11-07-2022, 03:32 PM | #1 |
Tail lights not working
I just replaced all the harnesses on my 69 c10. My rear turn signals and brake lights work but my tail lights “running light” don’t. All new bulbs and flashers as well. Any thoughts?
11-07-2022, 05:41 PM | #2 |
Re: Tail lights not working
I’ll put this out there before everyone else does….. grounds! I checked all mine like three times and still missed one. If all your grounds are solid then maybe a pinched or loose wire.
1971 K10 short bed step side, 5.3/th350/205, 3.73 gears |
11-07-2022, 07:59 PM | #3 |
Msgt USAF Ret
Pull the harness plug on the firewall by the accelerator mount and apply 12 volts to the dark brown wire. If the lights don't light the problem is in the rear of the truck. I fthey do light the problem is at the headlight switch.
A bad ground is usually the issue when the lights won't light in the rear. And a blown fuse is usually the problem in the cab.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
11-08-2022, 01:04 AM | #4 |
Do the dash lights work?
11-11-2022, 05:18 PM | #5 | |
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
