10-28-2023, 06:38 PM | #1 |
New gauge cluster with tach
I am going to be installing a new gauge cluster with 5K tach. My blazer does not currently have a tack, but it is the Taiwan reproduction of the OEM stock gauge cluster that I will be installing. Does anybody have a good advice before I start?
10-28-2023, 07:16 PM | #2 |
Re: New gauge cluster with tach
You should purchase the stand-alone tach harness. The separate tach harness is a very simple 2 wire. One wire connects to the negative terminal of the ignition coil. The other plugs into the fuse block in an IGN UNFUSED terminal.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
10-29-2023, 02:21 AM | #3 |
I’ll do that. That’s going to help me a a lot thanks for the tip.
10-29-2023, 02:27 AM | #4 |
Just saw that there is one for HEI. So I’m buying that harness since my Jimmy has been upgraded.
10-29-2023, 10:49 AM | #5 |
OH jeez. I hope I bought the right one. Been a long time. Can you post a pic when you it arrives?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
11-01-2023, 07:03 PM | #6 |
JJZeppelin I will post pics when the gauge cluster arrives.
11-26-2023, 09:29 PM | #7 |
glad to see you painted your other gauge needles! nice work. So many people leave that step out and it becomes soooooo obvious that the tach is new.
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
