05-26-2023, 07:19 PM | #1 |
60-63 frame
What is the difference between the 60-63 frames. I found a tubular transmission crossmember and it states its for a 63-66.
05-26-2023, 09:05 PM | #2 |
Re: 60-63 frame
On the 60-62, there is a big old X in the way.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
05-26-2023, 11:06 PM | #3 |
Re: 60-63 frame
The X is one of the biggest differences for sure. Also, the front frame horns and front bumper mounts are different (shorter than 63-66), the rear section past the axle is wider on 60-62 (so also different bumper brackets), front cab mounts are spaced out wider, and the other major difference is the 60-62 trucks use a torsion bar front suspension while 63-66 use coil springs up front.
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
05-27-2023, 02:10 PM | #4 |
Re: 60-63 frame
Ok I wasnt sure lol thanks for the info
