Old 05-31-2021, 03:52 PM   #1
Asshat
Asshat's Avatar
Sway bar on a 63 with a later model cross member
Installed the 74 C20 cross member, and the sway bar doesn’t bolt up right. It seems I would have to create a new mounting position. However, the stock sway bar from the 74 cross member is to short. It lines up with the mounting positions on the control arms, it’s the frame mounting positions that do not line up. It’s too short.
Is there an aftermarket sway bar that will fit?
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 05-31-2021, 11:26 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Sway bar on a 63 with a later model cross member
Do you have factory frame stands for the sway bar on your 63? I didn't on mine, and when I added my sway bar from a late 70s 3/4 ton, I had to bolt the bar on with the suspension on the ground to get it done
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 05-31-2021, 11:37 PM   #3
Asshat
Asshat's Avatar
Not sure what you mean?
I did have a sway bar on my63, it was smaller diameter, and I gave it away when I sold my old front cross member.
The one that came with the 74 cross member doesn’t fit because it isn’t long enough, front to back. It bolts up to the lower control arms, it just doesn’t come forward enough to mount to the frame where the old brackets were.
292, 4-speed
Old 05-31-2021, 11:42 PM   #4
cwcarpenter98
Oh, I understand what you mean now. Sorry I'm no help as I haven't had that issue before
Christian Carpenter
Old 06-01-2021, 08:45 AM   #5
nsb29
nsb29's Avatar
Don’t know how much to short you are but if it’s a small amount maybe you could move your frame stands. I took this route I think I got it through Summit, Much better design than the original set up no binding but you do have to drill new holes
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 06-01-2021, 02:28 PM   #6
Asshat
Asshat's Avatar
Attachment 2105643
What truck is this, early, like a 63?
Also, can you post a closeup of the mounting to the control arm? I can’t tell from the pic. Did you have to modify the control arm, drill holes in it?
292, 4-speed
Old 06-01-2021, 05:47 PM   #7
SCOTI
SCOTI's Avatar
That is an aftermarket sway bar in his image. Some of them utilize the end-link attachment method like cars would have vs the factory method of shell/bushing bolted directly to the a-arm. They usually do require drilling extra holes for mounting.
Put the center of whatever sway bar you have on a jack. Mount each side to the a-arm. Raise the bar until the frame rail mounts contact the frame. Drill holes where necessary. Install hardware & tighten.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 06-01-2021, 07:56 PM   #8
nsb29
nsb29's Avatar
Scoti pretty much summed it up you have to drill one hole in each A-frame and two in each frame rail no stands required the truck is a 65
Old 06-01-2021, 09:17 PM   #9
Asshat
Asshat's Avatar
I don’t think so; it’s a good 4-1/2” too short from the original mounts. I can see making some holes to mount, however, it would then come too close to the idler and pitman arms.
Just not going to work.
292, 4-speed
Old 06-02-2021, 09:05 AM   #10
nsb29
nsb29's Avatar
63/72 is the same 74/80 sum thing is the same all though I see where some of the aftermarket ones advertise 63/80 sum thing but they are a lot more money I would get an aftermarket one for 63/72 if you want I can get you measurements off mine
Old 06-02-2021, 09:34 AM   #11
SCOTI
SCOTI's Avatar
When the sway bar is being installed, the suspension needs to be compressed @ ride height (it's normal position). They way you are set-up in your images, it's extended.
Was the bar you pulled off & sold w/the previous suspension factory installed & similar to the unit you're installing w/the later model year x-member? I never knew 63's came w/sway bars but I suppose they could have.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-02-2021, 09:57 AM   #12
Asshat
Asshat's Avatar
If you could get your measurements for the sway bar, I would appreciate it.
Mine is about 15” deep, 38” wide.
292, 4-speed
Old 06-02-2021, 10:00 AM   #13
Asshat
Asshat's Avatar
I tried installing it last night, with the truck sitting on the ground, not extended.
The 73 original cross member did have a sway bar. There are holes in the frame. That original sway bar was a smaller diameter. The one from the 74 cross member is 1”.
