09-20-2021, 06:18 PM | #1 |
Junior Member
'83 C10 TBI swap
So I have a "90 Suburban that I am using for a donor. I mean complete, drove it home. Has 158,000 miles.
I am in the process of switching everything , and I mean everything, from the front seats forward. The '83 is just about ready to receive its new(er) parts, In getting it ready I had wondered about the fuel system, been searching and seen several say 5/16 is used for return line on TBI, the '83 has 1/4 return. The Suburban is 5/16 return. Haven't decided if I am going with '87 sending units and pumps or frame mounted pump. So my question is, will the 1/4 return work with the TBI? I pretty sure I will just change it out and do it the way the 'Burb is, but kinda wanted to ask and just post something about the project. |
09-20-2021, 08:57 PM | #2 |
Re: '83 C10 TBI swap
Do it correctly. 1/4” to 5/16” tubing doesn’t sound like much, but 1/4” is actually 36% smaller - pretty significant to lose over 1/3 of your flow capacity.
09-21-2021, 10:05 AM | #3 |
2nd what he said...
This is kind of an example. I have a supercharger add on kit (pro charger) on a 350mag marine engine. It is a merc multi port FI engine. As the boost rises there is more fuel needed to stay at the optimum mixture...to compensate for the higher demand of fuel needed procharger uses a boost reference regulator that restricts the RETURN side of the pump. This increases the spray when the injector fires, (cars typically increase pulse time to accomplish more fuel demand) I told you all of that to say, the restriction may bump up your pressure and cause a rich condition that would be hard to diagnose
61 GMC 4x4 1-ton flatbed 4bt cummins, ranger od, sm465, np 205, d60F, d70R 4.11 10,000 ramsey PTO winch.... SOLD 73 k5 gm crate 350-265 / sm465 / np205 3.73 posi |
09-21-2021, 11:50 AM | #4 |
Junior Member
ok, I will change it to 5/16.
Thanks for the replies. |
09-21-2021, 01:05 PM | #5 | |
These TBI side-saddle tanks and senders have been in short supply over the last year. Some key manufacturers have stopped making them, and the demand has gone through the roof because all the LS-swap guys are wanting these components as well. I think they're increasing in supply again, but I can't guarantee you'll find everything you need.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
