08-13-2015, 09:33 PM | #1 |
DIY 3 Point Seat Belt Installation 1960-66 Cab
Here's a DIY I made showing my 1965 C10 seat belt installation. I am not as familiar with the 1960-63 cabs, but it chould be the same.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
08-13-2015, 09:34 PM | #2 |
Re: DIY 3 Point Seat Belt Installation 1960-66 Cab
More pics
08-13-2015, 09:37 PM | #3 |
More
08-13-2015, 09:41 PM | #4 |
more
08-13-2015, 09:45 PM | #5 |
another
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. Last edited by Lugnutz65; 08-13-2015 at 09:59 PM. |
08-13-2015, 09:47 PM | #6 |
Some more pics
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. Last edited by Lugnutz65; 08-13-2015 at 10:01 PM. |
08-13-2015, 09:48 PM | #7 |
another set
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. Last edited by Lugnutz65; 08-13-2015 at 10:04 PM. |
08-13-2015, 10:06 PM | #8 |
Several more
08-13-2015, 10:07 PM | #9 |
Last two pics
08-13-2015, 10:25 PM | #10 |
Great job and thanks for sharing. This is going to be super handy when I do mine.
Could I ask where you got the seat belts? I like the look of them. Thanks! Scott |
08-13-2015, 10:34 PM | #11 | |
08-14-2015, 12:13 AM | #12 |
Lugz, do the 140" provide enough 'slack' to work if the bench seat was slid all the way forward? Basically, is it enough for each extreme in seat position... nice write up.
08-14-2015, 12:43 AM | #13 |
Yes. The 140" is plenty long enough.
08-14-2015, 09:50 AM | #14 |
What about us Suburban and Panel owners that want 3 pt belts? Same mounting? Our floor is a little different on the passenger side.
Thanks |
08-14-2015, 10:04 AM | #15 |
I have no experience with the Panel trucks and Burbs. So I can't offer help there. If anyone has done this install in a Burb or Panel I would welcome their input with photos to explain.
08-14-2015, 10:35 AM | #16 |
Read through this on your blog and to be honest.........
I will be fitting some of these to my truck. Just need to find the right donor pieces. Thank you for sharing Jay.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
08-14-2015, 11:03 AM | #17 |
excellent thread. Should be a "Sticky"
08-14-2015, 12:10 PM | #18 |
08-14-2015, 12:18 PM | #19 |
No, I don't think the 20" side is long enough if the seat is all the way forward. If that is a concern then the only option would be to move the floor mount location forward or have them make that belt piece longer by 8-12". Too long would be easier to deal with than too short. They make an extension piece for the shoulder anchor and if you call them, they might suggest a similar extension piece for the floor mounted belt. So there are options to play with.
08-14-2015, 12:43 PM | #20 |
Thanks, gave them a call since I need a seatbelt to accommodate a 6 foot as well as 5 foot person...was concerned about the stationary side of the belt falling into crease of seat when the wife is driving. The solution: don't let the wife drive the truck.
When installing the stationary belt, allow 4-6" of 'lay' on the bench seat from the crease (in the furthest back position)... this should allow enough adjustment for various height people. If the seat can be adjusted beyond that (forward), a custom stationary part can be ordered. If using a GM style buckle, the length is non-adjustable. If using a lift-latch, you can adjust the length of stationary side. The key point on the stationary side is that when latched, the buckle sits by the hip area. If the stationary side is too long, it may latch more towards the center of the body. If this occurs, it can make the shoulder strap non-operable and the occupant can slide out of belt. If the stationary strap needs to be adjustable, only certain styles of latches can be used. Thanks again |
08-14-2015, 02:39 PM | #21 | |
08-14-2015, 02:40 PM | #22 |
Very good write up Lugnutz65! most helpful!!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-14-2015, 05:18 PM | #23 |
That's pretty cool. Well done.
1966 Chevy C-10 350 Engine 700R4 |
08-14-2015, 09:50 PM | #24 |
awesome contribution
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
08-15-2015, 03:23 PM | #25 |
Awesome write-up... Bookmarked...
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