292, 4-speed
Old 06-02-2021, 11:25 AM   #14
SCOTI
SCOTI's Avatar
I mentioned about the truck being on jack-stands the way it was in the images just to ensure you were aware that the actual installation should be done w/weight on the suspension if/when drilling any new holes.
....Was the bar you pulled off & sold w/the previous suspension factory installed & similar to the unit you're installing w/the later model year x-member? I never knew 63's came w/sway bars but I suppose they could have.
....The 73 original cross member did have a sway bar. There are holes in the frame. That original sway bar was a smaller diameter. The one from the 74 cross member is 1”.
My question is was that previous bar similar to the current bar you're trying to install?
Were the end link bushings the same style as the frame mounting bushings?
Were there frame stands that the bar mounted to or was the previous set-up (that you sold) bolted directly to the frame?
These 63-87 C10 trucks had the factory sway bars mounted to factory attached frame stands & used the same bushing arrangement @ the frame & control arm pivot points. We need to understand what you likely had vs. what you're trying to put in. Knowing that info might shed insight on the differences you're experiencing.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-02-2021, 12:24 PM   #15
Asshat
Asshat's Avatar
Looked at some old photos, appears it was mounted to a raised standoff, and more forward, on a bracket-plate. This is the only picture I could find.
Guess I will have to look for an aftermarket sway bar.
292, 4-speed
Old 06-02-2021, 12:52 PM   #16
nsb29
nsb29's Avatar
This is as close as I can measure I cold be off a inch
Old 06-02-2021, 04:40 PM   #17
Paul Y
Make new brackets?
Just a thought....
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 06-02-2021, 05:56 PM   #18
Asshat
Asshat's Avatar
Originally Posted by Paul Y View Post
Make new brackets?
Just a thought....
P.
I don’t think I need to make new brackets, the brackets I have should work fine.
Maybe I can get a steel rod and extend each leg a few inches. Cheaper to buy steel rod and weld it on, rather than buy a whole new sway bar.
292, 4-speed
Old 06-02-2021, 06:00 PM   #19
SCOTI
SCOTI's Avatar
Definitely utilized different a-arm mounting.
The options are drill new holes in the frame to use the 74 model bar or spend the money to purchase an aftermarket set-up.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-02-2021, 06:26 PM   #20
Asshat
Asshat's Avatar
Can’t use the existing 74 bar unless I weld on a 5” extension. I think the bar would be too close to the pitman arm and idler arm.
292, 4-speed
Old 06-02-2021, 06:35 PM   #21
SCOTI
SCOTI's Avatar
Only way to know is put the a-arm mounts in place. Put the frame rail bushings/mounts on the bar approximately where they would pivot when installed. Loosely attach the frame stands to the frame pivot bushings & jack the bar up into place until the frame stands make contact.
Check clearances so you're not 'guessing'. If anything makes contact before the frame stands contact the rail/s, you have your answer.
Buying an aftermarket set-up may be the easy button or it could lead to additional frustration if the bars 'arms' are not long enough. I know from experience searching various sway bar criteria, not all manufacturers offer the dimensions to help make an informed decision. They usually will just offer that "it's intended to work on 6X-8X year model" truck.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-02-2021, 06:50 PM   #22
AcampoDave
AcampoDave's Avatar
Could the sway bar be upside down?
AcampoDave is offline   Reply With Quote
Old 06-02-2021, 07:00 PM   #23
Asshat
Asshat's Avatar
Turning it over doesn’t make it any longer. I thought about that too; it just changed the angle where it mounts to the control arms.
292, 4-speed
Old 06-02-2021, 07:02 PM   #24
Asshat
Asshat's Avatar
That’s what the picture showed from the other day. I had the brackets mounted at the control arms with the sway bar up on a jack stand.
292, 4-speed
Old 06-02-2021, 07:17 PM   #25
SCOTI
SCOTI's Avatar
Yes, you did.
You also did not have the frame stands in place. They would space the bar out slightly away from the frame possibly preventing clearance issues.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
