07-10-2022, 07:35 PM | #1 |
Fuel problem
Not sure what my problem is, but I cannot get fuel from the tank to the carb. I have been filling the bowl through the vent tube about 20 tomes. It fires up and runs fine and sounds DAMN GOOD with the Flowmasters on the headers.....until the bowl runs out. I have chased all of the lines from the tank to the pump and can't find any leaks. The vent line runs from the vent tubes in the back to the canister on the fender.
Any ideas??? |
07-10-2022, 09:20 PM | #2 |
Re: Fuel problem
I would disconnect the line from the tank to the fuel pump and make sure you are getting fuel there. I would also disconnect the line from the fuel pump to the carb. If you are getting fuel there there’s something clogged in the carb. If not and there was fuel at the input to the pump then the pump is most likely your problem. I have had issues on old thunderbirds where we weren’t getting fuel and we had to pressurize the fuel tank by using air from a compressor and blowing it into the fuel filler.
07-10-2022, 10:32 PM | #3 |
Re: Fuel problem
I went through all of my lines this morning. I installed a 40gal. tank with new sending unit, and all new lines front to back.
I pulled the pump and still no fuel. The pump rod is working. |
07-10-2022, 11:35 PM | #4 |
Re: Fuel problem
Have you tried running a hose into a gas can to verify that the pump is functional. Even if it’s new doesn’t mean it’s good.
07-11-2022, 01:08 AM | #5 |
Re: Fuel problem
I'm gonna pressurize the tank tomorrow to verify the lines aren't plugged. Then I'll test the pump.
07-11-2022, 03:32 PM | #6 |
Re: Fuel problem
Fuel line to the pump is incorrectly hooked up at the tank??
07-11-2022, 07:39 PM | #7 |
Re: Fuel problem
Have you replaced the 6 inch loop of hose inside the frame rail just in front of the crossmember (on a T400 truck)? That hose will go bad and the pump will only suck air. It won't leak fuel unless you pressurize the line.
I replaced mine with a short piece of steel line and 2 compression fittings. See photo. I bent my lines straight but they have 90 degree bends where the hose attaches from the factory.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
07-15-2022, 02:08 PM | #8 |
Re: Fuel problem
I pressurized the tank and pushed the fuel to the front. Problem solved!
07-15-2022, 02:31 PM | #9 |
Re: Fuel problem
Good to hear.
07-15-2022, 07:09 PM | #10 |
Re: Fuel problem
Until you run out of fuel. You may have a problem with the pump not being able to suck the fuel all the way to the front. You may either have a bad fuel pump, or need to make sure you pressurize the tank every time you fill up
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
07-15-2022, 07:32 PM | #11 |
Re: Fuel problem
So far, after breaking in the engine and running it to check everything, it runs and sounds really good. Excellent oil pressure, and great vacuum. Hasn't overheated. Bled the air out of the new power steering pump and steering gear. I put the Flowmasters directly on the headers and it sounds REALLY good! Can't wait to get the full exhaust on.
