Old 01-21-2022, 06:38 PM   #1
Nick_R_23
Nick_R_23's Avatar
Did GM ever publish a GCWR list?
Just like the title says - did GM ever publish a list of GCWR’s for Squarebody trucks? GVWR is easy to find, but not GCWR.
Planning a cross country move within the next couple of years and looking to stay DOT legal.
Truck was originally a 1978 Chevy K20, 6800# GVW, 350-4, SM465, 3.73 gears, vacuum brakes.
Old 01-22-2022, 04:34 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Did GM ever publish a GCWR list?
They are called the trailering guide.
Some appear in the brochures and some in the generic info packets, but not with any regularity.
Next time I come across one I'll post it up.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-22-2022, 06:05 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
Here ya go. It's for '74 but shouldn't be that different.
~Steven
Simi Valley, CA
Old 01-23-2022, 08:30 PM   #4
Keith Seymore
Well done, Steeveedee.
I see my work here is finished.
K
1979-1986
1986 - 2019
Old 01-24-2022, 02:11 AM   #5
Nick_R_23
Nick_R_23's Avatar
Thank you guys! Keith, I recall you mentioning before that you evaluated some of these ratings by “launchability”. Was there much design behind that aside from larger engines and deeper gears?
Quite a bit of this truck has been changed since new. It now has Camper Special springs and full floating rear axle, a 5.3L, and hydroboost brakes. It appears from the factory that it was designed as a 9500 GCW, but I’m curious of your opinion on what you think this truck would class in the same test today with these modifications?
Old 01-25-2022, 11:56 AM   #6
Keith Seymore
I didn't really get to affect the design. I took what was already locked in (in terms of powertrain content, based on other variables like unladed driveabilty, or fuel economy targets) and did a go/no go evaluation for the launch up the 16% grade, based on the existing rating.
Really the only knob I was allowed to touch would be to recommend dialing up or dialing down the trailer rating, if needed.
Probably better, due to increased horsepower and better springs. I don't think brakes were part of the equation since it was assumed/required that the trailer itself would have appropriate braking.
In any case, if you are trying to stay "DOT legal" you better stick to the published number.
K
1979-1986
1986 - 2019
Old 01-25-2022, 09:10 PM   #7
Nick_R_23
Nick_R_23's Avatar
It’s definitely better, was just more curious of a guess of what it may have achieved in the same test today.
