Old 03-25-2021, 10:08 AM   #1
Zeekmiester
Front Suspension Parts
G'Day All,
I have a 1960 GMC Stepper and wondering who would have the correct replacement parts for my Lower Ball joints and Idler arm. I have seen a couple variations on the idler (curved or straight)? or does it matter? They look to be 5-1/2" center to center. As far as the lower ball joints go, It seems they have been replaced in the past since they are bolted and not rivetted. I have had fitment issues like the rest of you and was hoping to save some grief. See pics below.
I do not see any slop in the ball joint But, when I try to move the tire from 6-12 O'clock I feel about 1/16"-1/8" movement, when I do it with the tire off I don't feel any movement. at 9 and 3 I see some movement in the idler arm. Does not seem to be the wheel bearing. Issue is on both sides. Suggestions would be appreciated.
Zeekmiester is offline   Reply With Quote
Old 03-26-2021, 04:33 PM   #2
Clyde65
Clyde65's Avatar
Re: Front Suspension Parts
Rock auto had mine, moog brand, 65 GMC
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-28-2021, 10:49 AM   #3
Zeekmiester
Thanks for the input, I found a set on CPP.hope they are the same. Now, to find a manual steering box or rebuild shop near northern Ohio. Thanks again
