09-18-2021, 12:20 AM | #163 |
Hey Mike, your 72 BBC tower setup and new mounts have been shipped, the package went out via USPS priority on Fri. 09/17 and your expected delivery day is this upcoming Tue. 09/21. Thanks again for your order and let me know if we can help with any other 67-72 parts needs, Mel
09-18-2021, 10:47 AM | #164 |
I'll take the bracket and spring. Let me know on the other parts and they can ship with brkt/spring. Thanks Scott
11-12-2021, 12:05 AM | #165 |
i need a set of pullies and an alternator bracket
11-13-2021, 12:53 AM | #166 |
We may be able to help but would need some more info from you. Do you have a CONUS address to use for receiving parts shipments, what year/style BBC brackets and which motor accessories are you needing the pulley setup for? Mel
11-17-2021, 03:57 AM | #167 |
11-22-2021, 06:10 PM | #168 |
Per your sent request, here are the OE BBC alternator brackets and OE BBC water pump and inner/outer crank pulleys for turning water pump, alternator and p/s (NO A/C). Will combine ship the below pictured BBC 70-71 style 2 pc. Alt. bracket set and BBC 3 pc. pulley setup for $22.45 via USPS CONUS shipment. The payment options are listed in the first post of thread, confirm preferred method and we'll get that info returned back to you. Thanks, Mel
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our paypal account & info has been changed as of Jan. 2022. Thanks... Last edited by Classic Bowties; 12-17-2022 at 03:53 AM. Reason: Ship cost |
11-25-2021, 03:59 AM | #169 |
The Non-A/C BBC pulley setup and BBC 70-71 alternator bracket setup pictured in above post #168 are now both available to anyone interested, 1972BackInBlackC10 has confirmed via pm that he's unable to complete on his end. We are also adding the two below pictured OE 402 BBC/Th400 high hump "No Hole" tunnel covers to this BBC parts thread, both are original 506 dk. olive & 516 orange paint. $135. ea. Thanks, Mel
***516 orange cover Sold/Shipped 11/26/21*** ***506 Dk. olive cover Sold/Shipped 09/13/22*** .
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our paypal account & info has been changed as of Jan. 2022. Thanks... Last edited by Classic Bowties; 09-13-2022 at 09:52 PM. Reason: Updated availability |
11-25-2021, 07:34 AM | #170 |
I will take one of the high humps, don't care which color, ship to 52601. also sent private message
Tom in Iowa 68 L88 C10 68 4x4 C10 soon |
11-25-2021, 03:03 PM | #171 |
I will take post 150and 151.
11-25-2021, 06:44 PM | #172 | |
That pictured 72 BBC tower/clam setup was sold to member mkmc69 per post #158, can check on another set but am pretty sure that our current 72 setups are all still in trucks with the motors installed, we do have 68-71 style BBC stands pulled/stored on the shelf.
11-27-2021, 01:24 AM | #173 |
The orange BBC/Th400 high hump tunnel cover is underway, your package went out via FedEx home delivery service on Fri. 11/26 and the expected delivery day is next Thu. 12/02. Thanks again for the order and let me know if we can help with any other 67-72 parts needs, Mel
11-30-2021, 09:17 AM | #174 |
do you have a set of 71 big block motor mounts with towers and everything? i'm doing a 454 swap and would like to use OEM brackets for that if possible.
Six in a row makes it go |
12-24-2021, 09:35 PM | #175 | |
