Old 05-08-2005, 03:35 PM   #1
orangeuavol
GO VOLS!
orangeuavol's Avatar
NP205 TH400 question
Noticed for the first time today that when I shift the transmission from park to drive I get a gear grinding sound from the transfer case. When I put the tcase in 4lo, start the engine, ans shift gears its fine. But it makes that noise in 4hi and 2hi. Is this just the nature of the beast or is the tcase not fully engaging?
I've only moved the blazer in 4lo. Should I try to put it in 2hi and drive down the driveway to see it still makes that noise? First NP205 TH400 combo I've had so I don't know what to expect. Thanks in advance.
update:
the only t case position that will hold when the trannt is in park is 4lo (i.e with tranny in park it rolls like its in nuetral in 4hi and 2hi).
http://1972blazer.shutterfly.com/<= blazer build pics
It's called golf because all the other four letter words were taken.
It's easier to ask for forgiveness than for permission.
orangeuavol is offline   Reply With Quote
Old 05-08-2005, 08:19 PM   #2
orangeuavol
GO VOLS!
Bueler...Bueler...Bueler...
Anyone?
Old 05-09-2005, 09:57 AM   #3
smokekiki
Mike
smokekiki's Avatar
Wouldn't want to jump to conclusions,but it doesn't sound good to me.It should hold in high.Should not be any grinding.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 05-09-2005, 10:06 AM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
My '69 had a gear grinding noise in similar situations. The rear sprag clutch in my TH350 exploded. The sound was the fragments of bearings being tossed around inside the case until one wedged between the case and other internal parts and shattered more internals and cracked the case. I was sitting still in the driveway trying to determine where the noise was coming from - I thought it was my t-case.
I'd check/change fluid in the 205 first. If all looks good, I'd pull the pan in the tranny and look for metal.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 05-09-2005, 01:24 PM   #5
Medicanman71
Medicanman71's Avatar
mine does it too sometimes but so far so good.... show it who's boss
Medicanman71 is offline   Reply With Quote
Old 05-09-2005, 05:55 PM   #6
Blazer1970
Blazer1970's Avatar
The t-case is not shifting properly. Your truck is not going to move if you try it in 4HI or 2HI. It is only shifting halfway from low to high.
Blazer1970 is offline   Reply With Quote
Old 05-09-2005, 08:33 PM   #7
orangeuavol
GO VOLS!
Figured it out! Its a combination of slop in the shifter, shifter linkage rod, and the cross bar that connect the two shift rods. Whew, thought I was going to have to tear that thing apart.
Old 05-10-2005, 08:10 AM   #8
smokekiki
Mike
smokekiki's Avatar
Glad it was something simple.
