01-12-2022, 06:04 PM | #651 |
Moderator
Re: 60-66 Tire/Wheel Pics
Can't believe I haven't posted mine. 16's and 17's.
01-13-2022, 08:43 AM | #652 |
01-13-2022, 10:16 AM | #653 |
Moderator
215/70R16 fronts on American VN6156773
235/60R17 Rears on American VN6157873
01-15-2022, 03:43 PM | #654 |
17x10 rear 5” backspace
17x8 front 4” backspace No outside pictures here for a bit, there is an inch of ice in front of my shop…. |
01-15-2022, 06:34 PM | #655 |
Any more info on the wheels? Steel or aluminum? Manufacturer?
01-15-2022, 07:17 PM | #656 |
Every time I see your truck I am curious about the black along the bottom and the shiny rockers. Is it unfinished rust repair or are you going for a new look.
01-15-2022, 08:30 PM | #657 |
This thread is so old I actually have new wheels. I bought the US Mag Boulevard in 20"x8". I like them alot!!
RED RUMBLE 1963 C10 Chevy Truck Owned since 1984 |
01-15-2022, 08:35 PM | #658 |
The wheels are aluminum from American Racing, I had the rear ones custom built for my 65 Chevelle, however I got too greedy even minitubbed they were just too close for comfort, so to match, I had the front ones done, with the backspace I wanted they became custom also….
The black rocker bottoms I figured the same as you when I purchased the truck, however when I got it on a lift, I found no rust, the stainless piece is just a trim piece The previous owner had a metal shop, all the stainless stuff he made is 14ga, he did a great job and I like the look so I am keeping all of his work intact. |
01-15-2022, 08:35 PM | #659 |
01-15-2022, 08:52 PM | #660 |
I converted everything to 5 43/4, I had a full set of 15x8 vette ralleys I was gonna use till I decided to go this route. The truck will never be a heavy hauler, so the smaller pattern will be fine, I didnt buy anyones kit, just got the correct rotors and bearing sets and did it much cheaper, even used the stock spindle, the front suspension is from an 86, coilovers all 4 corners. Built all the rear mounts and used a POL lower Arm, built my own upper mount…
01-15-2022, 09:39 PM | #661 | |
01-16-2022, 10:01 AM | #662 |
"Are those 6 lug or did you convert it to 5?"
They are six lug. I did install longer wheel studs too.
01-17-2022, 03:07 PM | #663 |
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
01-18-2022, 11:45 PM | #664 | |
What tire sizes are you running and are you on the stock inner fenders up front? I assume with a 17x10 that the rear tubs are widened? How is the truck lowered and how much?
1965 GMC 910 Short Fleetside. 230 CI 4-speed. |
01-19-2022, 08:01 PM | #665 |
I just put new wheels and tires on my '64. They are Rev 107 18x9s with 255/60/18s on front and 285/60/18s on back. I love them!
01-19-2022, 08:23 PM | #666 |
vary nice. are those aluminum or steel.
01-19-2022, 08:25 PM | #667 |
01-19-2022, 08:53 PM | #668 |
The tires are 305/45/17 in the rear and245/45/17 front, wish I had little bigger in front, but I already had them. The inner fenders are stock up front and the rear tubs are 11 1/2 “ from the carpet on the side to the outer edge, I measured some stock ones I have and they are 11”. The truck sits on coilovers front and rear, so guessing about 6” lower in the back and 4” in the front….Thanks for the kind words…
01-20-2022, 10:33 AM | #669 |
Excellent choice!
04-29-2022, 09:31 PM | #670 |
MT65 or Verdell..... Any chance that either one of you has any pics showing the back-side of those wheels?
A.R. wheel distributors won't provide dimensions or images to make an educated decision as far as big brake packages go. I'd like to see the back side of one of those wheels to see what there is to deal with.
04-30-2022, 03:20 PM | #671 | |
The AR people that answered the phone are NOT fun to deal with…before he retired I had a direct number to a guy at the plant where they were made, worked great…..those that you’re having to deal with suck… |
04-30-2022, 07:25 PM | #672 | |
That webbing is what interferes w/big brake calipers which is why spacers are required for clearance.
04-30-2022, 07:37 PM | #673 |
The rear wheels, the ones in the pictures do have a spacer and fit over 4 piston wilwoods, the front ones have no spacer and are over the large piston GM caliper which I think are larger interference wise than the Wilwood…
04-30-2022, 08:49 PM | #674 |
04-30-2022, 10:04 PM | #675 | |
I actually wanted to use the VN327's on my g-body Malibu that will be getting a budget GM based late model 2-piston caliper set-up (C6 base caliper w/Z51 13.4" rotor. No go w/o spacing them @ least 1/2". I have zero interest cobbling things together just to clear. It's a similar issue using the Torq Thrusts.
