Old 11-09-2022, 08:10 PM   #1
vht
2 things, cab mounts and Muffler
Anyone know of where to get a set of cab mounts, with bolts that is a decent price? Also, what muffler do you all run that has decent sound but not to loud? I was thinking of flow master, I also was thinking of some shorty headers and a 3/4 ton 3 in Y pipe, I done have a 3 in tail pipe. I just don't want headers that I have to worry about burning wires and plugs that are hard to change. My truck could use a little more get up and go, it's a 94 K1500 with a 5.7.
vht is offline   Reply With Quote
Old 11-10-2022, 08:33 AM   #2
Re: 2 things, cab mounts and Muffler
Not sure about the cab mounts. Last set I got were thru LMC. Muffler, normally a magnaflow has been on most of my trucks since I don't normally have a stock exhaust.
Old 11-10-2022, 09:39 PM   #3
vht
I'm looking at the 3 in Dynomax ultra flow, they say it has a good sound and doesn't have the drone. Anyone running one of these? 17229 is the pt #.
Old 11-11-2022, 09:29 AM   #4
sntrym95
sntrym95's Avatar
I used the polyurethane cab mounts, and got bolts from the dealership. You can use grade 8 bolts, and if you can find them with a shoulder then you don't need washers.
I run the Gisbon cat back exhaust and it has a nice sound with a little bit of drone but not much. Full 409 stainless with a 304 muffler. I also run the Gibson shorty headers with the donut built in.
Mike
sntrym95 is offline   Reply With Quote
Old 11-11-2022, 12:21 PM   #5
One of the tricks I was taught, if this is a crew or extended cab, move the muffler as far back as you can and that will lessen the drone. Most of my stuff is regular cab, but I tend to do the same thing and have had no complaints with most of my combinations. I have use FlowMaster Delta 50s,Flow master 40s, Magnaflows (several versions) and even some Cherry bombs without a drone issue. LOUD in some cases, but never a bad droning issue.
Old 11-21-2022, 02:22 PM   #6
OutlawDrifter
I would vote the 20" case version of the Dynomax Ultraflow you posted.
The 14" will get loud. The 20" case Ultraflow is my go to on pickups.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 11-25-2022, 08:16 PM   #7
Tom
driving is in my blood
Tom's Avatar
I run a flowmaster 50 series on my 98.
As for headers, don't waste time with shorties and factory y pipe. Get long tubes and the custom y pipe to attach to them.
Old 11-26-2022, 03:23 AM   #8
EVRLET
EVRLET's Avatar
Which longtubes have the egr fitting? Or are you saying to do an egr delete just to have longtubes
Customization is what you want it to look like -- not what other people think it should look like
EVRLET is offline   Reply With Quote
