Old 05-02-2022, 01:15 PM   #1
72c20customcamper
72c20customcamper's Avatar
Rear axle bearings need advise
I took out the axle bearings on the 68 not liking what I’m seeing . This is a little concerning looks as if the bearing was turning in the housing . Not sure if throwing new bearings in will work .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 05-02-2022, 01:24 PM   #2
67C10Step
67C10Step's Avatar
Re: Rear axle bearings need advise
Ooofta! What did the axle look like where the bearing rides? Although, am I seeing the same ridges where the seal sets in the axle? If so, I'd say they both weren't turning and may not be an issue.
Maybe someone else will chime in that has seen those same ridges before.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2020 Toyota CH-R
2020 Acura MDX
67C10Step is offline   Reply With Quote
Old 05-02-2022, 01:31 PM   #3
72c20customcamper
Axles look great no scoring . I just noticed the lines are where the seals go too . Maybe it’s just the way they are ?
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-02-2022, 01:40 PM   #4
The bearing moves freely in the race? I guess you could mic the housing and compare to the other side. It does look exactly like the race has been moving. What would it take to put it back together to make observations now that you've seen this? Unless someone comes along and puts their finger right on the problem. All I can imagine is the bearing not spinning freely, but I'd expect something visual on them if the bearing shows what it is.
Old 05-02-2022, 02:00 PM   #5
72c20customcamper
I needed to use a slide hammer to get the bearings out of the housing so didn’t seem loos. The needle bearings look good no pitting or scoring move freely . Figured I was in there looking for a noise (sounded like a bad bearing) that I’d just replace them regardless of how they looked . No blueing on the bearing or the housing
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-02-2022, 02:13 PM   #6
400/400
Is there scoring on the outside of the bearing you removed, or is it just discoloration?
Since you said they were tight in the bore, they may not have been spinning. It’s hard to tell by the pic, but usually a spun bearing shows heat marks (blueish discoloration) vs just scoring.
It may just be how the axle tube was machined.
1979 K25 350/SM465/205/44HD/14FF
1985 K20 400/400/208/10/14
1987 V10 TBI350/700R4/208/10/10
'85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968
400/400 is offline   Reply With Quote
Old 05-02-2022, 02:21 PM   #7
72c20customcamper
No blueing on the bearing or the housing and the marks are mostly on the top of the bearing so it just might be imprinted from weight . I’m leaning towards this is the way it was machined . Specially since the seal housing is the same . Think I’ll get some new bearings and put some sleeve retaining compound on it and call it a day
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-02-2022, 04:02 PM   #8
72c20customcamper
Found the rear end noise . Left carrier bearing is toast .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-02-2022, 09:19 PM   #9
That's the pits
Old 05-03-2022, 03:43 PM   #10
HO455
Post Whore
HO455's Avatar
If it was mine I would do some measuring of the bearing seats in the axle and if they are not oversized and not egg shaped for piece of mind I would install the new bearings with some liquid bearing retainer. Similar to LocTite.
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
Old 05-03-2022, 04:16 PM   #11
Jrainman
Jrainman's Avatar
Agree , well said .
Jrainman is offline   Reply With Quote
Old 05-03-2022, 07:48 PM   #12
72c20customcamper
The axles checked out as did the housing . I even went so far as to dig out the 12 bolt from my chevelle and the housing looks the same. Guess they didnt finish machine them from the factory. I will use loctite high strength 640 sleeve retainer when I install them . Waiting on one carrier bearing to put it back together have everything else .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-03-2022, 08:13 PM   #13
TALLone71
I have seen axle housings machined like this over the years in the shop where I work, the race was tight and required the normal force to remove it, and when I drove the new race in everything felt right, and never had an issue with installation. glad you found your noise, that carrier bearing is definitely done
:chevy
TALLone71 is offline   Reply With Quote
Old 05-03-2022, 09:34 PM   #14
Just call me Sean
Just call me Sean's Avatar
I'm working on the rear of my S10, but I haven't pulled what's left of the bearing yet to see if it looks like that. I was considering using a repair bearing, but I've had one come out before on something else. Maybe I'll try one again with that bearing retainer stuff. Never heard of it before.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 05-04-2022, 05:54 AM   #15
I never heard of the bearing retainer stuff either. I imagine it makes for a very difficult race to remove on down the road. I think if your measurements all check out I'd just go back together with it dry.
Old 05-04-2022, 09:29 AM   #16
72c20customcamper
I've used it before on press in fitting for hydrolic hoses . There are several strengths like the thread locker
https://youtu.be/riTo3zwyIaU
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-07-2022, 10:09 AM   #17
HO455
Post Whore
HO455's Avatar
The bearing retainer products I have used have a 200 to 300 degree maximum temperature which allows you to use soft heat (Like a propane torch) to break down the retainer material when it comes time to remove the bearing.
RIP Bob Parks.
